Yakima v OEM roof rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shotgunshooter3, Nov 24, 2013.
  1. Nov 24, 2013 at 10:47 AM
    shotgunshooter3
    shotgunshooter3 [OP] Well-Known Member
    Somewhere in the Southwest
    2025 DCLB TRD OR, Blue Crush Metallic
    Mud flaps
    I am debating between a Yakima or an OEM roof rack for my 2014 DCSB. Any thoughts on this? The Yakima is $100 less but the OEM will be covered under my warranty as a factory accessory.
    They well be used for the occasional kayak and that's probably it.
  2. Nov 24, 2013 at 11:56 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Personally I think the Yakima and Thule roof racks look better then oem.
  3. Nov 24, 2013 at 11:58 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    The factory only is rated for 100lbs vs about 150lbs for the Yakima. Unlike the factory rack, there are alot more attachments that you can interchange for carrying various items with the Yakima and finding parts used on CL is alot easier. Only advantage of the OEM rack is you can fold and store the bars away to prevent road noise. I am also not too fond of the bulky look of the OEM rack on top of the cab. Yakima racks are actually more pricey because OEM can be found on eBay for less than $250.
