Yamaha starting Problems
Discussion in 'All Terrain Vehicles' started by IndianTaco, Sep 1, 2011.
  1. Sep 1, 2011 at 5:55 PM
    IndianTaco
    IndianTaco [OP] Well-Known Member
    I have an 09 yamaha grizzly 550 efi that wont start. The battery is fully charged, kill switch is on all wire connections are tight. When I goto start it I can hear a rapid clicking noise coming from a relay. any ideas would be great.
  2. Sep 1, 2011 at 6:07 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    That relay may be hung up.......or the selanoid could be.
  3. Sep 1, 2011 at 6:15 PM
    IndianTaco
    how would one fix that
  4. Sep 1, 2011 at 7:07 PM
    IndianTaco
    i tried by pass relay with the cables and the starter just clicked but would not start or turn over. and no the motors not locked up
  5. Sep 1, 2011 at 7:17 PM
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    Was there any chance that you might have got the starter wet by washing or riding? If so you might half to take the starter apart and clean it. My Raptor 700 had something similiar and I had let it set for a few weeks after I went mud riding and it wouldnt start. The starter was kinda of rusted up so relay was I guesss kicking out cause of starter being froze up. Hope this helps
  6. Sep 1, 2011 at 9:55 PM
    IndianTaco
    thanks for the input! ill try this out tomorrow after work:D
  7. Sep 2, 2011 at 7:40 AM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    Make sure you gas and everything is on....it sounds stupid but i have done that before
  8. Sep 2, 2011 at 7:57 AM
    BLKTRD6SP
    BLKTRD6SP Well-Known Member
    Tim
    Crane Lake Alberta
    09 Black TRD 6 Speed
    2 way remote start,3M rockguard
    Check that your battery connections are tight also. had a bike that would click with the starter button depressed but would not start, turned out the connections were loose.
  9. Sep 2, 2011 at 8:19 AM
    mark73
    mark73 Noob :-/
    Poconos
    Green '02 TRD SR5 4x4
    Auto-Starter, 5-point harness rear seats, XM
    I know the sound you're talking about. My '01 Kodiak does the same thing when the battery gets low. I know you said that the battery is charged, but did you try and jump it? See if that helps.
    Also, did you try and pull start it? I know it can be a bitch, but try it once or twice just to see if that jars does anything. I found that by pulling the pull start out some and the letting it recoil just a little, releases the compression and makes it a lot easier to start.
    Good luck. Hope you get it going and get out there and ride!
  10. Sep 2, 2011 at 10:03 AM
    IndianTaco
    There no gas switch cause it efi
    Tried to jump it and nothing. Made the same clicking sound
  11. Sep 3, 2011 at 4:33 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    my yamaha does that too.
  12. Sep 30, 2011 at 6:27 PM
    IndianTaco
    ok come to find out the starter was shot. bought a new starter and it worked for about 3 start ups then the relay started clicking again. all connections are tight the battery is fully charged. with the starter out of the motor wheni start it the starter turns slowly while the relay is clicking im stumped and my yamaha dealer wont help . they just want me to bring it in. any ideas?
  13. Sep 30, 2011 at 6:35 PM
    98tacoma27
    Ben
    Not Beech Creek
    Could be bad contacts on the relay. Do you have access to a volt meter?
  14. Sep 30, 2011 at 8:45 PM
    IndianTaco
    yes i do! i have a friend whos a electrician
  15. Sep 30, 2011 at 9:06 PM
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS, 2017 LAND CRUISER
    Really sounds like a loose ground, especially since you replaced the starter. Is there a low oil cut-off?
  16. Sep 30, 2011 at 9:16 PM
    IndianTaco
    the oil level is fine. i pulled the belt cover and the motor still turns over by hand. im just stumped. checked damn near everything i can think of and im still left scrachting my head:confused:
  17. Sep 30, 2011 at 9:26 PM
    jivewalker
    Jack MeHoff
    Chucktown
    Maybe check the kill switch position and function, all fuses and try putting in gear and taking it out again. Good luck. Will be interested to see what it ends up being.
  18. Oct 8, 2011 at 1:32 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    check to see if kill switch is groundin out.
  19. Oct 8, 2011 at 1:38 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    mmm. i don’t what to tell you. but i will ask...... dose it have gas?? and is the gas turned on? lol i know thats a dumb ass question but i have sone that before.
  20. Oct 8, 2011 at 1:40 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    also call you’r locale dealer. they can most likely give you some info on what it will be over the phone.
