Yard work and safe chain usage?
Discussion in 'Off-Roading & Trails' started by MattN03, Nov 1, 2009.
  1. Nov 1, 2009 at 6:37 PM
    MattN03
    MattN03 [OP] Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    I wasn't sure where to post this topic, but figured many of the off-roaders would have good suggestions for my question. Mods, please move to appropriate area if necessary.
    I have been cleaning up our property and have cut down a few dead trees that are too close to our house. Recently, I cut down a 50' x 15" diameter oak. After cutting it down, I hooked up a logging chain to my Warn d-ring shackles and used the truck to pull the tree to more convenient location to finish cutting it up for firewood. I had the truck in 4lo/1st gear and other then slightly squatting when beginning the pull, the truck had no trouble moving the tree 100' further down the yard.
    However, this got me thinking-what if the chain was to break? I've read some horror stories on this site about chains going through the back glass and killing the driver. Should I reconsider using a logging chain for this or will putting a heavy coat over the chain work like when a winch is used? Would a strap be safer? Any safety suggestions when putting my truck to use like this? Obviously, there are no bystanders nearby when I'm doing this BTW.
  2. Nov 1, 2009 at 6:50 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    If you have a good quality chain and are using it as stated with no tugging or snatching, you will be just fine. Hell, I have yanked on another truck with a chain and gave it hell and it didn't break. Use it for the working loads it was made for and don't jerk the dog piss out of it and you won't break a chain.
  3. Nov 1, 2009 at 6:53 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I'm not qualified to answer this because I have no experience with it. BUT, if I was hauling something like that, I would hang something over the chain to help diffuse the recoil if it broke. You could use a towel or blanket.
    A longer chain would be a good idea but I don't know how long.
  4. Nov 1, 2009 at 6:53 PM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    X2 but i have seen a few truck with caved in tailgates from chains but a good tow strap can do the same thing but its not as heavy :D
  5. Nov 1, 2009 at 6:55 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    I have pulled out multiple stumps using a chain just be sure to have someone watching from a safe angle to see if the chain is over working.
  6. Nov 1, 2009 at 7:07 PM
    Foster9091
    Foster9091 Well-Known Member
    Upperco, MD
    01 Doublecab TRD
    deckplate mod, floor mats, hi lift, scanquage, and 2 in front leveling kit
    i have seen a chain break and it was a massive 4 wheel drive tractor pulling another pretty big tractor out of a swamp. we had trucks and another decent sized tractor pull on this thing and couldnt get it so we had to get a farmer down the road to come get it. and this chain was just an average one meant for trucks not this kind of hp. youll be fine just pulling a log. that isnt that much weight compared to trucks and stuff. but for the future if you think you are stressing the chain too much put a nice heave jacket or some similar over it to dampen it if it were to break.
  7. Nov 4, 2009 at 3:12 PM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    A static load is where chains come in handy. If you were snatching or getting a running start I wouldn't even consider it. Recovery straps are a good thing to have regardless for various situations.
    Even for simple recoverys, like pulling Burgman out of 6 inches of slop because he was silly and didn't buy a truck with a front differential or pulling the same truck onto the road because he got buried in the sand on the shoulder (*ZING*), exercise caution and good safety techniques. The consequences are to big for what could have been prevented by a little extra effort.
    FYI, we were doing some trail maintenance and a tree had fallen over the trail at one point. A little work with an e-tool and we were halfway through the trunk, a snatch strap and 4 Lo and the top half of that tree was on its way down the trail to a clearing. These trucks can do work.
  8. Nov 4, 2009 at 3:24 PM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    It doesn't hurt to have a jacket/blanket over the chain even if working within it's rated load. Another thing to do would be to put a wooden board over the back window, just in case it does break.
  9. Nov 4, 2009 at 3:35 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    when using a chain as you described for pulling, NOT YANKING, it should hold up just fine. this is considering you are using a chain that is large enough in diameter to handle the load. the biggest concern when pulling a log is the chain slipping off the end not breaking.
    i've witnessed both a chain and a tow strap break when under loads, the jacket idea is good for a strap but would most likely do very little to a chain that breaks under tension. just always remember that a chain is designed for a static load (steady continual pull) not jerking or yanking on it...
    another thing to remember is if using hooks always insert the hook from the bottom so the open side is up. this way is the hook stretches open and fails it will be directed down into the ground versus slinging up in an arc.....
  10. Nov 4, 2009 at 3:58 PM
    sportnobadges
    sportnobadges Well-Known Member
    the great midwest
    '09 TRD SPORT SR5 4.0L V-6 TOW PKG DEBAGED
    de-badged / weather tech digital floor mats front and rear / weather tech in-channel vent visors / A.R.E. MX cap / bed mat / blacked out 4s
    could someone explain to me how the chain knows that it has a jacket, rug, blanket, or towel on it when it snaps and re-coils in any direction it sees fit?
    i agree that any properly sized chain used in a static pull and not a "clean and
    jerk" situation would preform reliably. as mentioned before, i would be more concerned with the chain slipping off the load if it is not properly hitched and causing damage than a chain of proper size and in good condition breaking under a static load.
    just my 2 cents
  11. Nov 4, 2009 at 4:01 PM
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    The weight on top of the chain/strap/winch cable/shoe lace/etc directs the recoiling chain/strap/winch cable/shoe lace/etc into the dirt instead of "in any direction it sees fit." Recovery 101.
  12. Nov 4, 2009 at 4:02 PM
    Afwrestler1986
    Johnstown, NY
    the jacket or blanket works as a sort of harmonic dampener. Basically takes a good bit of the kinetic energy and disperses it into the jacket or blanket. or something like that, all i need to know is that it helps a lot.
  13. Nov 4, 2009 at 4:03 PM
    Fire931
    VA
    00 4Runner
    i totally agree with what your saying luni on that... however it will be way more effective with a strap or winch cable compared to a chain.. the weight of the chain is what will cause it to be less effective... you would have to apply alot more weight than you would to a winch cable...
  14. Nov 4, 2009 at 4:09 PM
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Fire, agree 100%. But we're dangerously close to getting into a physics discussion, and I bagged out of physics class early on a regular basis cause it was on Friday nights and I was taggin a chick in the next state :thumbsup:
  15. Nov 4, 2009 at 4:22 PM
    Fire931
    VA
    00 4Runner
    blah... as soon as you start up a big discussion i'm gonna have to log off for the night :D i've done enough thinking for one day! haha
    i just remember seeing a chain pull off a log and sling straight up and over my uncles truck and smash down across the roof, windshield, and hood and i know a simple jacket wouldnt have done much good... now a bag with a spare chain in it for weight would have done a wonderful job of preventing that....
  16. Nov 4, 2009 at 4:39 PM
    MattN03
    Bluegrass State
    Thanks for all the suggestions and experiences everyone. Fire931, I really appreciate this tip as I never thought of this scenery. I'll be hooking up the chain to the D-ring like this in the future.
    In general, everyone seems to agree that as long as I'm doing pull (within the chains working load limit) and not yanking, I should be good. I've got a couple large trees being taken down professionally this Saturday, so it looks like the Tacoma will be doing quite a bit more work since I'm doing the clean up once the pros drop the trees on the ground.
  17. Nov 5, 2009 at 6:09 AM
    petersharp
    Louisville, CO
    That would work well, and the advatage of using a chain os that you can attach soemthing easily to the midpoint of the chain.
    It would also be easy to attach a strap to the midpoint of the chain then attach the other end to the log. That way if teh chain snaps the strap will 'catch' it.
  18. Nov 5, 2009 at 8:19 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    i've pulled many, many trees out of our woods using a 5/16 grade 43 chain. they are hooked to a 3800lb tractor with front wieght, and i can stand it up without breaking the chain. i have managed to break one of the chains before with a small dozer and a pretty good size log. when it broke, it simply fell to the ground, no whipping, no slapping off the back of the dozer or any real drama. just make sure your attachment points, and the hooks you are using are rated as high, or higher than the chain. when the attachment point has breakage, is when you will run into trouble. cables, nylon straps and ropes are more dangerous IMO as they tend to have a shackle or hook attached that becomes a projectile when the attachment point lets go or the part of the hook breaks. a wire line can store a tremendous amount of energy that is released when there is breakage. chain does not stretch, therefore cannot "store" kinetic energy like nylon or wire rope.
  19. Nov 5, 2009 at 8:23 AM
    Agent475
    Agent475 "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    You could always use a come-along IF the situation permits
  20. Nov 5, 2009 at 9:08 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Here is my very scientific view (but not from experience) that I have learned over my last two semesters in statics and deforms classes. A chain should not recoil if you are in a static situation since its elastic potential energy does not increase barely at all (as in the chain stretches at the molecular level, but barely at all). The way the strain and stresses are distributed in a chain would not cause it to rebound with much force.
    However if using a chain to yank, the story chances. Furthermore with a Recovery Strap, even static situation are extremely dangerous if it breaks. Since a recovery strap in in an much more elastic state, the potential energy increases by the SQUARE of the distance the strap is stretched. That is also the reason they work more effectively, however they are very dangerous if they do break.
    Sorry for the physics discussion :D
