Yay, finally bought a new 2012
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Squirrellydw, Feb 25, 2012.
  1. Feb 25, 2012 at 8:41 AM
    Squirrellydw
    Squirrellydw [OP] Well-Known Member
    2012 PreRunner TRD Sport
    After about a year of wanting one I finally bought a new silver 2012 Pre Runner DCSB with the TRD Sport Extra Package. I wanted grey but they couldn't find any, I should have it on Tuesday. Couple questions.
    1. How many USB ports are there, I forget?
    2. Will the USB port charge an iPhone?
    3. If I wanted to hardwire this iPhone charger, what is the easiset way?
    http://www.proclipusa.com/?sectionp...older=false&have_mount=true&p_pageid=1&dtype=
    thanks
  2. Feb 25, 2012 at 8:43 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  3. Feb 25, 2012 at 8:56 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    There is one USB plug, not sure if it has charging capabilities. Never plugged anything into mine yet :boink:
    As far as hard wiring, probably can just tap into your 12v outlet wiring.
  4. Feb 25, 2012 at 8:57 AM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
  5. Feb 25, 2012 at 9:01 AM
    Derpy Derek
    Derpy Derek Well-Known Member
    Derek
    Brookings, OR
    2012 TRD Sport 4x4 DCSB
    ARB Bumper, Smittybilt X20, King suspension
    The USB port charges your iPhone.
  6. Feb 25, 2012 at 9:07 AM
    Sport11
    Sport11 Well-Known Member
    Kingsport, TN
    Dodge Ram 1500
  7. Feb 25, 2012 at 10:28 AM
    Squirrellydw
    Is there a write up anywhere on how to do it? Searched but did really find much but could be me.
  8. Feb 25, 2012 at 11:04 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Should be a pretty simple, straight forward job, just pop the panel off and splice two wires...I'll do a search and try to find something similar for you.
  9. Feb 25, 2012 at 12:30 PM
    Squirrellydw
    Yeah I did something similar with a Ford Escape I had years ago. Just not sure about how to pop the panel off. Does it matter what wire I tap off of (positive, negative thing)?
    SPORT11 I will have pics when I get it, should be posted Wednesday
  10. Feb 25, 2012 at 4:17 PM
    SLOJAM
    SLOJAM Well-Known Member
    pics please
  11. Feb 25, 2012 at 6:06 PM
    sherlock
    sherlock Well-Known Member
  12. Feb 25, 2012 at 6:35 PM
    OverRated
    OverRated Well-Known Member
    David
    San Jose, CA
    12 Tacoma / TRD-OR / DCSB
    theres 1 usb port and it charges iphones. not sure about your last question though.
  13. Feb 26, 2012 at 4:58 AM
    Squirrellydw
    This is a great idea but how do I know what circuit to use?
  14. Feb 26, 2012 at 8:16 AM
    sherlock
    Well, when you pull the plastic cover off the fuse panel look at the backside of it. It should be stamped on there exactly which fuse is which. (Should be mentioned in the owner's manual also) You will probably find that you have a vacant, switched circuit(s) with no fuse it it presently that you can use. If not look for a 10amp fuse that is switched. I do not have a 2012 Tacoma so can not tell you which circuit is switched, etc.. Hopefully, someone here will provide that info to you. You could just trial and error it as you can cause no harm trying different circuits until you get one that is switched. You might look for a circuit labeled Radio, Gauge or WSH (washer) as they are switched circuits. Again, I'm sure there are vacant switched circuits avail. in the fuse panel you could use. These vacant/unused circuits are there for accessories/options that your vehicle does not have..
    Installing your add-a-circuit is as simple as removing your fuse, installing a spare fuse of the same rating in the lower spot of the add-a-circuit, installing the fuse for your add on in the upper spot of the add-a-circuit. You then will insert the whole add-a-circuit assembly into the fuse block.
    So, with your install, you get the switched power from your add a circuit and your other wire from your charger, you ground by attaching to an available bolt/screw in the general vicinity of the fuse panel.
  15. Feb 26, 2012 at 8:22 AM
    Squirrellydw
    thanks, I think I understand now.
  16. Feb 29, 2012 at 5:01 PM
    Squirrellydw
    Here it is
  17. May 16, 2012 at 8:46 AM
    pstokes
    pstokes New Member
    Eads TN
    2011 Tacoma PreRunner
    Step Rails, Tonneau Cover, Bed Step
    The 2011 has the ATM Mini low profile fuses and I tried a ATM bladed fuse in place of the factory fuse, I used the same amperage and it failed to complete the circuit. The add a circuit indicated in your picture says it for the ATM fuse but no where can I find if it'll work with both the ATM bladed and low profile. Has any one used this to replace the ATM low profile fuse?
  18. May 16, 2012 at 9:00 AM
    dejesusr
    dejesusr Member
    Raul
    Newport News VA
    My new truck
    Sweet! I got one recently as well!
  19. May 17, 2012 at 11:24 AM
    pstokes
    pstokes New Member
    Eads TN
    Found just what I needed at Waytek.com. Search for ITEM # 46068. There is also a data sheet that can be downloaded and cost ia less than 5 bucks.
  20. Jun 5, 2012 at 7:53 PM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    TW rocks! I'm looking at hardwiring my Escort 9500ix fuzz buster tomorrow in my new 12 Offroad Access and thought I'd look for dash removal pics and came across this post. I didn't know they made such a thing but the fuse tap is just what I need! I had installed it in my previous Tundra and always had ground issues. Will post pics soon. Thanks guys.
