Yellow Airbag Plug??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma07ras, Mar 11, 2015.
  1. Mar 11, 2015 at 1:54 AM
    Tacoma07ras
    Tacoma07ras [OP] Active Member
    I am No One!
    OC, CA
    2010 Tacoma
    Texas Edition
    Hello, can someone tell me what is this yellow airbag wire plugs into?
    After opening up the dashboard, I noticed this plug is not connecting to anything.
    Thank you for your help.
  2. Mar 11, 2015 at 2:55 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That should go to the Disable key switch for the passenger side air bag. The key switch should be under the air register to the right of the stereo. See the picture below.
  3. Mar 11, 2015 at 3:47 AM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    not all tacos have the key
  4. Mar 11, 2015 at 3:53 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    If you have a double cab, there most likely is no air bag disable switch, and the trim there will be blank.
  5. Mar 11, 2015 at 3:58 AM
    TOLLAV
    TOLLAV Wait, I have to drive ON the road??????
    Louisiana
    14 TRD Sport
    If you remove one more panel you can see the unicorn that is inside the engine bay. Ha
    I remember having to almost do that to my dash. but the 2 above are right. Toyota and most manufactures for that matter will have one harness and have all the unused connections just tucked away its great if you just have a base model. its just cheaper to design one harness than a bunch of custom ones
  6. Mar 11, 2015 at 9:07 AM
    Tacoma07ras
    I am No One!
    OC, CA
    2010 Tacoma
    Texas Edition
    Thank you all....my tacoma is a base model, so I do not have the Disable Switch. That's why the plug is hanging behind the dashboard......
