Yellow flakes in oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rhetto, Jan 1, 2017.
  1. Jan 1, 2017 at 9:36 PM
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    Yeah from my experience bearing material is almost like a shade of copper shavings, that's too yellow...
  2. Jan 2, 2017 at 1:01 AM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    And here we have the OP displaying the contents of his oil pan. :rolleyes:
    Torspd, Midnighttaco08 and BrokenMech like this.
  3. Jan 2, 2017 at 8:23 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    As mentioned above do a Blackstone oil test and feel better.
    Clearwater Bill likes this.
  4. Jan 2, 2017 at 8:34 AM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    chain guides are black or a brownish color
    Torspd likes this.
  5. Jan 2, 2017 at 8:41 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Looks like wataburger! :eek:
  6. Jan 2, 2017 at 8:41 AM
    Pigpen
    Dan
    Northwest Montana
    Any chance is condensation from not running the engine hot enough? Like the sludge that can show up on the oil cap? Just a thought.
  7. Jan 2, 2017 at 8:46 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    take a magnet to it. I wouldn't think bad bearings would turn yellow.
    Torspd likes this.
  8. Jan 2, 2017 at 9:00 AM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    This is my though as well. Almost like a varnish you'd find in a carburetor. Could have flaked off the upper part of the oil pan when draining? As others mentioned, oil analysis would answer all of your questions. Lots of options out there. LEAP and Horizon are ones that I've used in the past.
  9. Jan 2, 2017 at 9:04 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Maybe some excess "Form-A-Gasket" material from a previous owner?
  10. Jan 2, 2017 at 9:57 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yup.
    Like he said. Take a magnet to the particles.
    All flakes of this engine's oem bearings will be silver.
    My bet, if it is doesn't stick to the magnet, is that those pieces are from the silicone used during assembly. After the grey silicone that Toyota uses, has aged, then it becomes brittle and changes to a slight yellow/grey color. Unlike their black silicone.
  11. Jan 2, 2017 at 10:20 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The truck that laid the golden oil...
    o0oSHADOWo0o likes this.
  12. Jan 2, 2017 at 10:28 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Was that from the engine? Maybe just the picture but the oil itself looks really bad, like it may have coolant mixed in it.
  13. Feb 7, 2017 at 1:21 PM
    rhetto
    rhetto [OP] Well-Known Member
    Rhett
    Austin, TX
    2010 TRD Off Road
    Ended up getting a report from Blackstone Labs. I'm even more confident that the yellow flakes were not bearing material now - but I'm still not sure exactly what they were.
    Anyway, wanted to leave this here for anyone else who might stumble on this thread with the same issue.
  14. Feb 7, 2017 at 1:23 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Do this. If you have the oil keep it and take a sample if not change it again and get a sample.
  15. Feb 7, 2017 at 1:23 PM
    #35
    rhetto
    Rhett
    Austin, TX
    2010 TRD Off Road
    lol
    farnorth01 likes this.
  16. Feb 7, 2017 at 1:24 PM
    #36
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Never done this and not sure exactly how to interpret data, but it looks like your iron content is high no? Yours being 108 vs national average of 11.....I still think it looks like gasket material
  17. Feb 7, 2017 at 1:26 PM
    #37
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    So close!
    rhetto[OP] likes this.
  18. Feb 7, 2017 at 1:26 PM
    #38
    rhetto
    Rhett
    Austin, TX
    2010 TRD Off Road
    Yeah, it is high. They speculated that the yellow flakes could be silicon (which is also high) and could have contributed to more wear on steel parts. They suggest changing the oil again after 2,000 and sending in another sample. I'll likely do that.
    excorcist[QUOTED] likes this.
  19. Feb 7, 2017 at 1:27 PM
    #39
    excorcist
    Reno, NV
    Interesting, thanks for the follow up.
  20. Feb 7, 2017 at 1:28 PM
    #40
    Toyko Joe
    Toyko Joe Here for the pictures
    By chance has someone used radiator sealer on your truck?
