yellow foglights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pannell_Trd, Dec 10, 2010.
  1. Dec 10, 2010 at 5:47 PM
    Pannell_Trd
    Pannell_Trd [OP] Well-Known Member
    Tyler
    Georgia
    2009 Prerunner Double Cab Trd Sport
    Yellow foglights 20% tint
    Where can i get the yellow foglights? id like to get the yellow bulbs and lense
  2. Dec 10, 2010 at 5:50 PM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
  3. Dec 10, 2010 at 6:05 PM
    Pannell_Trd
    Tyler
    Georgia
    whats a good brand to get? and should i run the lamin-x's to?
  4. Dec 10, 2010 at 6:10 PM
    BIG MoFukin SERG
    BIG MoFukin SERG Well-Known Member
    Serg
    Los Angeles
    '09 MGM TRD Off Road
    5100's set at 2.5", Blacked-out badges, CB, Drop-in K&N
    Do you have fogs already and just want them to be yellow?
  5. Dec 10, 2010 at 6:11 PM
    RCBS
    Appalachia
    06 Main Runner OR
    sorry, no personal experience...maybe someone else will chime in. i'm still running stock.
  6. Dec 10, 2010 at 7:36 PM
    DOT
    DOT Well-Known Member
    Jobin
    Littleton CO
    2007 FJ
    3'' toytec lift
    I also was wondering about what bulbs to put into just the stock fog lights ?
  7. Dec 10, 2010 at 8:06 PM
    BIG MoFukin SERG
    Serg
    Los Angeles
  8. Dec 10, 2010 at 8:17 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    a relatively affordable VERY yellow h10 bulb is by Nokya, http://www.google.com/products/cata...og_result&ct=result&resnum=3&ved=0CDEQ8wIwAg#
    also, the Optilux (by Hella) XY bulb is comparable to the Nokya, but not as yellow, http://www.google.com/products/cata...=X&ei=D_sCTfqcE4P88AadpciEBQ&ved=0CDoQgggwAA#
    with those bulbs, esp the Nokya, you don't really need the yellow lamin-x. the lamin-x will make it 1. look yellow with the light off and in the day time, 2. protect the lens and 3. enhance the yellow bulb...
    however, i'm not really into the "yellow when off" look so i'll probably run the Optilux bulbs and the lamin-x 40 mil clear covers to offer max protection. i simply want amber/yellowish fogs for the function, not necessarily the look.
  9. Dec 11, 2010 at 6:08 AM
    sooner02r1
    sooner02r1 Well-Known Member
    Get 3000k HID headlights from DDMtuning.com, just got mine for $40 shipped, bright as crap, plug and play. Super happy with this purchase.
  10. Dec 12, 2010 at 8:55 AM
    Pannell_Trd
    Tyler
    Georgia
    i have foglights and i want them yellow and brighter
  11. Dec 12, 2010 at 9:09 AM
    joe812
    joe812 Well-Known Member
    Joe
    NJ
    ARE LSII Cover w/ BedRug, CravenSpeed Shorty Antenna, Husky Liners, Wet Okole Seat Covers, OEM Tube Steps, Bilstein 5100 set @ 1.75 with rear leaf TSB.
    I installed the yellow Nokya bulbs. Less than 20 bucks on Amazon. They work great. I had the damn'd time trying to get them to seat properly till I figured out the rubber gasket/ring on the bulb was way bigger than the stock bulb. I swapped them out and it fit perfect. My suggestion is to try the bulbs first. You might be able to save some coin and it would be easy to go back to white bulbs if you don't like it.
  12. Dec 12, 2010 at 9:16 AM
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    To get the yellow tint, go to a Michaels and get the Krylon satin finish in orange. Give the fogs about 4 coats and you will get the yellow fogs for about 6 bucks.
  13. Dec 15, 2010 at 1:23 PM
    Grande
    Grande Well-Known Member
    Victorville, CA
    Thomas, The little truck that could
    Painted badges. Bedlined grille, wheels and lower valence. Billies 5100 @.85 up front. Dodger Jack Ball Mod. Custom trail damaged rear bumper (for the time being). Lil LED light bar on grill. Hard-wired Radar Det. Custom Projector fog lights, Anytime Fog Mod, HIDS, White LED accent lighting on a Single post double toggle swicht, so they light up wit my door/dome light, or always on, or never on. LED map and dome lights.
    is that what u did, looks good from ur sig
  14. Dec 15, 2010 at 1:29 PM
    TacoMal
    TacoMal Well-Known Member
    California
    09 TRD Off Road Dbl cab
    Wet Okole's, Relentless Sliders, Plasti Dipped badges and wheels
    This may be a dumb question but, why do you get the yellow fog lights? For looks? Functionality? Both?
  15. Dec 15, 2010 at 3:05 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    amber light is supposedly easier on the eyes and technically is ideal for poor weather.
    one of the reasons why euro cars for so long had amber forward lighting and/or fogs - in fact some had yellow head lights, not just fogs.
    but yeah, i'm sure many people use it for a certain look too.
  16. Dec 15, 2010 at 4:04 PM
    Nightstr
    Felipe
    Sacramento CA
    05 prerunner sr5
    Thanks, yes that is what I did. My friend has the lamin x and mine give out a better brighter light. We have thick fog here and I can totally tell the difference.
  17. Dec 15, 2010 at 10:00 PM
    cdikkers
    cdikkers Minimum Wage!
    Casey
    New Berlin, IL
    Speedway Blue '05 PreRunner
    I have just spent the past hour in the garage kicking and screaming while trying to install a set of Nokyas. After finally giving up, I come in and search here to see if I am just missing something. I read this, I swap gaskets, and it went right in. Amazing that little piece of rubber made all the difference. So thankyou for posting that. Now unfortanutly I'll probably have to go through it all again in the not-so-distant future because I'm sure I got the bulb nice and dirty. Even though I cleaned it with rubbing alcohol I'm sure it's still not going to last...
  18. Dec 15, 2010 at 10:06 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    i think johnnie cochran once said, "if there is any doubt, take 'em out"
    spin them in a paper towel soaked with isopropyl again, and do it now, because that would suck if they blew due to that. you don't want any of those oils or grime baking on and causing a hot spot. it happens fast.
  19. Dec 15, 2010 at 10:16 PM
    cdikkers
    Casey
    New Berlin, IL
    It's to late, I noticed a dark spot that wasn't coming off with cleaning. I made the mistake of turning them on just to make sure they were working (would have been pissed if I went to all that trouble and one was defective from the getgo) and it would appear I hosed myself...Failure! :boom:
  20. Dec 15, 2010 at 10:32 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    hmm...
    PM'd
