Yellow light things? Where the blinkers are?
Discussion in 'Lighting' started by RJALLDAY702, Sep 13, 2011.
  1. Feb 15, 2012 at 7:35 AM
    REDTRD
    REDTRD Woods & Water Edition
    Anthony
    Western NC
    07 DCSB SR5 4x4
    Click my build thread!
    Looks Good! Do your DTRL still blink normal when you use your turn signals.
  2. Feb 15, 2012 at 7:38 AM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    You've probably got a short in the circuit. Don't increase fuse size, as you might burn something up.
  3. Feb 15, 2012 at 7:38 AM
    cverneau
    cverneau Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    If I had to guess, you most likely either tapped into the wrong wire from the blinker or tapped into the wrong wire on the side marker.
  4. Feb 15, 2012 at 9:37 AM
    cverneau
    Craig
    Cheshire, CT.
    I think I might have it figured out. You said you tapped into the wire on the side marker for the blinker mod. That's incorrect - you need to totally cut the original wire (tape the cut end and stuff it into the wire loom) on the side marker and connect it to the tapped wire from the DTRL turn signal. Now you would be sending the blinker signal to the corner lights instead of trying to share that signal with the original wire.
  5. Feb 15, 2012 at 10:26 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    check you thread from last night...
  6. Mar 25, 2012 at 4:10 PM
    Taco zilla
    Taco zilla Member
    Shane
    South Carolina
    2011 Tacoma 4x4
    20x12 Fuel Hostage's with 33x13.00 super swamper iroks. 6" Fabtech susp lift. Borla exhaust 5% window tint. 4wd luminated switch
    My 2011 stays on, & im trying to find out to disable them. They're my front blinkers & thats all I want to use them for. Any ideas?
