Yellow slime on oil cap and neck...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Veccster, Feb 24, 2013.
  1. Feb 24, 2013 at 12:51 PM
    Veccster
    Veccster [OP] bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    While changing my oil this afternoon, I found the underside of my oil cap and the fill neck covered in a yellow slime. I was immediately worried about a blown gasket or leak somewhere in my engine. But after further research, I found that it's common for vehicles in the winter that drive mostly short distances. Apparently, condensation forms at neck and cap but the oil or metal up there doesn't get hot enough to burn off the moisture.
    Anyway, I wiped it off and continued.
    I live in western pa and mostly drive 4mi to work and back each day. I need to get it out and running more often I guess. I use it every day but only put on 4,000 miles in 8 months.
    The oil from the reservoir looked fine.
    Any other suggestions?
  2. Feb 24, 2013 at 12:52 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Probably just condensation and such.
  3. Feb 24, 2013 at 12:54 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    It's sludge. Happens durning colder weather and short trips because the engine doesn't heat up enough to burn the water/condensation off...
  4. Feb 24, 2013 at 1:48 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    change and inspect oil to be sure. thats more than i am used to seeing
  5. Feb 24, 2013 at 1:49 PM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    If it is that bad, you probably have either a cracked head or a bad head gasket. Mine wasn't even that bad and the head was cracked...
  6. Feb 24, 2013 at 1:50 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Take a longer drive once a week to give her time to get good and warm to burn the condensation off. If you are really concerned about your head gasket, take an oil sample and send it in to get checked.
  7. Feb 24, 2013 at 1:59 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    It's normal, mine does the same thing.
  8. Feb 24, 2013 at 2:07 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    Longer drives. Short run cycles are hard on your engine. Ive seen that sludge on lots of 4runners/2nd gen tacos, it's normal.
  9. Feb 24, 2013 at 2:10 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    It's normal especially with the colder weather we have been getting lately. This is more common with these plastic oil tubes compared to the aluminum ones which can warm up faster.
  10. Feb 24, 2013 at 2:10 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Good reason to conclude it has nothing to do with a cracked head or bad gasket.
    No big deal, search "oil cap", this topic comes up every week.
    Edit: I did the search and it comes up almost every day, sometimes more than once a day.
  11. Feb 24, 2013 at 2:13 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i got the shorter tube that is for the 5.7L tundra and i almost never get the slime anymore. the FJ 4.0 gets an aluminum filler tube also
  12. Feb 24, 2013 at 2:45 PM
    Ryandoobs
    Ryandoobs Active Member
    Dallas
    Prerunner
    I was concerned about this because shortly after buying my '07 i noticed sludge. I wiped the cap and changed the oil. Since then i haven't had anymore milky yellow stuff!!
  13. Feb 24, 2013 at 2:48 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Don't worry about it OP. Do you drive a lot of short trips? If I do a lot of highway, I don't get that. If I do a lot of short trips, I do get some moisture under the oil cap like that.
  14. Feb 24, 2013 at 5:44 PM
    MrTacoma
    MrTacoma Well-Known Member
    Tacoma Base v6
    None
    Yeah I see that all the time when i opened up the cap to put the oil in when i do service on the truck...I do run a lot of short trips especially as a volunteer firefighter..that explains why its doing it..since ive never had an issue with the engine im assuming its not that big of a deal..i ussally wipe it off before new oil goes in...
  15. Feb 24, 2013 at 6:15 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Seems like a lot to me? But it does happen in the winter.
  16. Mar 1, 2013 at 11:43 AM
    92dlxman
    Kevin
    Visalia, CA
    why not just change the oil to be sure? better safe than sorry kindof thing. if mine looked like that i would sh*t
  17. Mar 1, 2013 at 12:48 PM
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    First time I saw that was on my motorcycle. I posted on the ducati forum and people said the same thing about condensation.
    I changed my oil with Mobil-1 full synthetic and the filter, and I do see it on short rides where I dont let it get up to full operating temperature for a while (like going to the store or somewhere close), but it is drastically reduced since when I got the bike used from the guy before. All due to new oil (and probably removing water that was in there I suppose).
  18. Mar 1, 2013 at 1:07 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    It might be normal for short trips but I sure would not want that shit in my engine. I would start with an oil/filter change and maybe take longer trips more often even if it means driving around just wasteing gas. Hows the PCV?
  19. Mar 1, 2013 at 1:17 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    situation normal
  20. Nov 8, 2013 at 6:44 AM
    CBiscuit14
    CBiscuit14 Professional Lurker
    South Dakota
    08 DC TRD Sport 4X4
    Went to do my first oil change since buying my truck. Opened up the oil cap and about :eek: my pants. Fortunately I thought quick on my feet and checked TW! It makes sense too since a little water in oil will make it turn a milky color.
