Yellow wire mod or what the heck is happening?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bikinaz, Nov 12, 2018.
  1. Nov 12, 2018 at 1:00 PM
    Bikinaz
    Bikinaz [OP] It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    OK, what did the previous owner do to this 2014 truck? He installed a little on off switch in one of the plug holes on the dash. I’ve switched it off and on a couple times but couldn’t figure out what it was for. Finally, yesterday I took it out off-road for just a little cruise and I noticed that the 4lo light was blinking but there was no warning buzzer and the transfer case did engage 4lo. I thought it felt like the front axle was not engaged but I wasn’t entirely sure. I will also add in 4hi the front tires did slip on sharp corners so I know the front axle does in fact engage in 4hi. I did notice that the rear tires slipped a lot when I was turning sharp in 4lo, but it didn’t seem like the fronts did. After thinking about it I thought maybe he did the YWM.
    Fast forward to today and I thought maybe I’d look behind the glove box and see if I could figure out if this had the YWM. When I got the glove box out I saw two wires leading over toward that area, so I thought he set it up to turn on and odd via the dash…sounds sweet so far. So yesterday the switch was on because that’s where I left it last time I messed with it. Now I’m thinking I’m good to go, except of course I’ve heard the mod does not work on the 2014s. I jump in the truck switch it into 4 low and the 4lo light still blinks. I then turn off the little dash switch and the trac control, and vsc light both light up and the 4lo stops blinking and holds steady.
    Does anybody have any insight as to what I’ve got going on here?
  2. Nov 12, 2018 at 2:11 PM
    Shearboy2005
    Shearboy2005 It can't stay tight if it's a liquid.
    Ky
    2015 TRD SPORT, 06 PreRunner
  3. Nov 12, 2018 at 2:14 PM
    Nunya Bizness
    That is odd... I have no idea..
    tcjacado likes this.
  4. Nov 12, 2018 at 4:04 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Doesn’t sound quite like mine but maybe a DIY version of 2lo mod
  5. Nov 12, 2018 at 4:59 PM
    Bikinaz
    Hey You!
    Phoenix, AZ
    Maybe I need to get one more set of jack stands and see what happens. I'm just excited to finally figure out that the switch does something. :)
  6. Nov 15, 2018 at 7:44 PM
    Bikinaz
    Hey You!
    Phoenix, AZ
    One more question. Is there some kind of advantage of having the trac and vsc lights lite up while off-roading in 4lo? I haven't put her up on jack stands yet, but I'm pretty sure the front axle is engaged when the dash switch is on and the trac and vsc lights are lite by this switch.
    TXpro4X4 likes this.
  7. Nov 15, 2018 at 7:47 PM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Maybe call the previous owner and ask him? That’s what I’d do.
  8. Nov 15, 2018 at 7:52 PM
    Bikinaz
    Hey You!
    Phoenix, AZ
    I'm the 3rd owner and the second owner bought it as a certified pre owned from a dealership. The second owner was NOT a truck guy and knew nothing about the regular cabs. He thought the truck was pretty much stock except for the tires. :)
    WBF610[QUOTED] likes this.
  9. Nov 15, 2018 at 7:58 PM
    WBF610
    Carey
    Eastern PA
    2016 DC OR
    Well, never mind then.....
    Bikinaz[QUOTED][OP] likes this.
  10. Nov 15, 2018 at 8:03 PM
    Bikinaz
    Hey You!
    Phoenix, AZ
    It's all good. :)
  11. Nov 15, 2018 at 8:10 PM
    tcjacado
    tcjacado Well-Known Member
  12. Nov 15, 2018 at 8:16 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    @David K
    Cant remember your threads name
  13. Nov 16, 2018 at 3:05 AM
    k8md
    k8md Well-Known Member
    Bob
    2015 Silver TRD Sport
    Can it be "certified" with diy mods like that? Feels like a warranty buster.
    Norton and PzTank like this.
  14. Nov 16, 2018 at 4:33 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
  15. Nov 16, 2018 at 5:13 AM
    96carboard
    96carboard Well-Known Member
    I don't know what "yellow wire mod" means, but what he did, is he added a bypass that prevents the "low range" mode signal from being sent from the 4WD ECU to the SKID CONTROL ECU. This has the effect of allowing the skid control functions to continue operating WHILE the vehicle is in low range, which normally is not permitted.
  16. Nov 16, 2018 at 6:11 AM
    Bikinaz
    Hey You!
    Phoenix, AZ
    So in other words it will limit the throttle and add braking to avoid a spinning wheel in 4lo?
  17. Nov 16, 2018 at 6:16 AM
    96carboard
    No. It will add braking. It won't touch the throttle.
  18. Nov 16, 2018 at 7:44 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Is it the one in my signature links? I have a few!
    My truck is basically stock so my info is not about mods but only about what the stock settings do or how to operate them.
    I do recall from the Yellow Wire Mod posts that the 4LO blinking is normal when the TRAC is on, and of course solid when it is normal without TRAC. Double check my memory.
    TRAC is a limited slip and only available on 2nd Gen in H2 and H4. Before 2012, TRAC in H4 had no engine regulation, only braking for more wheel power. The mod made this available in L4, a benefit for those who did not buy the Off-Road and have A-TRAC.
    TXpro4X4[QUOTED] likes this.
  19. Nov 16, 2018 at 7:46 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    I know. I believe it was the one with all the lsd and traction button control section, where you where talking about holding the button and what not.
  20. Nov 16, 2018 at 8:14 AM
    David K
