Yes, another 2nd Gen Sway Bar question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MattDubs, Jun 25, 2011.
  1. Jun 25, 2011 at 5:06 PM
    MattDubs
    MattDubs [OP] Well-Known Member
    St. Augustine, FL
    6" Procomp
    I know this has been beaten to death, I just did a few searches and nothing I found answered my question.
    Ok let me start by saying: I have a 06' DCLB with a 6" Procomp lift. I bought it from my buddy who was being deployed overseas so I wasn't involved in the lift install, only know that it was done by a local shop. I am trying to remove my sway bar and got to looking at it and looks very easy, minus where it connects to the spindle... This is where I wish I was around so I could have seen how it was connected? Looks like its pressed into the spindle? If so.. how the F do I get it out of there? I can get the 6 bolts off no prob, but then Ill be left with the lower part of the SB still connected to my spindle bouncing around and getting in the way.
    So my question is how do I get that part off of there? And I guess I should ask, I know most who run w/o a SB are also running Coilovers, I am not, just the spacer kit (Pro Comp 6" kit) would this be a bad idea?
    thanks in advance!
  2. Jun 25, 2011 at 5:11 PM
    gtrotter
    gtrotter Well-Known Member
    Interlake, Indiana
    2009 Regular cab 4x4, ARB's, 4.88's, bumpers, 2017 DCSB SR5 stock
    locker,mud tires, lifted, toolbox
    It should unbolt, but I haven't dealt with a 6" lift yet. The big question, though, is are you planning on using it offroad? If not, leave the bar on.
  3. Jun 25, 2011 at 5:14 PM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Dunno how yours is but mine you take the bolt off and hammer it through so it breaks lose haha
    Mine is 90% road but my sway bar hits my coils so its coming off
  4. Jun 25, 2011 at 5:16 PM
    MattDubs
    St. Augustine, FL
    6" Procomp
    I can snap a pic and post it but It doesn't unbolt, at least not from what I can see?
    The Problem is the SB is rubbing REALLLLLY bad on the inside of my tires and cutting a groove. As you can imagine this sketches me out. I plan to change the tires and wheels to something a bit narrower the correct back spacing for the kit but money is tight so for now, this is my best option. Instead of getting spacers Id rather just take it off. I've read the pros and cons of running w and w/o and Id rather take it off.
  5. Jun 25, 2011 at 5:17 PM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Take a pic from front and back mine unbolt if Im not mistaken, running out to double check now
  6. Jun 25, 2011 at 5:24 PM
    n0rth
    n0rth Well-Known Member
    J.W.
    Idaho
    09 Tacoma 4X4 SR5
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    Just loosen the nut leave it on just a couple of threads then hit it with a hammer to break it loose.
    Hopefully a pic is worth a thousand words and helps.
  7. Jun 25, 2011 at 5:27 PM
    MattDubs
    St. Augustine, FL
    6" Procomp
    Ok in the 2nd pic you can see where its rubbing, Lucky me.
  8. Jun 25, 2011 at 5:29 PM
    MattDubs
    St. Augustine, FL
    6" Procomp
    Thanks, thats what I came up with when I looked into this at first but it seems that the Stock spindle has that^ option with the bolt all the way through. My Spindles are the ones that came with the Pro Comp kit and don't seem to have that same set up. I guess because the lower link came with the kit and is different then the stock one?
  9. Jun 25, 2011 at 5:32 PM
    MattDubs
    St. Augustine, FL
    6" Procomp
    ...Unless its behind the brake line bracket in the 3rd pic and Im just not seeing it?
  10. Jun 25, 2011 at 5:37 PM
    n0rth
    J.W.
    Idaho
    09 Tacoma 4X4 SR5
    In that case, it may be that you have to undo the top link and unscrew it from the spindle??? Can you pull your tire off and get a better pic/look at it?
  11. Jun 25, 2011 at 5:39 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    see if you can take off the sway bar relocation deal on the actual lift and see if that works.
  12. Jun 25, 2011 at 5:40 PM
    MattDubs
    St. Augustine, FL
    6" Procomp
    ^^ yeah thats the plan for tomorrow morning. Im over dealing with it tonight.
    I was thinking about taking the sway bar off and getting it out of the way then trying to pry on it to see if it moves but it has to be pressed in or maybe a c clip under the little boot that I am just not seeing..
  13. Jun 25, 2011 at 5:44 PM
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    the sway bar on my truck when i took it off only too 4 bolts.. 2 on the spindle and 2 underneath. one side is an open end and it slides out. i dont know what your problem could be :confused:
  14. Jun 25, 2011 at 5:47 PM
    MattDubs
    St. Augustine, FL
    6" Procomp
    hmmm. yeah mines different than that. I have 4 bolts on the frame in the front where the bushings are, one on the top link on each side, and then this issue at the lower link where it mates with the Pro Comp spindle.
  15. Jun 25, 2011 at 5:48 PM
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    ya the 4 bolts that go onto the frame.. the 2 that were closets to the cab i took off then it slid off the other two towards the bumper.
  16. Jun 25, 2011 at 5:55 PM
    MattDubs
    St. Augustine, FL
    6" Procomp
    lol I just came across this on PC's website :facepalm:
  17. Jun 25, 2011 at 5:56 PM
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    hahahah uh oh.. go fix it :thumbsup:
  18. Jun 25, 2011 at 6:00 PM
    MattDubs
    St. Augustine, FL
    6" Procomp
    haha thanks for the help guys!
    PS. I want your skid! Shocktaco make that?
  19. Jun 25, 2011 at 6:03 PM
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    yes sir :cool:
  20. Jun 25, 2011 at 6:18 PM
    MattDubs
    St. Augustine, FL
    6" Procomp
    Niiiice I asked him about building me one but Florida is a Loooooong ways from Cali. so im sure shipping is gonna be a bitch.
