Yes, Another AAL Question.....
Discussion in '1st Gen. Tacomas (1995-2004)' started by Onyx, Sep 28, 2011.
  1. Sep 28, 2011 at 7:15 PM
    Onyx
    Onyx [OP] New Member
    Seattle
    02 Prerunner Sr5 TRD V6
    So, I bought my first Tacoma last week. 2002 V6 Prerunner TRD SR5 51K. First truck, so either I am overly sensitive to the clunks and bumps but ive been reading that these trucks are know for the notorious "clunk" coming from the rear end. Yes, I seem to have it and its totally annoying!! Looking to get a set a stiff AAL (hopefully this will fix the problem) but was wondering if i need spacers in the front to keep it level...? Any recomendations on a brand? Would rather have a stiff ride than axle wrap.
    Searched through the forums but havent found any mention of adding something to the front. Surely if height is added to the back it wont sit level, correct?
    Thanks!! :D
  2. Sep 28, 2011 at 9:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Your assessment is accurate with the exception of using a lift spacer to compensate. Lift spacers are a cheap solution that you'll likely regret in the long run.
    Assuming your springs, both front and rear, still are in good shape, consider an adjustable shock for the front instead of a spacer. Here is a much better solution.
    http://downsouthmotorsports.com/i-1...acoma-pre-runner-4wd-pre-load-adjustable.html
  3. Sep 28, 2011 at 11:31 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I agree. Just get some 5100s up front to help balance out the lift from the rear. Will be much better then spacers.
  4. Sep 30, 2011 at 10:31 AM
    Onyx
    Seattle
    Thanks, was hoping not to mess with the front but don't think its gonna be an option!
    I was reading that a stiff helper spring would fix the issue as well?
    There isn't any option without lifting the vehicle is there?
  5. Sep 30, 2011 at 10:55 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    The AAL is temporary. I did an AAL and 5100's and got the clunk back after about 1 month and bad after about 3 months.
  6. Sep 30, 2011 at 11:06 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    not really as you need stiffer leafs...which usually means a bit of lift.
    Wheelers 5 pks dont give tons of lift and the 5100s up front on the middle setting should be close to level...well..maybe at the highest setting actually..
