Yes, Another newb with a tire question
Discussion in 'Wheels & Tires' started by LastoftheGen2, Dec 5, 2016.
  1. Dec 5, 2016 at 6:02 PM
    LastoftheGen2
    LastoftheGen2 [OP] Well-Known Member
    Mighty Mo
    NY & Vermont
    2015 Taco TRD Off Road
    Fab 4 Bumper with 9,000LB Winch. Prefy high lift rear bumper, All-Pro rock sliders, steel skids, expedition leaf pack and U-Bolt flip kit, King shocks with 700 lb springs, BFG AT KO2's 265/75, Safari snorkel, rear diff breather mod.
    Hello All, long time red oak hillbilly, first time mechanized.
    And of course I have a tire question.
    Great site, tons of info. I just want to confirm tire size options for the modifications I have done so far. I am new to this so my bad if I missed the answer on other threads.
    I have a 2015 Taco TRD Off Road. Currently making a "road" through the Vermont woods. No deep river rock climbing or high speed sand dunes in my future. Just bouncing off the pines and sinking into the mud.
    I have a 3" all pro lift kit with new leaf packs, UCA's and bilsteins all around. I have heavier springs up front to compensate for the winch and fab 4 bumper. Rock sliders on the side also add weight. The kit is a 3" lift but actually 2.5" up front and 3" in the back. With the weight of the bumper and sliders may be sitting lower, not sure.
    What I think I know,,,,,If I wanted to bump up to 285's I do not need spacers as I have UCA's that will fit but I should do a body mount chop to the frame??
    My questions are,,,
    1) Do I have to do a body mount chop to fit 285's?
    2) Can I strap on 275's as is, and not worry about rubbing?
    3) Are 285's that much better than the 265's that are stock on the truck?
    I am all about utilitarian thought so only looking to upgrade if it is worth it and will make the truck perform better. I would rather keep the original rims.
    Let me know what ya think.
  2. Dec 6, 2016 at 7:45 PM
    LastoftheGen2
    Mighty Mo
    NY & Vermont
    I just realized that I neglected to my original rims are 16" and the tire I was thinking about was a 285/75/16 or 275/70/16.
  3. Dec 6, 2016 at 7:47 PM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    Yes, no, depends
  4. Dec 6, 2016 at 7:51 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    1) if you off-road.
    2) nope
    3) depends
    You also need 4.5" backspacing for 285s.
    Please search gooogle for your question and then add 'tacomaworld' at the end. This has been discussed way many times.
  5. Dec 6, 2016 at 7:53 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    It also doesn't sound like you really need the extra clearance. 265s fit fine and come without hassle.
  6. Dec 7, 2016 at 7:27 AM
    Pigpen
    Dan
    Northwest Montana
    If you want more tire, look at 255/85/16. Most are E rated, but some (like Cooper) have options in lighter load rating. I think it's the perfect do it all size for the Tacoma.
  7. Dec 7, 2016 at 7:04 PM
    LastoftheGen2
    Mighty Mo
    NY & Vermont
    Thanks for the feed back, I would not complain with more ground clearance as there are some streams that I drive through and some steep inclines just not sure if I want to chop the body mount.
    The 255/85's are a tall tire, I am assuming I would have to chop the body mount with them as well?
    I spend 80% time on road but the 20% off road I am carrying a lot of weight in the back and bouncing off the trees I am to lazy to take an ax to.
