Yes another tire pressure question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GOTSAND?18, Mar 11, 2021.
  1. Mar 11, 2021 at 1:06 PM
    GOTSAND?18
    GOTSAND?18 [OP] Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    What are you guys running your tire pressure at ?
    I have tried range from 33-36 psi and find it bouncy on the street .
    Maybe it’s just the characteristic of the stock off road suspension.
  2. Mar 11, 2021 at 2:58 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I run what the door sticker and owners manual say 29 or 30 psi, seems to ride fine.
    Junkhead likes this.
  3. Mar 11, 2021 at 3:03 PM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Anything above what is posted on your placard and lower than the tire maximum. It is up to you.
  4. Mar 11, 2021 at 3:04 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    30psi like the door sticker says
    Junkhead and shakerhood like this.
  5. Mar 11, 2021 at 3:07 PM
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    Put some weight in the bed that usually helps. As for tire pressure, chalk test is the only way you’re going to get the “right” pressure for your circumstances and maximum tire longevity. I agree with Sungod though, anything between the placard and max pressure will work.
  6. Mar 11, 2021 at 3:09 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
