Yes or No on putting lots of money into truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoBlitz, Dec 13, 2010.
Is it worth doing all this to a truck having close to 200k miles?
Poll closed Jan 27, 2011.
  1. Yes
    21.3%
  2. No
    23.6%
  3. Maybe
    22.7%
  4. Hell yes
    22.2%
  5. Hell no
    10.2%
  1. Dec 13, 2010 at 5:44 AM
    TacoBlitz
    TacoBlitz [OP] Well-Known Member
    Jake
    Omaha, Nebraska
    01 DoubleCab SR5 TRD, white
    Topper, Yakima Racks, Yakima Loadwarrior roof basket (lights all around) 20% window tint (all 4 doors), Spectre ProFab Air Intake System, Black grille, Rino Lined rocker panels, rear bumper and flares Suspension: New OME 881 coils and OME 5 leaf rear springs, Blilstein shocks and struts, Daystar Greasable lift shackels Extended rear brake line
    My truck is a 2001 3.4 with close to 200,000 miles on it. I am putting over 2500 bucks into suspension, wheels and tires. The question is: Is it worth it???? I am not the original owner but I know that the previous owners maintained the engine, tranny, and everything else mechanical because I have maintenance records from both of the owners, I don't have everything but its definitively enough to be able to tell that it was maintained.
    What I am currently doing to it:
    Suspension
    - 5100 Bilsteins
    - OME 881s
    - Wheeler's 5 leaf rear replacement springs
    - Slightly longer rear shackles
    - 10mm spacers in front on top of strut plates
    - New strut plates
    - Extended rear brake line
    - Front diff. drop
    Tires n Wheels
    - General Grabber at2 285/75r16s (just so everyone knows.. the truck needs tires anyway so this was the first thing in my budget and new shocks because the ones on right now are leaking bad, so that is close to 1000 dollars of the cost right there)
    - 16x8in Pro Comp rock crawler black rims 3.75in backspacing
    Other
    - Yakima Load Warrior basket on topper
    - Driving lights and utility lights on the front and rear of basket.
    I want to do more down the road like possibly rock sliders, Line-xed rocker panels, and stuff like that but that is definitely not gonna be any time soon.
    Just looking for some opinions and/or suggestions. Thanks everyone
  2. Dec 13, 2010 at 5:48 AM
    mountainprimat2
    mountainprimat2 Well-Known Member
    Stefan
    LI, New York
    09 DC TRD Off-Road 6spd man
    ICON Suspension 2.5 CoilOvers(Front), RXT 2.5 (Rears), 2.5 Hydraulic Bumps, ICON RXT Multi-Rate Leaf Spring, Total Chaos UCAs and LCAs, 33inch TOYO MTS on 17'' American Racing Teflon Coated Wheels, TRD Cat-Back Exhaust, TRD CAI, Grillcraft Grilles(U/L), MOT's Badge Grille Mod (Red), Black Lower Valence, Black Bed Lined Rear Bumper, Bushwacker Pocket Style Fender Flares, OEM Roof Rack, Wet Okole TRD Seat Covers, Husky Floor Liners,TRD 6spd Shifter Knob, Cobra CB w/ Firestick II, Interior LED Map(RED)/Dome(WHITE) Lights, LED Licence Plate Lights, Amber Fogs, Plasti Dip Badges, Trailer Harness Relocate, Thule Tail Gate Pad + Bed Rack
    Well if you putting suspension on it, then you are eventually have to tweak the engine at some point, re gear or whatever. But its a yota sooo all the money is worth it in my opinion. Good luck on the mods. Post some pics when you get it going
  3. Dec 13, 2010 at 5:54 AM
    TacoBlitz
    Jake
    Omaha, Nebraska
    Thank you, and you really think that I am going to get different gears or do something to the engine? Have you ever heard of anyone having problems that don't?
  4. Dec 13, 2010 at 5:54 AM
    thombiz
    thombiz Active Member
    Corpus Christi
    01 Prerunner & '02 Tundra
    With that much mileage and that much money, my vote would be to save your money unless you go off road very frequently, at night and have a lot to carry in the basket. Most of it sounds like it is just for looks!
  5. Dec 13, 2010 at 6:00 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Since you have the v6 you don't need to regear. Some people do it just to have a little more torque with the bigger tires. I have 285's with the v6 and don't have any plans on regearing. The only thing that I have done, that you could consider an engine mod, is the deckplate mod. Which this is a very simple and cheap mod to do, that gives you a little more power. I don't plan on doing anything else to the motor except regular maintenance.
    edit: Oh and mine has 172k and i've put well over 4k into mine. If something happens to the motor, I'll just throw another one in there.
  6. Dec 13, 2010 at 6:02 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    How many annual miles do you put on? That engine probably has about another 100 k left in it at best before a rebuild so keep that in mind. Suspension parts could be sold if you decide to sell later on, but it would require you taking them back off.
    Id say if your mechanically inclined, then go for it!!!! Sell the 5100's and stuff later on if you sell.
  7. Dec 13, 2010 at 6:06 AM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    I've got the Bilstein 5100s with OME 881s and they were a great investment for my 10 year old truck. I don't have the whole leaf pack, just an AAL.
    I don't think you'd be able to fit 285s under that suspension though...I had 285s with Bilsteins up to 2.5"(Before 881s) but the old coils sagged a bunch and I started rubbing a lot. I went down to 265/75/16 and couldn't be happier..No rubbing, do well on dirt roads, etc. Might wanna look into 255/85/16 if you like the taller tires.
  8. Dec 13, 2010 at 6:07 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I like to budget about $500 a year towards maintenance and upgrades, I don't always spend it but I figure its the cost of having a reliable and capable truck. If you look at the mods as maintenance then it is certainly worth it.
  9. Dec 13, 2010 at 6:22 AM
    TacoBlitz
    Jake
    Omaha, Nebraska
    Right now I plan to have this truck forever as long as I don't wreck it, I cant really see my self selling it down the road at all but I guess you never know. I guess you could say that with this poll I am trying to figure out if I am being stupid or crazy having this kind of thinking with this old of a truck.
    - I do plan on offroading with it and I will use it a lot during the winter of course, I also try to go camping and hunting when I can so..
    Right now the truck is also my daily driver though so I am putting miles on it but its still not to bad, I have had it for about a year and have put about 10,000 on it. I don't plan on it being my daily driver for to much longer though (hopefully), once I am ready financially I plan on getting a 2nd vehicle.
    Thanks for the posts everyone your helpin a lot
  10. Dec 13, 2010 at 6:32 AM
    TacoBlitz
    Jake
    Omaha, Nebraska
    Yeah sounds like a great plan and I think is very important, and for me I know that If I want to keep mine capable and reliable I would have to do something about the suspension anyway because of how worn out it is (it bottoms out going over speed bumps). So I figured that it would be as good of a time as any to do a small lift. And I already decided that I am going to replace everything and do a quality lift/repair instead of just a quick fix.
    and I also need new tires pretty badly, and its not to much more for the bigger tires
  11. Dec 13, 2010 at 6:43 AM
    TacoBlitz
    Jake
    Omaha, Nebraska
    Thanks for the thoughts. I am hoping that the new rims with will fix the rubbing with the front tires cause I have heard that they will rub if put on with with this setup from other people also, that is honestly the main reason why I bought new rims. I would have rather saved the money and maybe done it down the road or something. Yeah and im sure that I will have to do some trimming of the front fenders too. I just really wanted a litter bit bigger tires for some reason lol I am determined to make it work
  12. Dec 13, 2010 at 7:30 AM
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    I'm in kind of the same predicament. I too considered going OME/AAL/16's/Tires
    I didn't end up going that route. My reasons:
    1) Its a prerunner
    2) I don't offroad..well maybe some light trails possibly twice a year at MOST
    3) It's a Toyota, I'll give you that. But its also 7 years old. This is my daily driver, not a project car. I looked at the total cost of my budget, in relation to what the car is currently worth, and that ratio did not make me feel comfortable pulling the trigger on that much money, for this truck. Don't get me wrong, I love it, and plan to keep it for years, but I just couldn't justify it to myself, especially since the mods (in my case) would be 99% cosmetically motivated. My plan is to just maintain the truck and drive it till the wheels fall off. In the meantime I'm also stashing away what I would be paying every month for a new car into my savings... to put down on an M3. LOL. :burnrubber:
    I have many, many other things I can do with a couple grand that will be more beneficial to me.
    But that's just me.
  13. Dec 13, 2010 at 7:39 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    if you have lots of money to spare then yes. if not, then no.
  14. Dec 13, 2010 at 7:53 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    If you plan to wheel it, mod it. Otherwise it's pointless b.c it is not functional to you and thus it's a lot of money for just looks.
    Also, get 882s instead of 881s if you plan to upgrade. You may regret 881s b.c they may sag after a little while with the V6. They did on my old 4cyl.
  15. Dec 13, 2010 at 8:00 AM
    unentered
    unentered Son of Baconator
    Jacob
    Deep Creek, VA
    DCLB4x4MGM
    AMS Filter, WT Mats, Supertop, ScanGauge.
    Now that your truck is "broken in." I think it's a good time to start with some add ons, spend away and have fun with it. If you have the money that is. If your kids are going to starve because you want to put this stuff on your truck then I'd say no, feed the kids and then do it.
  16. Dec 13, 2010 at 8:06 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    lol i have only about 2,800 miles on my 2010 reg cab and i have put bout 4,000 dollars into it already and plan on dropping around another 6,000 grand into it. then it will be lifted armored and it will have almost every option that i could want in a brand new truck time to enjoy it for the full life of the truck. i do plan on taking it to some shows possibly in the future.
  17. Dec 13, 2010 at 8:13 AM
    vinnyvavoom
    vinnyvavoom Well-Known Member
    CT
    09 Black Access Cab 4x2
    Some stuff
    Depends on what you bought it for, how you intend to use it and for how long?
  18. Dec 13, 2010 at 8:25 AM
    mackattack07
    mackattack07 Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    i have 338,000 and im starting on modding my truck im gonna fix it and drive it forever.
  19. Dec 13, 2010 at 9:05 AM
    STLharry
    Harry
    VT
    On your '99? Geez!
    I also noticed an '85 pickup in that sidebar thing...that true you have one of those?
  20. Dec 13, 2010 at 9:11 AM
    mackattack07
    william
    yes i do have an 85 its at my dads in fl with a worn out tranny it keeps eating rear main seals.my wife also has a 4runner with 212,000 the 85 is over 400,000 and second engine
