Yet Another Auto LSD / Trac Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brp, Oct 5, 2011.
  1. Oct 5, 2011 at 8:11 AM
    brp
    brp [OP] Well-Known Member
    In David K's very informative thread, "A-TRAC/TRAC/AUTO LSD Explained (Easy to understand, I hope!)" he says:
    "Also, in 2WD you can have 'enhanced' LSD with even heavier braking action to the spinning tire with a quick push of the VSC Off switch, which turns on 'AUTO LSD'.
    Only in 2WD can you go into AUTO LSD."
    This got me wondering if the rear axle limited slip action is stronge, in 2H with the Auto LSD engaged, than in 4H/4L(yellow wire) with TRAC?
    That does seem to be the case.
    If so, wouldn't it be nice, especially for people like me with an SR5 4x4 and no A-TRAC, to be able to have AUTO LSD engaed/active in 4H and 4L. The net effect might be like having A-TRAC in the rear axle.
    Assuming my line of thinking is correct, which is 50/50 at best, we should devise of a yellow wire mod type of thing to get AUTO LSD in 4H and 4L, for the SR5 guys.
    Let me know what you think.
  2. Oct 6, 2011 at 5:05 PM
    brp
    bump
  3. Apr 16, 2012 at 6:05 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    I hope you have discovered the answer already, but for anyone who wasn't clear the way I wrote it... (and Whipper is pretty close to being right):
    AUTO LSD is a 2WD traction aid (traction control without engine output regulation).
    In 4WD (H4) High, the traction control (TRAC) is automatically on without engine output regulation. Only in 2WD is TRAC operating with both brakes and regulting the engine output.
    So, AUTO LSD and TRAC in H4 is the same, but on different tires (back only vs. all 4).
    If you are stuck, and have a 4WD truck, skip the AUTO LSD and just go into H4... or L4 with A-TRAC.
    If you are stuck in a 2WD only truck, that is what AUTO LSD is for... to try it!
  4. Jun 9, 2012 at 2:01 PM
    stowayman
    stowayman Well-Known Member
    Gary
    Monterey, CA
    08 DC 4X4 TRD O/R - Debadged
    Kenwood DNX9980HD Nav - BT - Sirius - backup camera, Weathertech digifits, maglite mod, 14" billet antenna
    Atrac is pretty nice to have... too bad it wasn't offered in 08 when I got mine. The lockerand airing down has proved it's usefulness more than a few times however.
  5. Jun 9, 2012 at 5:37 PM
    David K
    Agree fully, air pressure has a ton to do with helping traction! If you are stuck or can't climb a hill... lower your tire pressure! 15 psi vs. 32 psi is pretty amazing!
    The rear locker (as I also had on my '01 and '05 Tacomas) is a great addition. The A-TRAC device may not get you any further than the rear locker and lower pressure do, but it is just comforting to know that there is a slip control on the front tires, with it... and I basically have no fear off roading solo... Not, that I have ever feared off roading with any of my Tacomas... but there is a sense of complete traction with the A-TRAC system.;)
