Yet another catback question.
Discussion in '1st Gen. Tacomas (1995-2004)' started by wesb1023, Oct 26, 2018.
  1. Oct 29, 2018 at 5:41 PM
    02hilux
    Planet: EARTH
    Buy used, that's your only option
  2. Oct 29, 2018 at 6:03 PM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    Buy a used exhaust system? Might as well pick up them used drums & rotors too. And grab those shocks while yer at it.
    Itchyfeet likes this.
  3. Oct 29, 2018 at 10:26 PM
    02hilux
    Planet: EARTH
    Used exhust don't have the same side affect as drum etc. Im sure you bought your truck used as well..... did you replaced all the parts on the truck yet with new ones?
    There's nothing wrong with used parts unless your in MI where everything is worth nothing cause of rust
  4. Oct 30, 2018 at 7:46 AM
    04tacoma trd
    04tacoma trd Well-Known Member
    02hilux[QUOTED] likes this.
  5. Oct 30, 2018 at 9:13 AM
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    I made my own exhaust. 4 to 1 header, Gutted cat, Magnaflow 11226. Sounds slightly ricey, but I'm in high school. It was destined to happen lol
    Logger likes this.
  6. Nov 17, 2018 at 2:26 PM
    wesb1023
    wesb1023 [OP] Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    Ok, I actually finally decided on the magnaflow kit that I first referred to in my original post. I thought it over with where I wanted the exhaust routed and the pros and cons of each, and it led me right back to where I started. Anyway after I finally got my kit, the first thing that I did was cleaned and sanded the entire system with a scotch bright pad and acetone. The tip and muffler of this kit were polished to a chrome like finish. I’m not a fan of chrome at all on anything. Anyway I scuffed the tip in a one way direction to make it a more dull, brushed finish. I then painted the entire system with VHT satin clear paint. Paint is the flameproof type that is rated between 1300-2000 deg F.
    I then installed the kit on my truck the next day. FYI it says in the instructions that the muffler should be in the vertical position, but to adjust after everything was installed then tighten all the bolts. My muffler ended up being on a slant to allow for the pipe hangers to line up correctly. The kit fit was phenomenal....up until I started tightening the bolts. I cussed enough for all of us up here. It just kept squalling in different directions. I’d loosen the bolts, readjust the muffler angle and tighten them again. I finally got it to where I was satisfied, all except the very last hanger at the tip. I can wiggle the exhaust and the hanger will start to come out of the rubber. I did use lube to install this because that’s what most of them take to stretch over the flared end. Now it wants the back right out over the flared end. It’s not much pressure, and won’t come all the way out of the rubber. I walked away from it and slept on the idea of how to get the hanger to stay in place and it all still look good. A worm hose clamp just doesn’t fit my style of work... I ended up with a very simple e-clip that clips onto to flat portion of the hanger stud and won’t let it come out of the rubber.
    I’ve only driven the truck once, and there is a crazy curing process that goes along with the paint that I used. I’ll keep you updated on how the kit holds up.
  7. Nov 27, 2018 at 1:13 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    ? - any trick to gutting the cats? Did you recycle the guts afterwards? i suspect they are worth a few bucks since people like to steal them.
  8. Nov 27, 2018 at 1:40 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    easier to cut it out and replace with a piece of pipe. plus you can make a few bucks selling it
    zerotimeouts[QUOTED] likes this.
  9. Nov 28, 2018 at 5:12 AM
    jgill21
    Jake
    Nashville
    I just took a big ass flatblade and hammer and beat it out. Took awhile though. Then found some pipe to run the length inside so I could keep the cat housing incase they were to look underneath during emissions testing
  10. Nov 28, 2018 at 11:54 AM
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    Here in CA it's best to keep the cats visible....those front ones are a pain to have to remove every couple years.
    ah, so you put a straight piece in to prevent extra turbulence in the empty chamber or weird resonance. makes sense.
    jgill21[QUOTED] likes this.
  11. Nov 28, 2018 at 7:04 PM
    Rick Speed
    Rick Speed Well-Known Member
    2002 Tacoma SR5 TRD 3.4L V6 4X4 Ext.Cab
    ARB Bumper Westin 9500LBS Winch PIAA Lights X6 OME 2" Lift OME Heavy Duty Leaf Springs MBRP Exhaust K&N Air Filter Toyo R/T 285/70/17R
    MPRB exaust, goes over leaf springs
  12. Nov 29, 2018 at 10:04 AM
    04tacoma trd
    Do you get any fault codes with the "test pipe"? Do you get any HP gains?
  13. Nov 29, 2018 at 10:29 AM
    jgill21
    Jake
    Nashville
    I threw two spark plug non foulers on the rear oxygen sensor for that. No code, passed emissions for 2 years now. Butt dyno felt some change
