Yet Another DC Manual Swap Thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by osterhagen, Apr 16, 2020.
  1. Jul 18, 2020 at 10:24 AM
    #121
    osterhagen
    osterhagen [OP] Well-Known Member
    Rafe
    Glendale, AZ
    2003 DC v6, MTM, 4x4
    "Totally Stock"
    My pleasure man. I ain't going anywhere anytime soon, so hit me up if you run into any questions I might be able to help with.
    I think that sounds like a really solid plan to get you headed down the road.
  2. Jul 18, 2020 at 10:25 AM
    #122
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    Thanks for the info! Yeah I will let ya know if I run into anything specific I need to know, really appreciate it.
  3. Jul 18, 2020 at 10:28 AM
    #123
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    idk why, your double cab is a lot cleaner than mine :)
    I spent the afternoon washing and waxing it (didn't even get it all done lol) and got reacquainted with each little ding, gouge and rock chip. But that is quite alright because she ain't meant to be fancy!
  4. Jul 18, 2020 at 12:30 PM
    #124
    Madjik_Man
    Colorado Front Range
    Dont be fooled by the 20’ away pic. Hail damage, little dings and scraps...
  5. Aug 3, 2020 at 10:25 AM
    #125
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    @Madjik_Man @JoeyWales Here is a pretty complete list for you. I haven't double checked this and it's somewhat off the top of my head but this will get you 99%. Let me know if you have questions :)
    Parts needed for manual swap (v6 3.4)
    R150F transmission and transfer case
    Bell Housing Bolts 3 (3 are longer, 3 are the same as Auto)
    Rear Main Seal
    Pilot Bearing
    Flywheel
    Flywheel bolts
    Clutch Disc
    Pressure Plate
    Pressure Plate bolts
    Clutch Fork
    Throw-out Bearing
    Clutch Fork Boot
    Slave Clutch Cylinder
    2x Slave Clutch Cyl bolts w/ washer
    Lower Clutch Hydraulic Hardline
    Clutch Hydraulic Flex Hose/Line (Between 2 hard lines)
    Bell Housing Mount for Clutch Hydro lower hardline to flex line
    2x Hose Clips (holds hoses in place on mounts for clutch hydro lines)
    2x Line Clips (holds lower hydro hard line to side of transmission)
    2x Line Clip bolts
    Upper Clutch Hydro Hard Line
    Clutch Master Cylinder
    Mounting Hardware Clutch MC (2 nuts w/ washers)
    Complete Clutch Bracket Assembly (see my post about all items need to make one)
    Clutch Cruise Cancel Switch
    Clutch Depress Switch
    Clutch Cruise Cancel Switch Plug
    Clutch Depress Switch Plug
    4x Wire w/ Terminal (pins and pigtail wire for above plugs)
    Brake Pedal from a manual Tacoma
    Manual shifter console surround (plastic trim)
    External Boot Covers (Vinyl or Leather type deal) (Comes with Console surround if new)
    Rubber shifter assembly boots (Rubber w/ metal surround & 4 screws)
    Shifter for Transmission
    Shifter Knob for Transmission
    Shifter Seat for Transmission
    Shifter Bushing for Transmission
    Shifter Base Gasket for Transmission
    Shifter for Transfer Case
    Shifter Knob for Transfer Case
    Shifter Seat for Transfer Case
    C-Clip for Transfer Case Shifter Retention
    Shifter Base Gasket for Transfer Case
    Reverse Gear Sensor
    4x crush washers (drain and fill plugs)
    Manual Transmission Mount
    Starter Bolt (1 is longer, 1 is short same as auto)
    Transmission Input Shaft Seal
    Transmission Output Seal
    Toyota Red FIPG
    Transfer Case Front Flange Seal
    Transfer Case Rear Flange Seal
    Transfer Case Input Seal
    Same Year and Drive Configuration ECU but with Manual instead of Auto
    Dot 4 Fluid for Clutch
    MT-90 or preferred fluid for transmission
    75-90w gear oil for transfer case
    Something to plug off holes in bottom of radiator for trans cooler lines
  6. Aug 3, 2020 at 10:27 AM
    #126
    Madjik_Man
    Sweet baby Geebus.
    Thank you
    Im gonna add ECU to that list.
    osterhagen[OP] likes this.
  7. Aug 3, 2020 at 11:04 AM
    #127
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    It's there, 5th up from the bottom. So many items though haha, easy to miss stuff :)
  8. Aug 3, 2020 at 12:51 PM
    #128
    JoeyWales
    JoeyWales Well-Known Member
    SC
    Wow bro, this rocks! Thank you so much! Looks like I better have 2-3k on hand ready
  9. Aug 3, 2020 at 8:59 PM
    #129
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Good list.
  10. Aug 21, 2020 at 7:27 PM
    #130
    Ccrowe323
    Ccrowe323 Well-Known Member
    Cory
    Florida
    2001 Tacoma 3.4 DC 5speed TRD OR
    Hey man, sorry to bother you with more questions lol but I’m having trouble finding these parts for the trans and tcase. I have found the tcase front flange and tcase input shaft seal on yotashop but can’t seem to find the others. Was wondering if you happened to write down the part numbers for the rest?
    If not no worries dude, I’ll keep doing my research:cheers:
  11. Aug 24, 2020 at 7:34 AM
    #131
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    No worries at all mate! I have just been busy most weekends out exploring and stuff. So sorry it has taken a few to get back with you.
    Regarding the part numbers, I don't have them specifically. But I can show you how I found them (teach a man to fish if you will) :)
    So head over to https://partsouq.com/ and put a vin number that has the equipment you're looking to re-seal. Once you enter the vin number it will give you a bunch of different part diagrams that are interactive with part numbers and usually even pictures of the parts. There will be different categories of parts on the left side.
    Just need to find the correct one (likely power train) and then find the diagram for the transmission/t-case. Then you can find the specific seal you are looking for and click the number associated with it on the diagram. This will pop a box up with the part number and often a little camera icon. If you click that icon you can see a picture of the seal in the package.
    Then drop that part number into mcgeorgetoyota or whatever you prefer and bobs your uncle!
    Let me know if you have issues or can't find them, I can dig them up for you worst case, just time is tight for me right now.
    Ccrowe323[QUOTED] likes this.
  12. Aug 24, 2020 at 7:39 AM
    #132
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    Also, make sure and get some FIPG for gear oil on txfer/transmission because some of those seals are behind bearing retainer covers and such. Easy to do but gotta make sure and re-seal it correctly :)
  13. Aug 24, 2020 at 8:04 AM
    #133
    Madjik_Man
    So I’ve been quasi-following some of your posts...
    do you have a transfer case issue and if so, have you figured it out
  14. Aug 24, 2020 at 8:24 AM
    #134
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    That depends on your definition of "issue". :D
    I purchased a used JDM R150F off of E-Bay. It came from a 4-Runner (at least I believe it did) Turns out the seller I bought from wasn't the best and long story short I ended up getting a large portion of the money I paid returned. What I believe to be happening is that I got a runner t-case that requires an actuator for some portion of the functions. But it was sold as a J-shift non actuated model.
    So now as to why it matters as to your definition of "issue"... One of the many reasons I built this truck the way I did is reliability and fall-backs. I am a Systems Reliability Engineer by trade so some of this is just habit and the rest is years of experience driving literally over 1M miles on and off-road. I have manual locking hubs so while I don't have a proper 2-Hi, with the hubs unlocked I accomplish the same thing, though spinning the front CV's and diff all the while :(
    So this config works fine, I've put nearly 2k miles on it in this configuration. However I won't be leaving it this way. I am taking some time to evaluate my options as they relate to transfer cases while I work on other projects for the vehicle, namely project "flat-ass". I will either replace with another t-case (V1FA, Tacoma, J-Shift) or go really out in left field again (unlikely) and go with a converter and lefty setup / dual case.
    Also I use the absolute shit out of 2-Lo off-road :D:cool:
  15. Aug 24, 2020 at 9:18 AM
    #135
    Madjik_Man
    I might have to do the gravy wire mod.
    And if I do the swap (with your in-person help of course :oops:) I’m just gonna buy the exact parts no matter how much it hurts the wallet.
    Also, 4-lo in the auto sucks donkey balls. In the 5MT I can slow crawl up and down anything just using the gas pedal. Never have to use brakes. In the auto I was riding the brakes as if I was in 4-hi.
  16. Aug 24, 2020 at 9:28 AM
    #136
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    Yeah always the best course of action if possible. Buying locally can help a lot with that also as you can put hands on it before purchase and make sure it's right.
    That is really good to know about the auto and man does that suck. Makes me so happy to have the manual because yeah I couldn't agree more. I climbed up and down some really steep shit weekend before last and used either 1st or 2nd gear and in low range and never used the brakes. Felt extremely in control the entire time and that combo'd with the Cooper STT Pro's air'd down and holy shit my face hurt from grinning all day :D
    Will be adding a trip report for that trip, the one before it and also the building of my 12v solar setup in the build thread. Want to get that stuff documented before starting on the flatbed in the next few days...
    Madjik_Man[QUOTED] likes this.
  17. Aug 24, 2020 at 10:02 AM
    #137
    Ccrowe323
    Cory
    Florida
    Awesome, thank you. Honestly I appreciate you sharing that site over just the numbers and appreciate you taking your time to share your knowledge man.
    Honestly at this point you should get paid for the time you’ve put into this write up lol. Maybe when I make it out west, you, @Madjik_Man, and I could meet up and buy you a couple beers for all the knowledge you provided for us haha. Hope you get the T-case sorted out, awesome that you got some money back from the deal.
    Im sure I’ll end up asking another question once I tear into the swap but I’ll just keep a beer tally hah
  18. Aug 24, 2020 at 10:06 AM
    #138
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    Thanks buddy, really appreciate that. Always happy to share my knowledge, just wish I had more time... but don't we all? Look forward to seeing your progress and happy to answer questions :) It would be awesome to get together with you guys sometime. Really looking forward to my Moab trip in Oct and finally getting to meet some other 1st gen Tacoma guys
  19. Aug 24, 2020 at 7:41 PM
    #139
    Ccrowe323
    Cory
    Florida
    I’ve finally had a chance to hop on partsouq and holy shit, this is the best place ever. I don’t know how I never heard of this before. They have every part number haha, I wanna rebuild the entire transmission now
    :spending:
    osterhagen[OP] and Madjik_Man like this.
  20. Aug 24, 2020 at 8:08 PM
    #140
    osterhagen
    Rafe
    Glendale, AZ
    "Totally Stock"
    That's awesome man. Yeah I've used that site to completely rebuild a starter and build the entire clutch pedal system from scratch. It's fantastic and the pics have been crazy helpful sometimes. Little items like fender and grill clips soany uses.
    Another cool bit of info. If you find yourself in a situation and need a Toyota part quickly and you have prime check Amazon. They often have them with free two day shipping at the same or cheaper than dealer. That has saved my butt a few times during my build. In full disclosure I work for Amazon and own a fair bit of their stock, but this is personal advice. It's important I'm clear on that.
    Madjik_Man likes this.
