Yet another lift question thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02tacoME, Oct 16, 2014.
  1. Oct 16, 2014 at 7:24 AM
    02tacoME
    02tacoME [OP] Active Member
    Mick
    Maine
    02 Tacoma
    de-badged, aux reverse lights, fog light mod, deck plate mod, tinted and yellow fogs, blacked out corner lights and painted headlight assembly
    Just curious if any of you happened to know if I can fit bilstein 5100 adjustables and a 2.5" coil spacer on my factory UCA's. Thanks in advance!
  2. Oct 16, 2014 at 9:19 AM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    If you are running the 5100 adjustable, you can just set it to 2.5 no need for spacers.
  3. Oct 17, 2014 at 3:26 AM
    02tacoME
    Mick
    Maine
    02 Tacoma
    Correct but why not use the spacers? Ive got 3" shackles in the rear and hope to do AAL's or all new leaf packs and I want my truck to sit level
  4. Oct 17, 2014 at 7:37 AM
    Combatman
    Combatman Well-Known Member
    Sioux Falls sd
    1996 Tacoma 4x4 3.4 Manual
    31" Wrangler tires
    You want to do the 2.5" of the bilstiens plus your spacers? You will run into major issues with CV angles and ball joint angles.
    I recently put on 5100s (at 0") with eibachs and even with an off road bumper and winch I think I got about 3.5" up front, and I did a diff drop and my CV angles already look pretty bad, and the ball joints were pretty difficult to reassemble
  5. Oct 18, 2014 at 4:44 AM
    02tacoME
    Mick
    Maine
    02 Tacoma
    Now thats the answer I was lookin for! Thats kind of what I thought would happen just figured it would be worth a shot
