Yet another question on lifting a taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sacul_reab, Feb 16, 2025.
  1. Feb 17, 2025 at 4:41 PM
    kent50
    kent50 Well-Known Member
    Kent
    Gold River California
    2017 Tacoma Sport DCSB MGM
    3" Lift XD Wheels 33" K02s Predator Steps TRD Oil Cap Backflip Bed Cover Factory All Weather Mats WeatherTech Bed Mat TRD Pro Shift Knob Vinyl Air Bag Decal Covers Vinyl TRD and Tacoma Inserts Factory Mud Flaps Factory Remote Start Factory Door Sill Protectors Console Organizer and Tray Pro Fogs Grill Mounted LED Light Bar TRD Faux Grill DeBadged TRD Sport Door Emblems Factory Bed Lights Pop Lock Tailgate Lock Rear USB Ports DIY Power Panel
    You may already know this but if you are trying to get more ground clearance, you won't achieve it with a lift. Your diffs will still be the same height off of the ground after the lift as the only thing that changes that is the tire size. I don't believe that adding sliders, steel bumper and a backflip will overwhelm the stock suspension either. If you just want the lift, well, because you want a lift then cool.
    RIX TUX likes this.
  2. Feb 17, 2025 at 4:44 PM
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    A lift will increase your angle of approach, your breakover angle, your angle of departure, and your ground clearance under the front differential, even with the same tire size. It will basically increase your ground clearance for everything, except your rear axle.
    MR E30 and SRexp1903 like this.
  3. Feb 17, 2025 at 4:54 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Pretty sure ARB Old Man Emu have a good reputation, but most members have better luck with a 2" Bilstein 5100 lift. As the the lift in the rear, you could go AAL, or a 1" block. Comes down to whether you carry a lot of weight in the box. I don't, but I have a rear steel bumper, and it hasn't changed anything one iota with my 1" block. No regrets there.
    Good luck OP, and yes lifts are cool. Fun to drive in deep snow storms, and forging water that's too deep for your average car.
    wood714 likes this.
  4. Feb 17, 2025 at 6:43 PM
    StreetSr5
    StreetSr5 Well-Known Member
    I have a Detroit Truetrac limited slip differential in my 2022 sr5. unless you’re a hard wheeler, go with the Truetrac. I can’t recommend it enough, it’s by far my favorite mod I’ve done. Buttery smooth, no chirping, durable, no maintenance, no wires to run, no activating and deactivating, and extremely capable. It’ll never one leg if both wheels are on the ground, like if you’re in sand, mud, dirt, snow, pavement, etc, so if your experiencing one wheel peels you can say goodbye to that. If one wheel is in the air (where a locker would be useful and a limited slip would just one leg) just press the auto lsd traction button and as soon as the truck applies resistance to the spinning wheel the Truetrac locks hard. I highly discourage against a lunchbox locker as they make daily driving annoying with clicking every time you make a turn. I’m not sure Truetracs are so unpopular in the Tacoma world but it’s really a hidden gem
  5. Feb 17, 2025 at 7:04 PM
    Sacul_reab
    Sacul_reab [OP] Member
    2023 tacoma off-road
  6. Feb 17, 2025 at 7:15 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    It's a spacer lift.
    For that price years ago. I've got aal, assembled coil overs with ome 885 on 5100.
    The 1st kit you shared as way better than 2nd
  7. Feb 17, 2025 at 7:31 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    how about the lower control arms?
    Junkhead likes this.
  8. Feb 17, 2025 at 7:35 PM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I had a lift put on my 2018 last week. Went with Bilstein 6112's in the front, and 5100's in the back. Due to a mix up in communication they only made the lift 1/2".
    Their redoing it this Wed, they set my front shocks at 7 and 5. Their moving them to 10-8 and adding a 1" block to the rear.
  9. Feb 17, 2025 at 8:02 PM
    TomHGZ
    Haha, how about which part of the lower control arms? At least it moves the fragile alignment tab ends farther from the ground.
  10. Feb 17, 2025 at 8:08 PM
    RIX TUX
    the lowest part, we are talking about ground clearance
  11. Feb 17, 2025 at 8:11 PM
    TomHGZ
    “I’m mad because the lift didn’t make my Tacoma an airplane.”
  12. Feb 17, 2025 at 8:12 PM
    RIX TUX
    thats your answer?
  13. Feb 17, 2025 at 8:15 PM
    TomHGZ
    If you are regularly banging the tire side of your LCA you are driving the wrong line.
    MR E30 likes this.
  14. Feb 17, 2025 at 8:16 PM
    RIX TUX
    so the lift dont matter but only the line matters?
    dryheat and Junkhead like this.
  15. Feb 17, 2025 at 8:19 PM
    #35
    TomHGZ
    It’s actually better to lower your truck to drive offroad. Better yet, take a Corolla.
  16. Feb 17, 2025 at 8:22 PM
    #36
    RIX TUX
  17. Feb 18, 2025 at 4:32 AM
    #37
    Sacul_reab
    Looking at some of the other complete kits is where I get confused. So for example, https://www.tacomalifestyle.com/col...1-5-3-suspension-kit-4x4-double-cab-short-bed.
    Does this kit give a 1.5" lift by default, with stock weight ratings, and then if you want more lift or weight rating you pick the extras? If you're just going for lift, and not wanting to upgrade load capacity, what's the point of getting new leaf springs over stock then, why not just use blocks in the rear? If that's the case couldn't a guy just do something like this https://www.tacomalifestyle.com/col...it-double-cab-short-bed-with-quick-ride-rear?
    If you get new shocks and struts for a two inch lift, I'm guessing you need blocks for the back end to help bring it up to height? Do you need coils then?
  18. Feb 18, 2025 at 8:01 AM
    #38
    TomHGZ
    Those Dobinson’s are like OME. If you pick the wrong coil from the drop-down menu and get the wrong ride height, you have to buy new coils. Adjustable height coilovers are more forgiving to mistakes or changes of mind.
  19. Feb 18, 2025 at 5:12 PM
    #39
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Don't forget, taller tires equal taller lift!
  20. Feb 19, 2025 at 12:30 PM
    #40
    TomHGZ
    I just thought of this: You can make your OME Nitrochargers “extended travel.” The compressed length on Nitrochargers is ~1” shorter than Bilsteins, so you can add a 1 inch spacer on the top of your Nitrochargers and they will still have enough room to compress to hit the bumpstops, and will extend into the “extended travel” range.
    I say this with three caveats: First, it would be prudent to measure the compressed length of your Nitrochargers yourself — compress them off the truck and without the coil installed — to verify they compress as short as they say. They need to compress to about 16 5/8 inches or shorter. That will leave you with enough margin to put that 1” spacer on top without problems.
    Second, it may be tempting to put an even larger spacer on top for more downtravel, but don’t. I played with putting a spacer on my Bilstein 6112’s, which extend about an inch more than the Nitrochargers, and I found that my UCA’s would bang into my coil springs at full extension, along with some other interference issues at full steering lock. So 1 inch spacers should give you “extended travel” equivalent to other extended travel shocks on the market, but don’t go taller than that.
    The third caveat regards lift: adding 1” spacers will give you almost ~1.75” more lift at the wheel than you currently have, which will be too much. So you will have to swap out your current coil springs for something that gives you less lift.
    I believe the 2884 coils are the shortest “officially” spec’d coils for 2nd/3rd gen Tacomas, but lots of people (myself included, when I had Nitrochargers) have run 2883 coils without problem. 83’s are an inch shorter than 87’s, so likely what you need to maintain a similar ride height after installing 1 inch spacers. Good luck!
