Yet another Tacoma brake upgrade to Tundra
Discussion in '1st Gen. Tacomas (1995-2004)' started by TheFed, Feb 11, 2015.
  1. Oct 31, 2019 at 1:42 PM
    #221
    Kens04Taco
    Kens04Taco Well-Known Member
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    without the sensors doing the manual (slam on your breaks in dirt/gravel) will not activate the abs. You’ll have to use the computer to have the abs bled.
    snowboard704 likes this.
  2. Oct 31, 2019 at 2:25 PM
    #222
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    @2004Taco do you have the ABS module in the engine bay? If so then the answer is Yes, regardless whether you disabled it or not.
  3. Oct 31, 2019 at 2:27 PM
    #223
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    Yes, everything is still in tack expect the sensor. What should I do with the ABS?
  4. Nov 1, 2019 at 3:59 PM
    #224
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Exactlyyyyy
    if the abs doesn’t have a sensor because there’s no spot on the spindles, the abs must be activated by computer via scanner at dealership or select snap-on readers to get the possible air out of the abs module
  5. Nov 2, 2019 at 1:08 PM
    #225
    2004Taco
    Lou
    California
    So I have a OBD2 scanner. Something like that or is it a different tool.
    snowboard704[QUOTED] likes this.
  6. Nov 2, 2019 at 6:37 PM
    #226
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    different tool completely
  7. Nov 3, 2019 at 3:30 PM
    #227
    2004Taco
    Lou
    California
    So today I did an old school bleed job on the Tacoma. Soft pedal.
    I then vacuum bled the system and the proportioning valve. I still have a soft pedal.
    After all that I've done I took my Tacoma into my local mechanic and had the entire system checked. I STILL HAVE A SOFT PEDAL.
    I asked about ABS to be scanned and he said that it only needs to be scanned if the pedal is vibrating, which it's not.
    I don't know what else would be the issue.
    Maybe take it into a brake specialist?
  8. Nov 3, 2019 at 6:14 PM
    #228
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    It’s not a abs scan. It’s a “manual” override to bleed the abs system. A purge if you will
  9. Nov 3, 2019 at 6:25 PM
    #229
    2004Taco
    Lou
    California
    Ok, what should I do at this point?
  10. Nov 3, 2019 at 6:42 PM
    #230
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    well assuming you don’t have a leaking booster. And since you don’t have ur abs sensors you’re going to have to find someone with the computer that can tell the computer to run the abs cycle or go to the dealer
  11. Nov 3, 2019 at 6:57 PM
    #231
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    kinda glad i don't have ABS now
  12. Nov 3, 2019 at 7:24 PM
    #232
    2004Taco
    Lou
    California
    No leaks but I still have my sensors.... in a box lol. So what if I pulled the ABS fuse?
  13. Nov 3, 2019 at 7:27 PM
    #233
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    air trapped inside the lines or the abs system itself. Pulling the fuse would not help your situation. I know it sucks bud but it’s kinda where your at. If someone else knows something I don’t please chime in. But when I went through what you are...I had to activate the abs to get my pedal back
  14. Nov 3, 2019 at 7:49 PM
    #234
    Stout890
    Palmdale ca
    99 prerunner sr5
    why not pull the abs module?
  15. Nov 3, 2019 at 8:25 PM
    #235
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    If he can bend and flare hardlines for the brakes then sure.
  16. Nov 4, 2019 at 5:45 AM
    #236
    2004Taco
    Lou
    California
    I'll have to find someone who can bleed the ABS system. Did you take your truck to the dealer?
  17. Nov 4, 2019 at 7:03 AM
    #237
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    No I just bled the truck. Took it out and found some wet leaves on the road and hammered the breaks and the abs kicked on. I came back home and bled again. The pedal got better after that. It wasn’t as stiff as stock but the truck stopped really hard and it was good enough
  18. Nov 4, 2019 at 7:10 AM
    #238
    2004Taco
    Lou
    California
    So the truck stops well but before I did the swap, I was able to lock up the tires on the dry assault. Now it doesn't. I still need to adjust the rear brakes. maybe that will help a little.
  19. Nov 4, 2019 at 12:06 PM
    #239
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    If you could could lock them up before and now you can’t then there’s something wrong
  20. Nov 4, 2019 at 12:37 PM
    #240
    2004Taco
    Lou
    California
    I found a brake specialist and I told him about my situation. He said he can to a "pressure bleed" and this should push any air out of the system. He also has the scan tool for the ABS. We'll see how that goes.
