Yet another Tacoma brake upgrade to Tundra
Discussion in '1st Gen. Tacomas (1995-2004)' started by TheFed, Feb 11, 2015.
  1. Jun 23, 2015 at 6:30 PM
    #41
    Frostbyte
    Frostbyte Well-Known Member
    Northern Utah
    18 Super White TRD OR Manual
    SOLD - 03 Black SR5 4x4 TRD OR RIP - 07 Radiant Red SR5 4x4 TRD Sport Fabtech 6" lift, 33x12.50.18 Toyo M/T on All black XD Hoss wheels
    Also, what is the difference between 13WL calipers and S13WL? I have noticed they seem to be the calipers of choice, but to me, being non mechanic, they appear to be the same? I'm looking at using the S13WL calipers for my upgrade, with the TRD Trail team wheels 15mm, 3"extended braids from LCE with my 881/5100 front lift.
    Is all of this going to fit together?
  2. Jun 23, 2015 at 7:00 PM
    #42
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Yes you definitely will have to trim the dust shield. I traced/marked the shield/caliper with a sharpie and then used an angle grinder to trim the dust shield back.
  3. Jun 23, 2015 at 7:02 PM
    #43
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Not sure the difference. Do the hard lines connect to the same nub? There are two nubs on each caliper, one has the threaded hole for the fitting and the other looks like it is blocked off but could be drilled out for a different configuration.
  4. Jun 24, 2015 at 4:14 AM
    #44
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    No, and they are pro comp 8069s. Also, you do not need to cut the dust shields. Just simply bend them back and out of the way, until the rotor can be turned and no contact with the dust shield is made.
  5. Jun 24, 2015 at 10:43 AM
    #45
    synergy10
    synergy10 @synergy10.sd
    San Diego
    I cut mine where the calipers would hit as well. Then bent them back so that the rotors don't rub.
    I guess you could bend them back enough to clear the calipers...I chose to cut and bend.
    Sorry for the crappy edit (used photobucket)...but here are the places I cut the dust sheilds at:
    41d044c3-ab84-48f3-ad8d-72c80f058ede_zps_9a44a056c56f007c339e403bfb87f5849f7e487f.jpg
  6. Jun 24, 2015 at 8:18 PM
    #46
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Here is mine after the trim. My rotor also rubbed a bit so I pulled the shield away a bit.
  7. Jul 9, 2015 at 2:27 PM
    #47
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    I am stepping up to the larger size calipers this week, I run 16 inch American racing wheels with plenty of current clearance with my S13WE calipers. hopefully its not an issue.
  8. Jul 12, 2015 at 2:58 PM
    #48
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Here are some more photos from my brake upgrade...
    Checking clearance for dust shield. Had to trim about 1/4" off the corners and bend/push the shield back a bit to clear the thicker rotors.
    These inserts come with the EBC brake kit. They are supposed to prevent vibration I think. The kit only came with 4 though even though there are 8 pistons. The instructions don't say where to put them. Next time I will call and make sure I have one for each piston.
    These are sweet pads. A little dusty but basically this is the best friction material available from EBC (Extra Duty).
    I know the retainer clip is upside down in the photo. I had to pull the wheel to flip it.
    Spindle brackets, clips, hard lines, and braided hoses from LCE. Everything fit up very nice.
    Red calipers are a bit flashy but I think it turned out not too bad.
    1997tacomav6 likes this.
  9. Jul 12, 2015 at 8:58 PM
    #49
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Awesome photos! Unfortunately, I will have to postpone my upgrade because I had to get a new Ujoint two days ago. Maybe over Thanksgiving I can do it. Until then, I'll just replace my current warped rotors with stock Tacoma ones. The Wheeler's SS lines will still work with the stock calipers, right?
  10. Aug 7, 2015 at 5:19 PM
    #50
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    My brake caliper came with all new guts including the pins and retainers. I would think most remans would also have them. They will not come with the pads.
    Edit: I'm not really impressed with the cotter pins or the retainer clips that came with my calipers. They seem flimsy and weak compared to back in the day. It's hard to believe the retainer clips do anything to push the pads apart.
  11. Aug 7, 2015 at 5:27 PM
    #51
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Retainer clips don't do a lot but without them I have experienced an increase is braking noise in other vehicles. Something simple that I would not recommend leaving off the vehicle
  12. Aug 7, 2015 at 5:31 PM
    #52
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I agree. It just got me to wondering if anyone makes a stiffer retainer.
  13. Aug 8, 2015 at 5:42 PM
    #53
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Bout to see how much trimming is needed for my 15s
  14. Aug 20, 2015 at 7:06 PM
    #54
    4thone04
    4thone04 Well-Known Member
    jcl
    west END of hwy2
    new at 155,000
    image.jpg Thanks for ghe write up. Some good info.
    If anyone is still on the fence about doing the upgrade here is a photo of the stock 04 tacoma front rotor and for grins a 2000 golf/jetta rotor. There is more material on a golf front brake than the truck?? Not a gti just a standard golf. image.jpg
  15. Sep 5, 2015 at 11:50 AM
    #55
    amp3d
    amp3d Well-Known Member
    Mark
    Toronto
    2002 Double Cab TRD Offroad, 2012 Access Cab
    Hey guys, I ended up having problems with my brakes this weekend and am in need of replacing one of my calipers on my 2002 Prerunner.
    Local auto shop has the S13WE and S13WL in stock. I see there is good info on the WE on this forum, but S13WL fitment has been somewhat confusing. My Prerunner TRD has the stock TRD 16" rims. Should I pick up the S13WL? I don't mind trimming the disc guard if that is the only modification...
    Does the WL have a higher risk of rubbing my rims than the WE?
    I looked around and couldnt find any direct comparison other than the length of course and size of pads used of course.
    Basically I'd like to get the WL as long as I won't have clearance issues.
    Figures I'd be stranded on the holiday weekend working on my truck! :/
    EDIT: Seems like the WL is fitting nicely :) Just a tiny bit of trimming as others have mentioned on the shield. Other than that, I think the WL is the way to go! Thanks for this thread! Just as a reminder for anyone thinking of trying this, I wouldn't try it with any rims smaller than the 16" stockers. My wheels clear, but not by much!
  16. Sep 9, 2015 at 5:28 PM
    #56
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    I just did the upgrade today with the S13WE calipers. All I have to say is wow, incredible stopping power.
    I also put on the LCE tundra to Tacoma hardline and stainless brake line conversion.
    I love it. The truck should've come this way from the factory.
    There might be slightly more pedal travel but the feel is great.
    I had doubts about the upgrade after reading many stories about a sloppy pedal but I'm so glad I did this.
    TacoVibez and alphabravo like this.
  17. Nov 15, 2015 at 9:26 AM
    #57
    Toms98Taco
    Toms98Taco Member
    Tom
    Raleigh NC
    98 sr5 5spd 4wd work in progress
    urd short throw, scs F5 matte bronze wheels, more mods coming soon
    Hey guys I'm preparing to do this upgrade but my only concern is whether my scs f5 16 inch wheels will clear the calipers. Other than that I'm all set to purchase the necessary parts to begin. I believe my wheels are 3.5 inch backspaced. Not the usual 4.5. Anyone with some insight please feel free to reply
  18. Nov 15, 2015 at 10:21 AM
    #58
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I thought the SCS fit regardless. Take a look at the F5 FS thread it should be in there
  19. Nov 15, 2015 at 10:32 AM
    #59
    Toms98Taco
    Toms98Taco Member
    Tom
    Raleigh NC
    Well I checked out the f5 page and there wasn't much of a guarantee. I read that they were pretty sure but didn't see anything promising. I'll keep looking til I find it. Thanx tho
  20. Nov 15, 2015 at 2:52 PM
    #60
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    I have the SCS F5's and the 231mm tundra brakes, no issues.
