Yet Another UCA/LCA Ball Joints Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by rocknbil, Mar 26, 2023.
  1. Apr 25, 2023 at 3:13 PM
    #61
    rocknbil
    rocknbil [OP] Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Heh @Kevins60 thanks, once I got everything out it took like 6 hours to put it all back together. I torqued the cam bolts under load, and wound up getting crowfoot wrenches for the rear ones so I didn't have to futz with the rack again. I never would have thought it would take 2 days to get the tie rods and other bits loose lol.
    Kevins60 likes this.
  2. Apr 26, 2023 at 3:45 AM
    #62
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Percussive impact is your friend. I have a craftsman c-3 impact gun that made short work of the castle nuts and my grandfather’s monkey wrench that broke the TREs loose with one shot from a 4lb maul. I lost all my time trying to press the UBJs out and doing the UCA bushings. I gave up on the ball joints and took the knuckles over to the neighborhood garage. $50 and half a day later I had the new UBJs installed. The UCA bushings were a mess. I tried using a small drill bit to drill a bunch of holes in the rubber (fail) and then using a hole saw to try and cut through the rubber (fail and ruined up my hole saw). Checked back here at TW and everything i read says heat the CA with a propane torch and the bushings gets soft and fall out. And they do, but in my case they caught fire and fell out and one left a burning trail of vulcanized rubber when it missed the catch bucket and it rolled across the garage floor. I had to pressure wash the garage floor and workbench because that melted rubber sticks to and stains everything.
    braille and rocknbil[QUOTED][OP] like this.
  3. Apr 26, 2023 at 3:20 PM
    #63
    rocknbil
    Bill
    Yeah "what could go wrong?" LOL
    braille likes this.
  4. Jul 22, 2023 at 5:10 PM
    #64
    rocknbil
    Bill
    As it turns out, this pull was exactly what he said in 2018, I needed a new rack. Now have new LCA's, ball joints, rack, coiiovers and shocks from suspensionlifts.com, it drives like a new truck and the handling is incredibly tight. See more pics here.
    The gold standard likes this.
  5. Jul 23, 2025 at 10:07 AM
    #65
    Suarezabraham
    Suarezabraham Well-Known Member
    Monterey, CA
    2014 Tacoma double cab 4x4
    Which LCA do u recommend to replace OEM
  6. Jul 23, 2025 at 11:07 AM
    #66
    Red_03Taco
    Red_03Taco @ the Taco Shop
    Jerad
    Yavapai County, AZ
    2003 Tacoma Xtra Cab 4WD
    Eaton E-locker (rear), Alcan Leafs, Toytec 2.0s (rear), Icon 2.5s (front)
    OEM
