YFZ 450 Help
Discussion in 'Motorcycles' started by Anthony250, Dec 31, 2011.
  1. Dec 31, 2011 at 10:38 AM
    Anthony250
    Anthony250 [OP] Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    My Cousins 04 YFZ450 Raptor and it runs great but recently started burning oil in larger amounts, and smoking blue heavily, but still running great. There was a good amount of oil coming out of the exhaust. I just took the motor apart to rebuild the top end to replace the piston and rings. But to find it was a 97mm big bore piston kit "ESR" and piston looks great and rings look fine. I dont know if it is just the rings or the valve seals to be replaced. Not sure whether to run the big bore kit with a new set of rings or just get an oem cylinder and piston.
  2. Dec 31, 2011 at 10:58 AM
    Anthony250
    Anthony
    Rialto CA
    I did try that seems that no one cares anymore . LOL
  3. Dec 31, 2011 at 11:10 AM
    Hughesc99
    Hughesc99 Well-Known Member
    Derby, KS
    A yfz450 raptor? Is it a yfz motor in a raptor? Why would he do that?
    Sorry for the off topic-ness, just kinda curious.
  4. Dec 31, 2011 at 11:14 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    just because the rings "look good" doesn't mean they are. Any blow by on the piston skirt? I agree, a leakdown test is the best way to diagnose.
  5. Dec 31, 2011 at 11:19 AM
    Alex88
    Alex88 Well-Known Member
    Alex
    Oakland, CA
    2010 DCLB Sport
    i say new rings and new seals for the ESR piston if you arent looking to burn a lot of money, otherwise your gonna need new piston and jug, and to dyno tune and re jet for the new piston and compression ratio. by the way, if it is a hi comp piston in there right now you need to run race fuel in it, anything above 13:1 or so. if at all possible finding out exactly what piston ratio it is will get you in the right direction. on the other hand, if the rest of the bike is mostly stock, then the rev happy motor seems a little flat when you only put a big bore kit on it. i have a 98mm bored and stroked YFZ and until you add cams and some head work with the bigger jug, it doesn't flow right. i've built two YFZ's since they first came out, an 04 and my current 05, if you wanna chat, ive been inside and out of that motor a lot. PM me for my number if you want.
  6. Dec 31, 2011 at 11:59 AM
    Anthony250
    Anthony
    Rialto CA
    I knew i shoulda done a leak test but i didnt have a tester. I already got the OEM piston and rings and gaskets. I know where to get a good used oem cylinder for a good price.
    No blow by on piston skirt.
  7. Dec 31, 2011 at 11:59 AM
    Anthony250
    Anthony
    Rialto CA
  8. Dec 31, 2011 at 12:01 PM
    RenoTacoma
    RenoTacoma Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    Sounds like an expensive issue, did you have the right amount of oil in it?
  9. Dec 31, 2011 at 12:05 PM
    Anthony250
    Anthony
    Rialto CA
    Think so , not exactly sure its not my quad.
