Yikes! Expected 3" Got 4" w / Dakars
Discussion in 'Suspension' started by woodyc, Feb 8, 2015.
  1. Feb 8, 2015 at 4:06 PM
    woodyc
    woodyc [OP] Well-Known Member
    Craig
    Oceanside, CA
    2014 Access Cab 4x4 TRD
    Sway Away 2.5 " Coilovers Sway Away rear shocks Dakar rear leafs (3rd leaf removed) Snug Top Sport Highliner Shell Thule Racks Toyota Bed Mat Weather Tech Floor Liners
    Wow, I had my Dakars installed the other day and they are giving me 4" of lift even with my shell. I can barely get into the garage with about 1 finger width of clearance. I'm getting a little vibration when I start off up to about 15 mph. 3 deg axle shims installed also. Here's a before and after pic.
  2. Feb 8, 2015 at 4:24 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Were they + , + ?
  3. Feb 8, 2015 at 4:42 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    How many miles you got on them? Mine sat ~4" when first installed but after the ~15 mile drive home had settled down to 3". If you havent driven it around much or over bumps try doing that a bit to see what happens
  4. Feb 8, 2015 at 5:40 PM
    woodyc
    Craig
    Oceanside, CA
    They have a minus sign right by the arrow pointing to the front
  5. Feb 8, 2015 at 5:42 PM
    woodyc
    Craig
    Oceanside, CA
    Maybe about 75 miles on them so far. I always aim for the bumps now to see if they'll settle.
  6. Feb 8, 2015 at 5:42 PM
    OZ-T
    Peter North
    British Columbia
    Interesting
    As above if you just installed them they should settle
  7. Feb 8, 2015 at 5:44 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Looks like your original leafs were sagging pretty good as well.
  8. Feb 8, 2015 at 5:46 PM
    OZ-T
    Peter North
    British Columbia
    Good point
    What's the hub to fender measurement on the rear OP ?
  9. Feb 8, 2015 at 5:54 PM
    woodyc
    Craig
    Oceanside, CA
    Current Hub to Fender Driver side rear is 24 7/8" w/full tank of gas . The shell dropped the rear by about 1/2 inch or so with stock springs (just an estimate)
  10. Feb 8, 2015 at 5:56 PM
    woodyc
    Craig
    Oceanside, CA
    I do like the way the Dakar's feel though. Not as harsh as the stock set up. I have Sway-Away shocks also.
  11. Feb 8, 2015 at 6:02 PM
    Aerial Tacoma
    Aerial Tacoma Well-Known Member
    Andre
    Kodiak Ak
    2010 TRD Off Road Access Cab
    TRD Cold Air Intake, TRD Catback, Original HomerTaco Raptor Grill, TRD Trail Teams "Black", Duratrac 265/75/16, ALL PRO apex rear bumper, Retrofits W/ BHLM halos and deamon eyes
    Do u have to SAW 2.0's in the back. Also u running the SAW 1" blocks?
  12. Feb 8, 2015 at 6:05 PM
    woodyc
    Craig
    Oceanside, CA
    Yes, Sway Away 2.0s and no blocks
  13. Feb 8, 2015 at 6:07 PM
    woodyc
    Craig
    Oceanside, CA
    I did install the 3 deg shims though, I guess they are contributing to a little of the lift.
