yota243 turbo build
Discussion in '2nd Gen. Builds (2005-2015)' started by yota243, Jun 12, 2014.
  1. Mar 9, 2017 at 4:57 PM
    #321
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Very awesome. Congrats. Hopefully, I can get my mapecu3 installed this weekend. I finished building the harness last night.
  2. Mar 9, 2017 at 5:00 PM
    #322
    yota243
    yota243 [OP] Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Good luck man super stoked to swap injectors and get boostin
  3. Mar 9, 2017 at 5:02 PM
    #323
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    :burnrubber:
  4. Mar 9, 2017 at 5:03 PM
    #324
    ChadsPride
    Sponsored by TacomaWorld.com
    Damn she's nasty
  5. Mar 9, 2017 at 5:04 PM
    #325
    yota243
    E.J.
    north Alabama
    I guess the alternator had a lot of catching up to do with it not really running in a couple weeks
    ChadsPride[QUOTED] likes this.
  6. Mar 9, 2017 at 5:18 PM
    #326
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    So what was wrong, or different with your setup/file/map, versus MadTaco's?
    Not even my truck, but thank you so much for coming to the rescue Mike! :cheers:
    Super excited to see it idling and running. :woot:
  7. Mar 9, 2017 at 5:21 PM
    #327
    yota243
    E.J.
    north Alabama
    Well to put it as simply as i can understand it, his worked and mine didnt:proposetoast:
    ChadsPride likes this.
  8. Mar 9, 2017 at 5:30 PM
    #328
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Fair enough. Lol.
    Are those the stock injectors, or larger?
    ChadsPride and yota243[OP] like this.
  9. Mar 9, 2017 at 5:31 PM
    #329
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I'm glad to hear you've got it running!
  10. Mar 9, 2017 at 5:32 PM
    #330
    yota243
    E.J.
    north Alabama
    Stockers. i do have the 61# in the truck... But in the back seat
  11. Mar 9, 2017 at 5:32 PM
    #331
    yota243
    E.J.
    north Alabama
    Me too!!!!
  12. Mar 9, 2017 at 5:33 PM
    #332
    yota243
    E.J.
    north Alabama
    @MadTaco461 replace everyone's "you" with ur name as u read all this
    MadTaco461 and ChadsPride like this.
  13. Mar 9, 2017 at 5:34 PM
    #333
    boostedka
    James
    NM
    ThTs gotta be such a relieving feeling. What size injectors are you installing?
  14. Mar 9, 2017 at 5:34 PM
    #334
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    That old fuel map pissed it off until it trimmed back to normal.
    When you get boostin. You can grab the afr adjust table from the urd 7th injector map.
    yota243[OP] and ChadsPride like this.
  15. Mar 9, 2017 at 5:35 PM
    #335
    yota243
    E.J.
    north Alabama
    The 61# from urd
    boostedka[QUOTED] and ChadsPride like this.
  16. Mar 9, 2017 at 5:37 PM
    #336
    MadTaco461
    CA
    Kinda stock
    Get used to loading maps and running logs before you change injectors. Wire in your afr gauge too so you can log all that.
    yota243[OP], Torspd and ChadsPride like this.
  17. Mar 9, 2017 at 5:38 PM
    #337
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What he said.
  18. Mar 9, 2017 at 6:32 PM
    #338
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    This must have been such a wonderful feeling. Congratulations bro!
  19. Mar 15, 2017 at 5:20 AM
    #339
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  20. Mar 15, 2017 at 5:23 AM
    #340
    yota243
    E.J.
    north Alabama
    drove about 350 miles or so on mike's tune and everything is running good. cel did come on for 02 sensors even tho I have the sims, I cleared the codes with the torque app but they came back in about 50 miles, so I'm gonna unplug them and plug them back in and see what happens
    KelticAngel and ChadsPride like this.
