yota243 turbo build
Discussion in '2nd Gen. Builds (2005-2015)' started by yota243, Jun 12, 2014.
  1. Dec 13, 2017 at 12:12 PM
    #561
    yota243
    yota243 [OP] Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    :humble:but for real you should check out some other guys 1 gr turbo stuff, @Torspd is the Godfather of turbo 1gr and has put more blood sweat and tears in than anyone else I would venture to say. he knows the platform forwards and backwards and you can take what he says for gospel. I'm more or less just poking and hoping with a halfway general idea of whats going on because of the real pioneers. (I've noticed your activity in my thread for the past couple days and was wondering when you were gonna speak up haha) before you start buying stuff, check out the turbo bs thread and get a good feel for stuff over there cuz there is a ton of knowledge accumulated over there. also there are a few things that I wound up not using or replacing, although most of which is discussed in here but feel free to ask before you start throwing cash around.
  2. Dec 13, 2017 at 12:19 PM
    #562
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Words of wisdom.
  3. Dec 13, 2017 at 12:20 PM
    #563
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    ooopss
    yota243[OP] likes this.
  4. Dec 13, 2017 at 12:21 PM
    #564
    wheeliest
    Json
    TMPE AZ
    oh crap thought i was in turbo BS thead.
    BassAckwards likes this.
  5. Dec 13, 2017 at 12:21 PM
    #565
    yota243
    E.J.
    north Alabama
    something about Edison and several light bulbs that didn't work seems fitting
    dirty deeds likes this.
  6. Dec 13, 2017 at 12:21 PM
    #566
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well those skills will place you in the adavnced beginners club. Cheater. :p
  7. Dec 13, 2017 at 12:22 PM
    #567
    yota243
    E.J.
    north Alabama
    haha not sure if that is some kinda joke or something but it is a turbo thread with lots of bs so call a spade a spade I suppose
  8. Dec 13, 2017 at 12:24 PM
    #568
    wheeliest
    Json
    TMPE AZ
    No, I wasn't trying to hi-jack your build.. I get notifications for you're build thread and turbo BS as i view them often.. and thought my first post was in turbo BS thread (i'm distracted with my work at the moment and TW)
  9. Dec 13, 2017 at 12:28 PM
    #569
    wheeliest
    Json
    TMPE AZ
    Maybe I missed it, did you buy the speed daddy headers @yota243 ?
  10. Dec 13, 2017 at 12:30 PM
    #570
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    After seeing the last 2 vids of 20-80 mph...I'm sold!
    Time to start saving up for a 2.7 kit!
  11. Dec 13, 2017 at 12:31 PM
    #571
    yota243
    E.J.
    north Alabama
    yessir I did; there is a link to them in the "product discussed in this thread" down below as there is for a good bit of the stuff I used (and a few of the things I didn't use haha)
  12. Dec 13, 2017 at 12:33 PM
    #572
    yota243
    E.J.
    north Alabama
    @dirtdigginjoe you give a brotha the hook up?
    dirty deeds[QUOTED] likes this.
  13. Dec 13, 2017 at 1:08 PM
    #573
    dirty deeds
    Nick
    Eastern KY
    I know these two words realistically don't belong together...
    But I want the cheapest options possible with daily dependability. Low boost application
    ChadsPride likes this.
  14. Dec 13, 2017 at 1:11 PM
    #574
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    You can get the manifold and Downpipe cheap, but the rest should not be skimped on if you want reliability
  15. Dec 13, 2017 at 1:17 PM
    #575
    dirty deeds
    Nick
    Eastern KY
    Somewhere, I found a reliable <7psi kit for under $1k. I'd have to dig through my chrome history to find it.
    ChadsPride and BassAckwards like this.
  16. Dec 13, 2017 at 1:22 PM
    #576
    dirty deeds
    Nick
    Eastern KY
  17. Dec 13, 2017 at 1:24 PM
    #577
    MrCrowntown
    Alyn
    Ky
    Probably the Ozboost kit. @dirtdigginjoe can source the manifold and downpipe that Ozboost uses, directly from the supplier. Then you can get a good turbo from somewhere else as well as all charge piping.
  18. Dec 13, 2017 at 1:33 PM
    #578
    yota243
    E.J.
    north Alabama
    those are for the 3rz not the 2tr. like @MrCrowntown said the ozboost manifold can be out sourced with down pipe for like $400 and the rest of that kit is pretty much crap and needs to be replaced anyway; on the cheapest end with minimal fabrication, you could find an internally wastegated t28 turbo (I assume you can get a pretty good one for less than 1k) and then a universal intercooler kit and a few extra reducers and couplers and stuff for around $200 and have that "kit" but a lot better set up imo for ~$1500 and then upgrade your fuel system and get a way to tune it, I would say you could get into a well put together set up for ~$3k with a little elbow grease and ingenuity.
  19. Dec 13, 2017 at 1:40 PM
    #579
    dirty deeds
    Nick
    Eastern KY
    Oops! Guess I should get a v6 motor haha!
  20. Dec 13, 2017 at 1:40 PM
    #580
    dirty deeds
    Nick
    Eastern KY
    That would be most excellent! I like better pricing
