yota243 turbo build
Discussion in '2nd Gen. Builds (2005-2015)' started by yota243, Jun 12, 2014.
  1. Jan 12, 2017 at 8:06 AM
    #161
    ChadsPride
    Sponsored by TacomaWorld.com
  2. Jan 12, 2017 at 8:09 AM
    #162
    yota243
    yota243 [OP] Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    ChadsPride likes this.
  3. Jan 12, 2017 at 8:19 AM
    #163
    yota243
    E.J.
    north Alabama
    Meat and potatoes from thmotorsports.com
    BorgWarner BorgWarner Airwerks Turbo - S200SX Series (177268)
    S200SX Complete Turbo
    Bearing Housing Material : Cast Iron
    Comp Wheel Inducer (in) : 2.2 (55.8mm)
    Comp Wheel OD (in) : 3
    HP Range : 220-580
    Turbine Config : VTF
    Turbine Housing A/R : 1.22
    Turbine Housing Inlet : T4 Bolt Pattern / T3 Volute Opening
    Turbine Wheel Exducer (in) : 2.42 (61mm)
    Turbine Wheel OD (in) : 2.74 (70mm) 1 $568.41 $568.41
  4. Jan 12, 2017 at 8:25 AM
    #164
    yota243
    E.J.
    north Alabama
  5. Jan 12, 2017 at 8:32 AM
    #165
    yota243
    E.J.
    north Alabama
    urdusa.com
    Products
    Base Final
    6 x 61lb Mulit-Fuel Fuel Injector for 1GR-FE
    Option's $54.95 $329.70
    1 x URD 2005+ Tacoma V6, Fuel Pump/Filter Upgrade Kit
    Option's
    *Select Your Fuel Pump : DeatschWerks 255 LPH Pump
    + $5.00 $165.00 $170.00
    6 x Injector Harness Adapter - 1GR-FE to Bosch/Lucas (EV-1)
    Option's $11.99 $71.94
    1 x URD Rear O2 Simulator, 1GR-FE 4.0L V6 Dual Channel
    Option's $149.00 $149.
  6. Jan 12, 2017 at 8:37 AM
    #166
    yota243
    E.J.
    north Alabama
    himni-racing.com
    1 ea. Borg Warner S200SX, S300SX3 V-Band KIT - Stainless
    • Select Flange Size - For 3.50" OD Exhaust Tube, Mild Carbon Steel
    $43.90
    (could have went with the 3" for $10 more and not had the reducer mentioned in the ebay post)
  7. Jan 12, 2017 at 8:41 AM
    #167
    yota243
    E.J.
    north Alabama
    I think that's it so far and all that is left if the mapecu3 $500 at groupbuy rate and afr module for the mapecu3 that is ~$150
  8. Jan 12, 2017 at 9:13 AM
    #168
    yota243
    E.J.
    north Alabama
    ebay ~ $965.5 (-~90 for what I bought I didn't need/have to)
    yonaka= $259 (-$33)
    thmotorsports ~ $569
    Amazon ~ $80
    urd ~ $721 (+~$650 for ecu and module to come soon!!!)
    and himni-racing ~ $44
    total spent so is ~$2640; should have been ~$2516 if I knew more of what I was doing, and total project should come in at just under $3300 (should have been ~$3166) also there were some s&h charges on some of that (all on ebay was calculated into the total but the others may have added up to $50)
    I'm sure that some of the ebay stuff is questionable at best and I may have to replace some of it but hopefully not:fingerscrossed:
  9. Jan 12, 2017 at 9:26 AM
    #169
    yota243
    E.J.
    north Alabama
    oh I have also bought about $50 worth of beer for my helpers and refilled an argon bottle ($18) and gave the main fabricator guy $100 (he didn't ask for it but he has help tremendously in those tight bend low real-estate areas), and I'm making the other guy two holsters since he has let me use his shop for like 4 months now, so still should come in under $3500 haha,
    wheeliest, Nickel and ChadsPride like this.
  10. Jan 12, 2017 at 10:18 AM
    #170
    Getoutthere
    Getoutthere Well-Known Member
    Seth
    Grand Haven Michigan
    2007 white Tacoma trd offroad
    Total chaos upper control arms. Stealth custom wheels. KO2’s
    Boost!
    ChadsPride and yota243[OP] like this.
  11. Jan 12, 2017 at 1:16 PM
    #171
    yota243
    E.J.
    north Alabama
  12. Jan 12, 2017 at 5:08 PM
    #172
    ChadsPride
    She's driving now???
    yota243[OP] likes this.
  13. Jan 12, 2017 at 5:11 PM
    #173
    yota243
    E.J.
    north Alabama
    Na. Havent got to work on it in a week:(
    ChadsPride[QUOTED] likes this.
  14. Jan 13, 2017 at 5:43 AM
    #174
    yota243
    E.J.
    north Alabama
    test
  15. Jan 13, 2017 at 5:43 AM
    #175
    ChadsPride
    bump
  16. Jan 13, 2017 at 12:33 PM
    #176
    yota243
    E.J.
    north Alabama
    goals
    Nickel, ChadsPride and akkyle like this.
  17. Jan 13, 2017 at 1:11 PM
    #177
    ChadsPride
  18. Jan 13, 2017 at 9:09 PM
    #178
    yota243
    E.J.
    north Alabama
    Fuel pump back in, fuel filter in (kinda sketchy had to heat it with a heat gun so i watched with a fire extinguisher while my buddy heated it up haha) and... Battery was dead so popped the charger on and it fired up and ran. Gonna try and get it back on the road this week
    stronghammer and ChadsPride like this.
  19. Jan 14, 2017 at 7:33 AM
    #179
    ChadsPride
  20. Jan 16, 2017 at 6:21 AM
    #180
    yota243
    E.J.
    north Alabama
    down pipe is done! there was no way to get a vband on the bottom side and still get it to go thru the lack of room I had to work with, so we worked it till it pointed str8 back and will put an exhaust clamp on the muffler so that everything will go where it needs to. still need another oil feed fitting (BorgWarner has a threaded inlet so the universal feed I bought wouldn't work without drilling and tapping) sooooo close now
