Yotamafia kit or Old Man Emu (suspension/lift)?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BradleyS, Jul 30, 2022.
  1. Aug 4, 2022 at 5:23 PM
    sonoran
    sonoran Big Loop
    Brob
    Flagstaffrica, AZ
    Tacoma 4X4 3RZ
    Tires: BF Goodrich TA KO2 235/85-16 Matching Spare (in rotation) Rear Suspension: King 2.5 shocks Custom Alcan springs OME greaseable shackles Front Suspension: King 2.5 coil overs Total Chaos UCAs New OEM LCAs Total Chaos Steering knuckle gussets Total Chaos Steering rack bushings Rear Diff: ARB locker (Zuk-Built diff) ARB HD Compressor Rear diff breather extended Armor: Custom full-coverage skid plates Stubbs sliders CBI rear bumper CBI Frame plates Engine: 3RZ Custom over leaf spring exhaust LCE Heavy Flywheel, Pro clutch LCE Stage 1 Head LCE Stage 1 Cams LCE Balance Shaft Delete Bed: Flip-PAC Camper Spray-in bed liner Footman’s loops Canyon Cooler KIST bottle opener Recovery: Custom and very complete tool/service kit including angle grinder and impact HiLift (I know how to use it) and/or Solo skid floor jack depending on trip Glock e-tool (shovel) Strap Interior: Fire Extinguisher Saddle Blanket seat cover Alpine sound Exterior: Anza Headlights WeatherTech wind deflectors “One Less Sprinter” bumper sticker
    I drive a lot of off-road and after 15-years of replacing OME and Bilstein shocks every few years I got Kings on all 4 corners. It’s a financial hit up front but the performance is in a different league! Totally stable on washboards, takes pothole hits at 70MPH, they don’t fade, I can revalve to my liking and rebuild when necessary. They have 40k/mi on them now and still feel fresh.
    BradleyS[OP] and Nessal like this.
  2. Aug 4, 2022 at 8:54 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    My 2003 DC had a previous owner’s lift kit (Bilsteins, SPC control arms, blocks on rear spring U-bolts) and FJ Cruiser 17" wheels when I got it in 2017. I converted to Old Man Emu kit and to the OEM wheels (from my 2001, with BFG A/T 235/85-16). My shop replaced the SPC control arms with aftermarket Moog OEM style because they couldn't get good alignment with the SPC control arms. IIRC. The OME lift kit at about 2" was an inch or so less than the previous owner was running with his setup. The SPC control arms looked pretty well made, I'll note.
    I installed the Old Man Emu OMETACO4HKS kit on the truck I have now. Nitrocharger Sport shocks in the kits today, compared to old Nitrochargers on my earlier OME installs. I'm perfectly fine with the Sports. That particular kit number includes the 2881 heavy front springs and medium rears without extra leaf. There's always some weight over the rear axle; I ran a Mountain Top (Denmark) aluminum tonneau with my first kit, and an ARE canopy with the current truck.
    That particular image of my white 2003 DC was taken at the Wedge Overlook in the San Rafael Swell of central Utah, @BradleyS. My 2002 and 2015 Tacomas, however, have spent plenty of time in New Mexico, and with luck I'll relocate to northern NM over the next two years.
    BradleyS[QUOTED][OP] likes this.
  3. Aug 4, 2022 at 10:07 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    May I just say I appreciate how well built the drawers are. That looks amazing, almost factory built. Well done.
    BradleyS[OP] and sonoran like this.
  4. Aug 5, 2022 at 2:09 AM
    Lil Puke
    Lil Puke Well-Known Member
    Oregon
    ‘99 Taco
    crumbs between seat cushions, junk in glove box, center console mostly full
    running the 881’s and RA leaf pack. 48lb bumper up front. Canopy, BedSlide, and toolbox on the back end.
  5. Aug 6, 2022 at 12:43 PM
    UncleStan
    UncleStan Well-Known Member
    02 Double cab Tacoma
    Anyone with the OME setup need to replace their UCA's?
    BradleyS[OP] likes this.
  6. Aug 6, 2022 at 5:27 PM
    4xdog
    Santa Fe, NM
    My shop took OFF SPC control arms put on by the previous owner for the lift he was running and went back to OEM style for the OME kit I put on to get proper alignment.
    I put OME on my XJ Cherokee, a previous Gen 1 Tacoma, and my Gen 2 Tacoma -- all with stock upper control arms and all with excellent alignment for the approx 2" lift they all got.
    So I'd say it would be unlikely anyone would need to change stock upper control arms.
  7. Aug 8, 2022 at 3:24 PM
    BradleyS
    BradleyS [OP] Well-Known Member
    Bradley
    03 Toyota Tacoma TRD
    None, yet.
    Glad to hear you're happy with that set up. I'm still on the fence as far as Billstein or OME shocks. OME front coil springs and replacement rear leaf pack for sure. I think I may go for the SPC UCA's if I do the Billsteins. Thx for the info!
  8. Aug 8, 2022 at 3:27 PM
    BradleyS
    Bradley
    None, yet.
    I've been told by some friends Kings are the sh#@. I like your description of how they handle. If you don't mind, about how much for them? Also, between Billsteins 5100 or OME nitrochargers, which one would you recommend? Many thx! Nice rig! and I bet there's a lot of terrain around you to explore.
  9. Aug 8, 2022 at 3:31 PM
    BradleyS
    Bradley
    None, yet.
    yerah the SPC UCA's look pretty bomber. 10-4 on the 2881's. Man UT looks great! NM has similar looks. When you make it over this way lemme know. I'm in North NM, and have been for some time. This truck I got a couple years back is really helping me to get out and explore. That's interesting about the SPC UCA's not really jiving with the OME set up. Thx for the info, much appreciated!
  10. Aug 8, 2022 at 3:33 PM
    BradleyS
    Bradley
    None, yet.
    Thx! From a youtube build I found. From 'paskmakes'. You can find it there. I improvised of course, gotta say they took quite a bit of work. but worth it.
  11. Aug 8, 2022 at 3:34 PM
    BradleyS
    Bradley
    None, yet.
    been wondering the same. According to Yotamafia, they advise to get the SPC UCA's with the Billstein kit (I think is about .5"/half inch taller kit).
  12. Aug 8, 2022 at 3:38 PM
    BradleyS
    Bradley
    None, yet.
    Thx for the info 4XDog, been wondering about this, as well as someone above (think you saw). When I asked Yotamafia about the Billstein kit they said it would be advisable to replace with SPC UCA's (as an option on the site). Someone above also said that they replaced the SPC UCA's back to more OEM style. Thx for info. I appreciate you guys.
