YotaMatt's 2012 Taco Build
Discussion in '2nd Gen. Builds (2005-2015)' started by YotaMatt, May 4, 2012.
  1. Oct 12, 2012 at 1:53 PM
    #81
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
    :drool: mud grapplers!!!!!
  2. Oct 13, 2012 at 10:08 AM
    #82
    YotaMatt
    YotaMatt [OP] Livin Low, Ridin High
    West Point VA
    12 PreRunner DC TRD Sport
    Spidertraxx 1.25" spacers in front and rear, 4" Maxtrac Spindles,Billy 5100s at 0", OME 885 Springs, 1/4" top spacer on both sides, 1.5" AAL, 3" Block, 1.5" 4crawler driveshaft spacer, 17x9 XD Spys with 35x12.50 Nitto Mud Grapplers, Magnaflow offroad Stainless Exhaust, Volant Intake with scoop,Camo emblems, BHLM, Tinted tailights, Anytime fog mod,Alpine Type R 12, Kicker 1000 watt amp,600 watt 4 channel memphis and all memphis components, 35%tint front all the rest at 5%, Hella 500s with sylvania zxe bulbs, sylvania zxe headlights, sylvania zxe fogs, Weathertech digi fits, flyzeye blue/white, LED map dome license plate lights, Redline hood struts, Tailgate EZ Down, Custom TRD Camo Browning Edition Bedsides, Camo wet okoles, Ridgid Dually bed lights, SOS Concepts Tire Carrier
    Aren't they just the best!!! Love the sound...and they look so damn good too
  3. Oct 13, 2012 at 8:07 PM
    #83
    COMAtose HI
    2012 TRD SPORT 4x4
  4. Oct 15, 2012 at 11:00 AM
    #84
    HanleesTacoma
    HanleesTacoma Well-Known Member
    NorCal
    2013 MGM Prerunner V6 SR5
    Window Deflectors with (Tacoma) Logo Visor Yakima Locking Bike Rack Mount N-Fab Nerf drop step bars 2" tube Powder-coated Black 4" Maxtrac Spindles Steel braided extended (front) brake lines Bilstein 5100 Adjustable Front Shocks 1.6" Eibach Coil Springs 3-4" Bilstein 5100 Extended Rear Shocks 2" Toytec Progressive 3 Leaf AAL (made by Deaver Leaf Springs) 2" Rear Blocks Steel braided extended (rear) brake lines 1.5" rear wheel spacers Black TRD NORCAL Bedside Vinly Stickers from Sockeye Monkey 10g Powder-coated BLACK Skid Plate with TRD Logo from Matt123 (Black) Plastidip emblems Go Rhino Xtreme Rack Sport Bar Lightning Series (Black) 4" 18watt CREE LED Flood/Spot LED Work light (x4) Powerbass BTA8 150W 8" bass tube with built-in amp plus remote control 32" 180W CREE LED Bumper Light Bar Flood/Spot combo Bully Matte Black Exhaust Tip. Inlet diameter: 2.875", Outlet diameter:3.75", length 9" Redline Hood Struts (Black) Plus kit True Edge (Black) Riveted Textured Fender Flares
    Suspension:
    Bilstein 5100s on front set at .85"
    Eibach springs 1.6"
    4" Maxtrac Spindles
    1.5" AAL and 2" Block
    Pro Comp Shocks in rear for 4"-6" lift
    Extended Stainless Brake Lines Front and Rear
    Custom ABS sensor wire drop bracket​
    RE: Hey brother Matt!. pardon my ignorance but I'm really new at this..Quick question for you about the custom ABS wire drop bracket..where can I buy this?. Toytec?. also will I need 4 for both front and rear? or just rear?. I'd apreciate any input..
  5. Oct 15, 2012 at 11:59 AM
    #85
    YotaMatt
    West Point VA
    No I made it myself...at full droop in rear it was pulling on the abs lines really hard so I unbolted the bracket from frame and then made bracket. I installed it where factory bracket was and then bolted factory bracket to new one.
  6. Oct 15, 2012 at 12:13 PM
    #86
    HanleesTacoma
    NorCal
    I see!. I will inspect and look at it today..maybe I should bring this up to my mechanic before doing the install this way, we can plan ahead and do it right the first time. Thanks again for the insight!. really apprecite it!.
  7. Oct 17, 2012 at 11:21 AM
    #87
    YotaMatt
    West Point VA
    Yea I'm kind of surprised no one makes one..as I only have 3.5" of lift in rear with shocks designed for 4-6" of lift and at full droop the abs lines were pulling really hard
  8. Oct 22, 2012 at 9:38 AM
    #88
    HanleesTacoma
    NorCal
    Looked and inspected it..you are absolutely right! a few more inches and this can definitely be a problem. Yeah suprisingly no one makes it..but can be easily customized. Thanks for the heads-up!. Btw, did you installed 1.25" spidertrax wheel spacers on the front too?.
  9. Oct 24, 2012 at 12:56 AM
    #89
    YotaMatt
    West Point VA
    I did but removed them from front after i did spindles...Way to wide in front!!
  10. Oct 24, 2012 at 10:53 AM
    #90
    HanleesTacoma
    NorCal
    Got it!. That saves me an extra $99 i can buy for other stuff. So after installing spindles, stock wheels and tires will no longer fit right?. Reason i ask is i'm undecided to keep them or sell it.
  11. Oct 24, 2012 at 11:15 AM
    #91
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Will someone message me and get me started on how to create my own build page. Thanks, Justin
  12. Oct 24, 2012 at 1:19 PM
    #92
    YotaMatt
    West Point VA
    Correct stock wheels will not fit unless u have spacers
  13. Oct 24, 2012 at 2:48 PM
    #93
    HanleesTacoma
    NorCal
    Copy. Thx!
  14. Nov 2, 2012 at 4:17 PM
    #94
    Fightman80
    Fightman80 Well-Known Member
    Capreol Ontario Canada
    05 TRD DCLB Speedway Blue
    Tinted Tail lights, Nerb Bars, Tonneau Cover, Vent Visors, Hood Deflector, Foglight/highbeam mod, Custom homemade grill, Carbon Fibre Interior.
    Nice rig man! Any idea if using spindles to lift a 4X4 would work... or is this only something that can be done with a PreRunner?? Check out my build sometime, let me know what you think! :)
  15. Nov 2, 2012 at 4:23 PM
    #95
    YotaMatt
    West Point VA
    only for prerunner....unless u removed your axles and differential :rolleyes:
  16. Nov 2, 2012 at 8:39 PM
    #96
    Fightman80
    Kinda figured... oh well... lol! Thanks for the reply man....
  17. Nov 18, 2012 at 9:11 AM
    #97
    bdawson0801
    bdawson0801 Member
    Brett
    Boise, ID
    2012 TRD Sport DC
    Incredible build man! One of the best I've seen. I know you're not running the ToyTec ULK with the 285 Nitto's anymore but when you were did you have to do any trimming? I'm kind of a newbie and would rather not do any of my own personal modifications haha
  18. Nov 18, 2012 at 4:55 PM
    #98
    YotaMatt
    West Point VA
    I actually had the 3" toytec spacer....i had no rub with the 285s, sport wheels, and 1.25" spacers....when i went to tundra wheels they rubbed cuz more offset
  19. Nov 19, 2012 at 4:06 PM
    #99
    jjhitchen
    jjhitchen Relentless
    Joel
    Arroyo Grande, CA
    2012 4x4 V6
    100% stock Tacoma
    looks sweet man, attempting to resemble that soon.
  20. Nov 19, 2012 at 10:26 PM
    #100
    YotaMatt
    West Point VA
    thanks! amazing how much its changed since march when i bought it :cool:
