YotaWerx Tuning Services and Development
Discussion in 'Performance and Tuning' started by mZiggy, Jul 31, 2021.
  1. May 20, 2022 at 7:28 AM
    #221
    mZiggy
    mZiggy [OP] Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Where and how it saves is dictated by your default or set settings. It should prompt you to choose where you want to save it, but if not, it will likely go to your Downloads folder. If not, open a fresh file explorer window (folder icon) and it should show up in a list of Recent files. Right click on it and choose Open File Location to navigate to wherever it is and then move it wherever you'd like to from there.
    From there, when in the VFtuner Flash Tool, you can navigate to the file when selecting Select Calibration and select the file.
  2. May 20, 2022 at 7:34 AM
    #222
    Truky!
    Truky! Well-Known Member
    Satellite Beach FL
    2021 TRD Offroad
    Ok, I'll get that done today...I'm definitely baby stepping this
  3. May 20, 2022 at 8:03 AM
    #223
    Double Down
    Double Down Well-Known Member
    Colorado Springs, CO
    '23 ACLB TRD OR
    Magnuson, King, OVRLND, Deaver, Method, BFG
    FYI for those on older ECU IDs - I reached out to Ryan at Magnuson and had a new tune file for the new ECU ID from them in less than 12 hours. Pretty painless process.
    Murd3rd and mZiggy[OP] like this.
  4. May 20, 2022 at 8:08 AM
    #224
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    OK,
    That was my next question,
    I got the file download from Ryan this morning, downloaded it, saved it to my VFTuner, do I now flash that new file to my truck?
    Will that change my 04C20 to the most up to date configuration, that will allow me to install the YotaWerks tune?
  5. May 20, 2022 at 8:16 AM
    #225
    mZiggy
    Marc
    No. You still need to update your ecu ID from 04C20 to 04C21 using Toyota Techstream.
    VFTuner has an updater within the flash tool, but I don't know if it works or has been tested by anyone here.
    @tonered might know...
    either way, idk if EROM tunes create an exception when using it like they do for using TIS
  6. May 20, 2022 at 8:25 AM
    #226
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Do the TS upgrade for your ECU ID (04C20 to 04C21) first if you are not currently on a VFTuner "Tune." Otherwise you will have to flash to a stock tune (non-EROM V...tune) and then to the new ECU ID and then to the Maggy/Yotawerx tune. @mZiggy and @tonered have mentioned and can explain further.
  7. May 20, 2022 at 8:30 AM
    #227
    mZiggy
    Marc
    If you are on an EROM file (Magnuson SC, YotaWerx SC), do the following:
    Flash a non-EROM tune for your current ECU ID. Stock tune is simplest to explain, so just use that. Any non EROM tune FOR YOUR CURRENT ECU ID will do though.
    Update ECU ID via Techstream.
    Flash Magnuson supercharger or YotaWerx supercharger tune for NEW ECU ID.
  8. May 20, 2022 at 9:19 AM
    #228
    aleja_333
    aleja_333 Well-Known Member
    Colorado
    19’ Pro AT, 5.29's, Fox 2.5 RR, Alcan, PowerBrake
    Magnuson, Stryker tune, C4, Archive Garage HH, Alucab CC
    My truck is a 2019 AT, and it my ID is 8966304B3100. Based on @mZiggy post, I need to be on 04B33, correct?
    I have the free version of techstream installed but never used it before. Can I use the Maggy dongle to update my ECU ID using Techstream?
    Anyone has the step by step to update the ECU ID, trying not to brake the truck.
  9. May 20, 2022 at 9:22 AM
    #229
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Yes you can use the dongle supplied by Magnuson to update. All the info you need on how to flash is here https://www.tacomaworld.com/threads/ecu-tsb-update.562550/
    aleja_333[QUOTED] likes this.
  10. May 20, 2022 at 9:28 AM
    #230
    mZiggy
    Marc
    if you have the software installed, you don't even need to launch TIS to start. Just double click on the cuw file (update calibration file) and it'll automatically prompt the TIS Update Wizard to run. Follow the prompts and you'll be set.
    Follow the same precautions you would when flashing a tune WRT sources of voltage draw.
    Maggy kit owners should be aware that the pump for the air to water intercooler tends to come on and draw power when the ignition is on, even though the engine is off. This represents a source of potentially significant voltage draw.
    This is why all YW customers (NA and FI) get a helpful tune guide supplement document that covers basic flash procedure, steps to take to avoid ecu bricking, and ecu recovery procedure.
    aleja_333 likes this.
  11. May 20, 2022 at 9:35 AM
    #231
    aleja_333
    Colorado
    Is this the CUW I need?
  12. May 20, 2022 at 9:35 AM
    #232
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    Yes
  13. May 20, 2022 at 9:36 AM
    #233
    Murd3rd
    An easy remedy for the pump coming on is to just pull the fuse for it. Shouldn't take but a second.
    mZiggy[QUOTED][OP] likes this.
  14. May 20, 2022 at 9:38 AM
    #234
    aleja_333
    Colorado
    Is the battery charger absolutely necessary when flashing the ECU? It would be one more thing to buy. :(
  15. May 20, 2022 at 9:39 AM
    #235
    Supr4Lo
    Surprise, AZ
    That is one thing I've never been a fan of, having the coolant pump run with ignition on engine off. Not just for flashing but any situation.
  16. May 20, 2022 at 9:39 AM
    #236
    mZiggy
    Marc
    no, our testers frequently flash without a charger. If your voltage is a bit low, run the truck for a few minutes to bump it up a bit
  17. May 20, 2022 at 9:40 AM
    #237
    Murd3rd
    No, but if your voltage drops below the recommended voltage you can risk bricking the ECU. I leave mine on a battery tender (not as much amperage as a "charger") and it does just fine.
    GoldenBrew likes this.
  18. May 20, 2022 at 10:03 AM
    #238
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    OK guys, I'm thinking I've bitten off something I can't chew here, I don't know what Toyota techstream is, what an erom is....
    Zoey'sTaco likes this.
  19. May 20, 2022 at 12:45 PM
    #239
    GoldenBrew
    Golden, Colorado
    True. I just hook up the trickle charger because I simply don't want to experience Murhpy's Law - which would certainly happen if I let it. :boom:
    Murd3rd[QUOTED] likes this.
  20. May 20, 2022 at 12:50 PM
    #240
    GoldenBrew
    Golden, Colorado
    are you running the original Toyota tune or an aftermarket Tune. If it is original Toyota all you need to do is update the ECU ID via TS (TS is a toyota software the dealers use). If you don't feel comfortable doing the update find a Tuner near you and have them do it for you, or if you are experiencing the issues the ECU update addresses go to the Dealer with a copy of the TSB for the ECU update in-hand and have them flash the update for you.
    ??? @ktbell444 are you anywhere near Truky where he can catch up with you and get his ECU updated? Or know of a Tuner near him that can assist?
    ktbell444 likes this.
