YotaWerx Tuning Services and Development
Discussion in 'Performance and Tuning' started by mZiggy, Jul 31, 2021.
  1. May 3, 2022 at 11:59 AM
    #81
    aleja_333
    aleja_333 Well-Known Member
    Colorado
    19’ Pro AT, 5.29's, Fox 2.5 RR, Alcan, PowerBrake
    Magnuson, Stryker tune, C4, Archive Garage HH, Alucab CC
    I have an aftermarket tune that makes driving (shifting logic specifically) very enjoyable. I have added weight, lift, big tires, etc. etc. Going back to stock shifting logic it's a step back in my opinion and not something I want. I held buying the SC for months waiting for this tune to be released. I don't mind waiting a little more time for the YW tune.
    Sure I want the extra bit of boost from the SC but driving experience with the tune I have much better than having the SC and OEM shifting logic. For me at least.
    PapaRee and Supr4Lo[QUOTED] like this.
  2. May 5, 2022 at 2:14 PM
    #82
    nemith
    nemith Member
    Brandon
    2019 Tacoma Sport
    Borla Exhaust
    I was doing somewhat the same but I got tired of having the boxes take up space in my Garage so I put the SC on a couple weekends ago. I will say that what the SC brings it is almost negated by the horrible tune in regards to the slopping shifting at weird times. It seems just when you start to build boost it it taken away by a bad shift. I am anxiously await a new tune.
    @mZiggy Will there be an upgrade path for 90mm->87mm pulleys. buy the 90mm now and switch to 87mm for free/small charge?
  3. May 5, 2022 at 2:18 PM
    #83
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    It was talked about 2 pages back
  4. May 5, 2022 at 8:57 PM
    #84
    aleja_333
    Colorado
    I've been waiting since last year for this tune to arrive so waiting a little more is not going to make a difference. Luckily, I purposely waited on buying the SC until just a few weeks ago. That way I wouldn't get to install anxiety mode looking at the boxes every day in my garage.
    mZiggy[OP] and ktbell444 like this.
  5. May 6, 2022 at 4:58 AM
    #85
    mZiggy
    mZiggy [OP] Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    I'm trying to aim for a release date for the 90mm pulley of the 21st. Gotta get the tunes built across the various ecu's.
  6. May 7, 2022 at 9:19 AM
    #86
    mZiggy
    Marc
    UPDATE [sort of] on YotaWerx Tuning MagSC tune:
    Still trying to aim for a release date of May 21st for the 90mm pulley supercharger tune. Been spending long hours to get through building the tunes for the ecu versions, and I am also exploring the idea of two throttle response options.
    Some bugs with the datalogger with the recently updated VF1.6 software mean that the 87mm tune may be a slightly delayed, but shouldn't be much further behind still. The tune had been progressing alongside the 90mm tune and pretty much just needs verification with possible tweaking of AFR and ignition, followed by dyno day.
    VFTuner is aware of the datalogger bug and is working on a fix.
  7. May 7, 2022 at 8:11 PM
    #87
    mZiggy
    Marc
    Further update on the YotaWerx Tuning MagSC tune:
    EDITED to update introductory price duration upon launch.
    Price:
    Upon initial launch on May 21st, the introductory price for the 90mm Pulley tune for the first 12 hours will be $500USD. This will run from 0700 - 1900 MST.
    Following those 12 hours, it will become regular price of $700USD.
    Please be prepared to fill out, sign, and return the YotaWerx Tuning waiver prior to receiving the tune. Providing your vehicle's VIN is required. Failure to provide these items will result in YotaWerx Tuning declining to proceed further with the transaction. If these items are provided after the initial 12-hour window has expired, eligibility for the promotional pricing will be forfeit.
    This is set for the 90mm pulley, since that is the pulley size that comes with the Magnuson supercharger kit by default. Everyone should have the 90mm pulley, even if it was never installed due to wanting to run the 87mm pulley.
    During the tune release, orders will only be accepted via our email (yotawerxtuning@gmail.com). This will assist us in keeping track of customers and keeping inquiries in one place.
    The 87mm pulley tune will be an additional $50USD. Once released, it can be packaged with the 90mm option, but since they'll be getting released separately, existing 90mm customers can of course reach out to get it when released.
    We will accommodate requests for tire size, regear, and AGM settings. We already do so for several of our testers. Tunes will be available in gearlock versions as well (ECT + S-mode). As stated in the post above, we are also exploring two different throttle response options.
    Like on the NA side, updates to the tune made by YW will be made available to existing customers for free. If we announce an update, reach out to receive it.
    If you are running a snorkel, modification may be required. I don't know if this is the case for every snorkel brand, but the ones run by @SK808 and @virginiamarine were noted to require modification due to their design significantly restricting airflow, enough so that boost was severely limited, sometimes even non-existent. This is something we've noticed with some snorkels on the NA side as well.
    This community deserves a big thank you for the patience and support that has been given to YW. It sounds cliche but we really couldn't have reached this point without it. 10 testers from all over the US, literally hundreds of hours spent on every aspect of the tune... it's all come a long way from where we started out back in early October last year. Thank you.
  8. May 7, 2022 at 8:40 PM
    #88
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    Is this one of those things where I'm gunna have to stay up til midnight and send an email as the clock strikes midnight? Lmao!
    Will both throttle response options be available with a single purchase? Or how does that work? (I know it's still tentative, but just curious if more than one IS offered, how would it work)
  9. May 7, 2022 at 8:42 PM
    #89
    mZiggy
    Marc
    Lol we may end up doing a deposit system, although the result may be the same.
    Matt Sierra and Murd3rd[QUOTED] like this.
  10. May 7, 2022 at 9:13 PM
    #90
    mZiggy
    Marc
    Just saw this edit. If we do it, it'll be set up like a tune pack, sort of like how we do our NA tunes. So yes, both with a single purchase.
    Murd3rd[QUOTED] likes this.
  11. May 8, 2022 at 5:00 AM
    #91
    Zoey'sTaco
    Zoey'sTaco Art Jockey
    Noah
    Dirty Jersey
    2020 DCSB SR5, Daily, camper-hauler, blizzard chaser, rock bouncer, tool box
    6112/5160/Maggie SC Hammer Hangers Tom Woods 1 piece Shaft ARE-DCU ARE HD leafs Rear Seat delete
    how will payment work? PayPal?
    Murd3rd likes this.
  12. May 8, 2022 at 5:02 AM
    #92
    mZiggy
    Marc
    Yes.
    Murd3rd likes this.
  13. May 8, 2022 at 5:31 AM
    #93
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    @mZiggy Congratulations, to you, your team, and all of us !! Great news.
    Any possibility that you could change the opening discount to something like "all orders paid in full within the first hour, must include VIN, (VIN changes will cancel the discount)" or sim. even if this means jacking up the entry price $50?
    I have a feeling that there will be a real scramble, and I for one, will be disappointed if I get trampled by the crowed. By the look of some on this string, there is libel to be a fist fight amongst the crowd forming overnight at the door. :curls:
    mZiggy[OP] and Murd3rd like this.
  14. May 8, 2022 at 5:31 AM
    #94
    Zoey'sTaco
    Noah
    Dirty Jersey
    so how many folks have offered to send you 550 today?:spending::D:crapstorm:
    mZiggy[OP] and Pinchaser like this.
  15. May 8, 2022 at 5:38 AM
    #95
    Pinchaser
    Alan
    It crossed my mind to just send payment already; the only thing that stopped me is that @mZiggy has been such a stand up guy, that I fear it would just make him perform a whole lot of additional effort, sorting, communicating and refunding. He deserves better!
    That effort would be wasted, instead of building us more great Tunes.
    I will try to restrain myself. That is the most that I can commit to right now, "will Try".
    Zoey'sTaco and Murd3rd like this.
  16. May 8, 2022 at 5:47 AM
    #96
    Murd3rd
    Yeah, I don't wanna miss the discount either. I got funds now!
  17. May 8, 2022 at 5:58 AM
    #97
    mZiggy
    Marc
    This is a decent idea.
    I'm not sure if there's an ideal method. It occurred to me before to do some sort of deposit system, but I think the result will ultimately be the same. Still might do it, but that's why for the time being I was thinking I'd just announce the release date and that would give people enough advance notice. The same would probably have to happen for a deposit system.
    It also occurred to me to set a specific time based on my time zone, but not everyone may be available at that time, so that doesn't seem viable either.
    I'm certainly open to suggestions. Your additional suggested specifics aren't far off from what I'd planned to announce anyway. VIN and ECU ID/version will be required, failure to provide these up front will bump the individual because I cannot provide a tune without the info. I *could* be provided with a model year, but it won't be sufficient really.
    This is because originally I was thinking I would only support the most up-to-date ECU versions. However, I'm moving away from this because of rumors of increased chance of ECU bricking for a certain ECU version (unconfirmed if this has been fixed/addressed), a number of people who have expressed concern about not having their Magnuson tune to fall back on if necessary, and a number of people who have expressed unwillingness to update their ECU ID (due to concern about their ability to do so and worry that they will not receive an updated tune from Magnuson).
    So as a result, I'm building *several* tunes across several ECUs unfortunately. But this means that I won't be able to just get told "hey I want the tune, I have a 2020 AT." I need the ecu ID, because there's 3 ecu versions possible for just the '20 6AT.
    There are some ECU versions though that are so old/poor/outdated that I just refuse to support. Most notably, 2016-17, 04B10-11, probably B12 too, and 04B00-03
    Lol a handful or so have already sent in emails asking if they're in the first 5 or not for the promotion.
    The tunes with all the ecu versions could possibly be done by this upcoming weekend, but the wife made me promise that the weekend will be hers lol and it gives me additional time to ensure the tunes are built anyway.
    Pinchaser[QUOTED] and Murd3rd like this.
  18. May 8, 2022 at 6:00 AM
    #98
    mZiggy
    Marc
    I mean, if I open up a deposit option, I feel like I still need to give an announcement with a few days notice to people to be fair, particularly so that people who have already reached out don't feel slighted.
    Murd3rd likes this.
  19. May 8, 2022 at 6:03 AM
    #99
    mZiggy
    Marc
    Off topic from the immediate discussion, but @virginiamarine provided a photo of his boost gauge's recorded max boost from his dyno day/run:
  20. May 8, 2022 at 7:06 AM
    #100
    Pinchaser
    Alan
    Ohhh Nooooo (you hit a nerve). Where can i read about this? I suddenly have a very sinking feeling, as I just updated to 04B82 on my 2020. I never thought to check with you or Maggie, before the update; just followed what I had learned from miles of OVtuner thread (though I am not current on that). Hope this is not the one with potential troubles? Dang, does this mean that there are certain ECU's that Maggie cannot provide a tune for? I have the SC, but have not installed or asked for the Tune yet; installed exhaust and now working on gauges, then SC.
    Please tell me that up update was not a step backward!!!
    I also though that going back to stock tune is always an option (not to be mistaken, I do understand you can never go backward with the ECU version; hence my panic above).
