YotaWerx Tuning Services and Development
Discussion in 'Performance and Tuning' started by mZiggy, Jul 31, 2021.
  1. Apr 24, 2023 at 12:33 PM
    #1101
    microsnook
    microsnook Well-Known Member
    '20 TRD OR MGM MT
    I’ve just received the YW tune and I am enjoying it. I’m waiting for the gears to be installed and then it will be proper and ready for a final opinion.
    Runnin4Tacos even said they would flash the update for free when it’s released this year.
    mZiggy[OP] and GoldenBrew like this.
  2. May 3, 2023 at 9:54 AM
    #1102
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    so the blackhawk tune has a rev limiter higher than 6800?
  3. May 3, 2023 at 2:32 PM
    #1103
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    just a short report on the YotaWerx Stryker Tune: Finished a 1500-mile trip from base camp (Golden CO) to just west of Bozeman MT - one day of travel each way. I'm a believer in stops every few hours (if you are over 67 you will understand, and if not, well I remember those days) and driving 70 mph cause the truck likes it. Averaged 20 1/4 mpg which is pretty good if you know what face on into the wind in Wyoming is like. Plenty of power to and drove effortlessly. Nice job @mZiggy and the crew!
  4. May 12, 2023 at 4:18 PM
    #1104
    Louie2001
    Louie2001 Well-Known Member
    Louie
    Dallas, Texas
    2001 Tacoma TRD
    Front Fox 2.0 Coil-Over Shocks Rear Fox 2.0 Performance IFP Shocks FN Wheels Five Star -25mm Offset Cooper Discoverer STT Pro's 285/75R16
    Any luck on tunes for 1st gen 3.4 V6? @mZiggy
  5. May 12, 2023 at 9:58 PM
    #1105
    mZiggy
    mZiggy [OP] Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Some 5vz ECUs have become supported in-software, but we'd want a tester for any dev
  6. May 13, 2023 at 3:12 PM
    #1106
    calzonical
    calzonical Without the 2nd, there is no 1st.
    2018 Taco TRD OR DCSB A/T
    @mZiggy - Which ECUs? I have an 02 T4R 3.4L A/T
  7. May 13, 2023 at 7:02 PM
    #1107
    devinzz1
    devin
    2023 aclb trd or mt
    2002+ according to vftuners facebook
  8. May 13, 2023 at 7:32 PM
    #1108
    mZiggy
    Marc
    ^these are the 4 ECU IDs currently supported for the 5vz
    If you have an OBD code reader of some sort, most can identify ECU Calibration info. If you elect to do so, send me a PM with that or send us an email and we can explore tuning options. Options available to you will likely be limited however for the following reason: currently VFTuner's model/structure for tuning K-line ECUs is not very feasible financially except in one or two very specific methods/scenarios
    Louie2001 and solscooter like this.
  9. May 20, 2023 at 11:21 AM
    #1109
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    Can anyone help? I am trying to load an updated Striker tune, and get VF tuner up, connect to truck and verify ECM appears to succeed. then i cannot select calibration file without error. One file says it is not a .vfc file (though I can clearly see that it is), and the other says ERROR Access Violation at address 00C95171 in module 'vf Tuner.exe", Read of address FFFFFFFF8.
    I had decided to skip updating my VfTuner software, but with this problem I went and updated; same problem.
    Last time I did this is was no problem, hope someone can help.
  10. May 20, 2023 at 12:16 PM
    #1110
    mZiggy
    Marc
    Hello, happy to help you out.
    At face value I'd chalk this up to VFTuner "being VFTuner". I'll send you a message in our email thread.
    I'd consider restarting your laptop and software for starters. If this persists, I'll re-export your files, but oddities like this have been more prevalent over the course of the last several VFTuner updates unfortunately, and it seems to just be a frustrating quirk of the software.
  11. May 20, 2023 at 2:15 PM
    #1111
    Mcbelen
    Mcbelen Active Member
    Maynard
    2022 Electric Lime Green Tacoma TRD PRO ( Manual Transmission )
    Try uninstalling and reinstalling vf tuner software.
    try connecting your dongle to other usb ports of you laptop..
    Make sure laptop is connected to the wifi for internet.
    McFlysRide and mZiggy[OP] like this.
  12. May 21, 2023 at 1:31 PM
    #1112
    Pinchaser
    Alan
    OK,
    rebooted computer, no change, tried other USB ports before and after reboot, no change, wifi always available and VFTuner software was always happy to open, and to prepare ECM, just will not load calibration file.
    Interesting that it is happy to load any of the original Striker tunes, but will not load any tunes provided including the test tunes sent last fall, regarding CC surge. Since it will load the known good original tunes, I suspect a problem with the recent tunes, not the main software. I am questioning if it is worth uninstalling VFTuner and re-installing?
    It is certain that it will load the original Striker tunes, because i had been running a throttle limited version, and just not loaded the original Striker w GL, no problem. Test drive seems great.
    Is it worth uninstalling VFTuner?
  13. May 21, 2023 at 1:39 PM
    #1113
    mZiggy
    Marc
    I'll re-export your tune files for you but it's worth uninstalling/reinstalling.
  14. May 21, 2023 at 1:45 PM
    #1114
    mZiggy
    Marc
    Sent
  15. May 23, 2023 at 10:53 AM
    #1115
    BigKahunas15
    BigKahunas15 Well-Known Member
    Dan
    Prince George B.C, Canada
    Black 2015 TRD 4.0l 6MT
    Bilstein 6112 HD Dakar leaf pack CBI sliders and custom bed rack 295/70/17 Geolander MT G003
    Any tunes for the 4.0 with a manual trans? Also curious if this tune will help remedy the rev hang issue with the MT trucks.
  16. May 23, 2023 at 12:41 PM
    #1116
    mZiggy
    Marc
    Hello, yes we support the 4.0L MT.
    Tuning can help but there will always be a limit due to physics. At the end of the day, it's still a truck and the components in use reflect that.
  17. May 23, 2023 at 12:48 PM
    #1117
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    I'm almost certain it's been asked before, but is there a way to tune a direct 1:1 for pedal position:throttle position? Or is it map based for torque\air\whatever load?
    I'd be curious to experiment with it...
  18. May 23, 2023 at 12:53 PM
    #1118
    mZiggy
    Marc
    We could do it, but it can very rapidly feel too aggressive, not to mention there's other factors that can influence your throttle position on a throttle by wire vehicle.
    That said, we used to offer something approaching this a long time ago and can go back down this rabbit hole with you on the side if you'd like.
  19. May 23, 2023 at 12:55 PM
    #1119
    Murd3rd
    Nah, if it's already been tested and basically determined to not be better then I'm ok with that.
    I was just genuinely curious.
    The current Stryker tune I have is pretty damn amazing, so I'm def happy. I don't even honestly feel the need for full throttle control, because the truck moves like I want it to before my foot has a chance to reach the floor. Lmao
  20. Jun 3, 2023 at 5:43 AM
    #1120
    sorevilo
    sorevilo Well-Known Member
    V7 for the maggy tune is the last version I have just out of curiosity are there any newer versions or something that’s being worked on?
