YotaWerx Tuning Services and Development
Discussion in 'Performance and Tuning' started by mZiggy, Jul 31, 2021.
  1. Feb 13, 2024 at 5:24 PM
    #1321
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Make sure to add rpms and injection timing cylinder 1 D4 to the graph.
  2. Feb 13, 2024 at 6:07 PM
    #1322
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    I just need to make sure the all/primary is selected in the drop down before starting, correct? Then select those after the fact when viewing graphs?
  3. Feb 13, 2024 at 6:14 PM
    #1323
    Vlady
    Issy, WA
    Yes, use all or look through other options to see if d4s pids available.
    Drive around, if you stop in traffic and hear some noise, hit a space bar. It will flag the event in the capture.
    moon22[QUOTED] likes this.
  4. Feb 14, 2024 at 9:01 AM
    #1324
    Way Way Afar
    Way Way Afar Well-Known Member
    2022 TRD OR 4x4 DCSB AT
    Nice. Does this create a single flag? I don't have to toggle it like some kind of on/off flag type thing?
  5. Feb 14, 2024 at 9:08 AM
    #1325
    Vlady
    Issy, WA
    Each hit on the space bar creates a flag. Also, techstream has a feature to setup an auto flag based on some criteria, but I was not able to get it working in my case.
    Way Way Afar[QUOTED] likes this.
  6. Feb 14, 2024 at 11:24 AM
    #1326
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Trying to load the new tune and get this error "cannot decode .vfc file" has anyone else run across this? VF tune is up to date all windows firewalls ect. off and windows up to date.
  7. Feb 14, 2024 at 11:49 AM
    #1327
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    I am going to try and flash my truck in about an hour or so if I have time. Will keep you posted if I run into any errors
  8. Feb 14, 2024 at 4:33 PM
    #1328
    M1Awolf
    Rob
    Montana
    Well F**K me. I just tried to load a fresh install of the VFtune software and it completely bricked my existing install and will not open VFTune at all. I knew I should have written down my license info beforehand. Now I probably have to contact Matt at OVTune to see about getting it set up again. This should be fun as I was one of the first M/T guys to buy the tune with the purple dongle back in the fall of 2017 and have no records of the purchase.
    ETA I am downloading the legacy VFTune 1.7.X Should I be downloading 2.0WiFlash?
    Update I did a complete uninstall of all previous VFtune installs and loaded Version 1.7.x and all is well. Truck is flashed and a short test drive to make sure I get to work in the morning. Roads are snow packed and icy so a thorough test drive will have to wait. Initial impression is it feels stronger down low with smooth throttle response I loaded the premium Active duty file.
  9. Feb 14, 2024 at 6:17 PM
    #1329
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    I switched from 'WW' to 'AD' last night and was pleasantly surprised. I would have actually liked a touch more throttle sensitivity off idle, seems just a bit sluggish to get to a usable RPM to get going from a stop - but otherwise I think it works rather well with MT.
  10. Feb 14, 2024 at 6:23 PM
    #1330
    M1Awolf
    Rob
    Montana
    I got that feeling as well but wasn't sure if it was just me being careful on icy roads in my slippers instead of my boots...lol
  11. Feb 15, 2024 at 6:24 AM
    #1331
    Way Way Afar
    I did a few days with WW and switched yesterday to AD. It's a more fun(ner) tune.
    Each iteration is getting better and better. I need to put some miles on the AD tune to give a workout and for it to learn my driving habits.
    moon22 likes this.
  12. Feb 15, 2024 at 11:53 AM
    #1332
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    I had only about 24 hours with WW 2.0, when I first took off with that I about killed it getting out of the garage - and then again when I went to AD, I was expecting it to be way touchier and almost killed it again.
    Are these “you get what you get” and I just need to get used to it, or does Marc, et al, tailor a bit to taste? Really happy overall, just that last little detail, but I can deal with it if needed.
    On that note - is this “final draft” for Blackhawk as we move to the 4G era, or is development continuing?
  13. Feb 15, 2024 at 11:59 AM
    #1333
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I only tried WW but I almost killed it multiple times as well. Was not a fan of that part of 2.0. Original Blackhawk was not like that, so not sure why it changed to be how it is in the update.
  14. Feb 15, 2024 at 12:06 PM
    #1334
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Every tune that I have ever tried all take a bit of an adaption. A crazy, super linear throttle test took a week to get used to from a muscle memory standpoint. You gotta give it at least 150mi to 200mi to get used to it.
    I do not like raise the revs to get rolling. This 2.0 tunes seem close at the very bottom end, but I do not need to add revs to get rolling.
  15. Feb 15, 2024 at 12:18 PM
    #1335
    mZiggy
    mZiggy [OP] Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    We strove to make the take-off more tame for as many people as possible on BOTH throttle versions because we had a lot of people report from testing that they were wanting the touchiness of AD deeper in the pedal but with a more "WW-like tip in", so we accommodated that. If this needs adjustment for you guys, please email us
    moon22, tonered and RDT415 like this.
  16. Feb 15, 2024 at 6:18 PM
    #1336
    moon22
    moon22 :-|
    '12 TRD OR ACLB 6MT
    When I get a chance I will plug in the prior AD version for reference before nagging you. WW was a nice improvement over stock, but my Goldilocks tune may very well be 2.0 with the earlier AD tip-in. I would wager the MT guys would err towards a bit more aggressive settings than the AT crew..a lot harder for them to kill/bog it from a stop, hah.
    Funnily enough though it does seem like it is hard to kill. Only time I have actually killed it is at a long stop when I forgot to pop it in neutral and then let the clutch out. Does the ECU sense revs dropping way below idle and attempt to keep it alive? It kind of seems like it..it seems way too forgiving to be “all natural” for lack of better terminology.
    RDT415 likes this.
  17. Feb 15, 2024 at 8:01 PM
    #1337
    M1Awolf
    Rob
    Montana
    That dead throttle feeling seemed to improve with driving and the tune settling in after a few miles today. OR I just got used to the feeling of the new tune and it became the new normal. It doesn't want to bog down as much as when first installed and throttle seems very responsive to input without being too aggressive. So far I am liking it and the power down lower in the rpm range is very apparent,at least for my truck.
  18. Feb 16, 2024 at 6:42 AM
    #1338
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    reading lots of input on BH2 from the MT users - what do those of you on BH2 with AT think about the two tunes (WW and AD) and how they drive. Just curious. TIA.
  19. Feb 16, 2024 at 8:15 AM
    #1339
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    @mZiggy when is the 2.0 being released for us supercharged folks? Been running one of the betas for 8 months and it's been good. Looking forward to the official release.
  20. Feb 17, 2024 at 9:55 AM
    #1340
    mZiggy
    Marc
    Please excuse my limited communication in the recent days. Currently traveling across Texas for a big project.
