YotaWerx Tuning Services and Development
Discussion in 'Performance and Tuning' started by mZiggy, Jul 31, 2021.
  1. Mar 7, 2024 at 5:46 PM
    #1441
    3GTCMLMTD
    3GTCMLMTD Well-Known Member
    2022 Limited
    Hopefully you get better soon. I would hold off. If it is hard coordinating schedules, no need to put yourself through doing that multiple times. Once it’s fixed, one and done
    GoldenBrew[QUOTED] likes this.
  2. Mar 8, 2024 at 8:56 PM
    #1442
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    Wanted to give everyone an update. We are making progress on this, but are still testing to ensure this goes smooth. Pun intended.
    moon22, dms91, GoldenBrew and 2 others like this.
  3. Mar 8, 2024 at 9:06 PM
    #1443
    TACO-TY
    TACO-TY Not so well-known member
    Tyler
    Eastern WA
    '25 DCSB Sport
    Good one! :cheers:
    Kevinpd325[QUOTED] likes this.
  4. Mar 9, 2024 at 1:24 PM
    #1444
    iexc
    iexc WerXED BH2.0 AD
    Kalede
    Toronto
    2023 TRD Sport MT
    I second this. Could not have explained this better. After running OvTune for 6 yrs on my 2016 manual waiting for the Ultimate tune witch never came,I was not watching the forums anymore and content with what a had until I picked up my 2023. Came back to TW and settled on Yota Werx and flashed BH2.0 WW last fall and :eek: what a leap from what I had!!.liked it so much I was content with it.how much better could BH AD be :notsure:. until actually flashing it for other reasons and woa!! :eek: By far the best shifting I have ever done was with AD.could use a touch more power in coasting in idle as I have stalled it a few times particularly in reverse.
    moon22 and Menjivar54[QUOTED] like this.
  5. Mar 9, 2024 at 1:40 PM
    #1445
    Menjivar54
    Menjivar54 Well-Known Member
    2020 TRD PRO
    That's what I noticed, it requires a little more throttle input than the previous version but easy to get accustomed to. It is indeed awesome haha
    iexc[QUOTED] likes this.
  6. Mar 10, 2024 at 5:47 PM
    #1446
    nhpoke
    nhpoke Well-Known Member
    jason
    nh
    21 DCLB OR AG
    I just wanted to take a minute to say thank you to @Kevinpd325 for all of his hard work on this.
    I've been sharing logs from my 2021 that have hopefully helped to identify the "surging issue".
    Kevin was really helpful in explaining to me how to actually create logs for them to analyze.
    For the past few weeks my wife has even been saying my truck is driving weird. With the files I got from Kevin earlier this week (and we just did a 250 mile trip) things were soooo much improved!
    I got another set of files this evening and will flash them tomorrow, but it is clear that they have been working really hard to address issues and responding to feedback.
    Much appreciated @mZiggy and @Kevinpd325 .
  7. Mar 11, 2024 at 6:08 AM
    #1447
    jewboi
    jewboi Well-Known Member
    @iexc @Menjivar54
    are you guys running the AD version with or without a bunch of added weight in the form of armor/skids/etc? I have a similar experience to both of you and have loved the BH2.0 but flashed the WW version since my truck is fairly close to stock. slightly bigger tires, but no armor or other weight...
    I read another post somewhere that someone said AD version is mostly for trucks with much larger tires and/or weight
    Menjivar54 and iexc like this.
  8. Mar 11, 2024 at 10:06 AM
    #1448
    Way Way Afar
    Way Way Afar Well-Known Member
    2022 TRD OR 4x4 DCSB AT
    iexc likes this.
  9. Mar 11, 2024 at 11:12 AM
    #1449
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I’m 265/75/16, 225lbs of armor, and a Gobi roof rack running WW and love it. Excluding heavy towing, this truck/tune has more power than I need. I’m rarely above 3.5k rpm. Only time I am, is for serious highway onramp needs.
    There’s a wide range of needs with apparently similar satisfaction.
    iexc likes this.
  10. Mar 11, 2024 at 11:22 AM
    #1450
    iexc
    Kalede
    Toronto
    2023 TRD Sport MT
    All stock here to.Does take a bit longer to get used to.I am on my second tank and still learning it.
  11. Mar 11, 2024 at 1:56 PM
    #1451
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    hoping the bug is gone and 04B04 will be re-released soon - that is if it was confirmed in the versions (ecu's) which had the issue(s).
    @Kevinpd325 any thoughts - or update? I can reply to the original email I received that contained the Tune Package if that helps you look into and identify if my tune was corrupt. LMK. Thanks.
    06TXED likes this.
  12. Mar 12, 2024 at 2:00 PM
    #1452
    Menjivar54
    2020 TRD PRO
    I don't have any added weight aside from the OEM TRD skid plate
  13. Mar 16, 2024 at 10:59 AM
    #1453
    GoldenBrew
    Golden, Colorado
    any updates on the progress? been pretty silent for a while, which hopefully means they are nearing a fix. Asking for a friend :jpow:
    ahinks26, 06TXED and 3GTCMLMTD like this.
  14. Mar 16, 2024 at 11:12 AM
    #1454
    06TXED
    06TXED Well-Known Member
    Tony
    Aurora CO
    2023 DCSB MGM TRD OR 4x4
    x2 I am patiently waiting to get my 23 tuned at the R4T meet next Sunday. Hopefully the revised version is ready to go then !
  15. Mar 19, 2024 at 10:38 PM
    #1455
    TACO-TY
    Tyler
    Eastern WA
    '25 DCSB Sport
    Shellshock and 3GTCMLMTD[QUOTED] like this.
  16. Mar 20, 2024 at 3:06 AM
    #1456
    mZiggy
    mZiggy [OP] Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Alex of Doekter Tuned is mistaken. There is not a merger.
    Blackhawk 2.0 is being patched, to include Kevin's work to methodically root out the issue and address it accordingly rather than just putting a band-aid over it.
  17. Mar 20, 2024 at 6:56 AM
    #1457
    GoldenBrew
    Golden, Colorado
    Based on ^^^^ this I'd say the Mods need to lock and delete the post (s) by "Alex of Doekter." Nothing honorable in that type of post. JMO.
  18. Mar 20, 2024 at 9:01 AM
    #1458
    mZiggy
    Marc
    Actually I don't really care about that in this instance. Let it go in my opinion.
    Although I will admit that I don't particularly care for the part of the post that says he has tried YotaWerx Blackhawk for the 2020+ 4Runner when in fact he hasn't, as he only has 02.0 and 02.1 files, which predate any "Blackhawk" files for the 2020+ 4Runner by several months.
    That said, everyone has different tastes and preferences. It would be naive to expect any one calibration out there to satisfy literally every single person. I certainly do not begrudge him for feeling that KDMax's calibration offering was superior.
  19. Mar 20, 2024 at 2:01 PM
    #1459
    mZiggy
    Marc
    ANNOUNCEMENT:
    RDT415, iexc, ahinks26 and 22 others like this.
  20. Mar 20, 2024 at 2:05 PM
    #1460
    Rob64Taco
    Rob64Taco Well-Known Member
    Robbie
    2019 RedTacoma
    Wheels, grill ,fog lights ,blacked out emblems, hard cover shell
    Great News for all .
    TWTaco and mZiggy[OP] like this.
