Yoter problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by Grizzly2411$, Nov 15, 2023.
  1. Nov 15, 2023 at 8:02 AM
    Grizzly2411$
    Grizzly2411$ [OP] Member
    Toyota Tacoma 96 v6 3.4
    Why is my toyota tacoma 4×4 96 3.4 manual if i put it in gear i have to rev it in order to get it to budge when i let the clutch out an even tben it barely goes then it starts smoking top speed is 15 to 20
  2. Nov 15, 2023 at 8:57 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    What have you tried to fix this, and what is your level of mechanical intuition and ability? Most people start with checking the master and slave cylinders to ensure they are in working order, then maybe checking the cables. If those sound above your ability, it's probably best to take the truck to a shop.
    rocknbil likes this.
  3. Nov 16, 2023 at 4:02 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Welcome to TW, where you can turn bad news into good news with a little determination and some tools. :p If the the clutch master/slave check out, the clutch pressure plate is probably toast. It's not an impossible job to do by yourself, even easier with a transmission jack, but requires dropping the transmission/transfer case.
