You have got to be kidding me...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chachie, Jan 21, 2010.
  1. Jan 21, 2010 at 11:26 AM
    Chachie
    Chachie [OP] Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    Ok so i have had a few comments on my truck that the rear looks to be sagging a bit with the lift. Well i just figured it was wear as i bought the truck used from a dealer. Come to find out that whoever did the lift install didnt install the F****N AAL!!! here is a pic:
    On the Fabtech site it says that the Performance kit with the coilovers comes with the blocks and the AAL and both need to be installed. Im thinking that a shop looked at it and said oh its either one or the other. Anybody have any ideas of what to do?
  2. Jan 21, 2010 at 11:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Unless you have the TSB springs, you DO have an AAL in that spring pack
  3. Jan 21, 2010 at 11:29 AM
    Chachie
    Justin
    Nor Cal
    So they came stock with 2 leafs(sp?)?
    EDIT: and will the dealer do the tsb with the lift installed?
  4. Jan 21, 2010 at 11:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you are within the 3 year/36,000 mile warranty, Yes. They should
  5. Jan 21, 2010 at 11:34 AM
    Chachie
    Justin
    Nor Cal
    hmm im at 45000 but have an extended 36000, does that count?
  6. Jan 21, 2010 at 11:52 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I see a Block and a Fabtech aal in that pic. The 3rd leaf down is a fab tech aal. Notice how it is cut straight across (not good). That is the AAL.
  7. Jan 21, 2010 at 11:54 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2010 4Runner Trail Premium
    Nope i dont think the extended waranty will cover that.... many of us went through the same thing .... Chris or someone else correct me if im wrong but i doubt at 45000 and extended waranty they will do the tsb
  8. Jan 21, 2010 at 11:56 AM
    Chachie
    Justin
    Nor Cal
    Just called my local toyota stealership and he said it shouldnt be a problem.
  9. Jan 21, 2010 at 11:59 AM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    You either already have the TSB pack or you have an AAL installed (4 leafs total). It looks like you have the AAL installed because you can see a different arch on the 3rd leaf down. Good luck getting the TSB springs, maybe your dealer isn't as lame as mine was.
    Extended like for a total of 72k, or it's called an "extended 36k warranty"? If it's the latter you're probably hosed. Time for an upgrade.
  10. Jan 21, 2010 at 12:00 PM
    nuckinfuts
    Pacific NW
    '06 AC TRD Off-Road
    damn, nice! :D
  11. Jan 21, 2010 at 12:02 PM
    Chachie
    Justin
    Nor Cal
    extended 36k. Ya im going with there is an AAL installed and no TSB. I figure ill go in there and see what happens. The worst they can say is no. And come to think of it Novato Toyota owes me so maybe i should just call them.
  12. Jan 21, 2010 at 2:03 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    You shouldn't worry... toyota has a well documented history of rusty frames... :thumbsup:
  13. Jan 21, 2010 at 2:15 PM
    Chachie
    Justin
    Nor Cal
    Haha, dont be too worried about it. 95%+ is red clay residue from where we go wheeling.
  14. Jan 21, 2010 at 2:28 PM
    Chachie
    Justin
    Nor Cal
    No im in north california, but where we go wheeling is about an hour from me and it is all red clay up in the hills.
