You have the chance to change one thing about your Tacoma, what do you change?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mmm tacos..., Mar 2, 2021.
  1. Mar 4, 2021 at 4:52 PM
    #201
    eurowner
    eurowner Duke Sky
    Scoty
    Much lower seat base height.
  2. Mar 4, 2021 at 5:17 PM
    #202
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Remote start that stays running when door is opened (for PTS Tacomas) Second choice would be manual shift transfer case, But it is far less of a concern than the "proper" remote start.
    black_angus1 likes this.
  3. Mar 4, 2021 at 5:42 PM
    #203
    Wicker24
    Wicker24 Well-Known Member
    2018 TRD Off Road
    Push the stop/start button without your foot on the brake. Dumps the vehicle into ACC mode without cycling the system.
    grogie and TRD-ED[QUOTED] like this.
  4. Mar 4, 2021 at 5:47 PM
    #204
    eurowner
    eurowner Duke Sky
    Scoty
    While the engine is running, put in neutral, set the parking brake, hit stop/start button once.
  5. Mar 4, 2021 at 5:50 PM
    #205
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    I will keep it simple, I wish that no matter what radio screen was on it would show my phone service connection and Gaia had more information when using it.
    Living where cell service goes in and out it by each mile, it would be nice to see all the time
  6. Mar 4, 2021 at 5:52 PM
    #206
    black_angus1
    black_angus1 Well-Known Member
    AZ
    2017 Inferno TRD Sport DCSB
    I'm assuming this means stuff I can't easily change myself, so wheels/tires and the like are out. Already got mine paid off (19 months early) and got Clazzios and other cosmetic mods so don't need that either. So I'm going to go with transmission. A V8 would be neat but just improving the transmission would result in better power delivery.
  7. Mar 4, 2021 at 8:22 PM
    #207
    jetfishn
    jetfishn Well-Known Member
    I would change the engine to a longstroke V6 w/310 hp, Boxed Frame, spin on oil filter, 4 wheel disc, better gearing with 9 spd auto, no wait, I can get one at Nissan dealer in June! I might.
    NMBruce likes this.
  8. Mar 4, 2021 at 8:30 PM
    #208
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    Solid front axle with a locker and the power seats they didn’t put into my 2019. It would also be nice if they offered the off road in an actual Off Road ready configuration, ie, Lift, tires, front locker, etc...
    jetfishn likes this.
  9. Mar 4, 2021 at 9:04 PM
    #209
    krzysnwbrdr
    krzysnwbrdr Well-Known Member
    Masaki
    2016 Black Tacoma TRD Sports DCLB
    Hood design. water doesnt run and it stays leaving watermarks.
  10. Mar 4, 2021 at 9:05 PM
    #210
    psychic_legume
    psychic_legume Well-Known Member
    2002 White Tacoma TRD
    Swing rear doors on the extra cab. Makes a huge difference getting stuff in and out.
  11. Mar 4, 2021 at 9:53 PM
    #211
    TacomaDome91
    TacomaDome91 Active Member
    2016 AC MT Inferno TRDOR
    Would be nice to be able to change the display for metric users.
    For ex/ the map is in weird zoom increments (1.6km; 800m, 400m etc) because it's set to imperial (1mi, 1/2mi etc.) and the fuel efficiency tracker is impossible to read. We use L/100km instead of MPG so it works in reverse in that lower is better; the graph data is all squished way down to the bottom since the axes aren't scaled for metric.
    Also wish I could update things like map data, gracenotes etc without having to pay dealerships to literally put in an SD card and upload it, I could do that if they just released the damn data!
  12. Mar 5, 2021 at 5:26 AM
    #212
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    Thanks. I have no idea why Toyota would make something that complicated.
    This I will try! Thanks.
  13. Mar 5, 2021 at 6:19 AM
    #213
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    Still have an Xrunner option, or at least a true limited slip differential.
  14. Mar 5, 2021 at 7:15 AM
    #214
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You can change MPG to L per 100km in your settings. Can also change miles to km in your map settings.
    I have L per 100km and km in my maps.
  15. Mar 5, 2021 at 7:18 AM
    #215
    jrshaw91450
    jrshaw91450 Well-Known Member
    Maui
    2019 Cement Tacoma TRD OR 4x4
    TRD Cat back & Skid plate
    A non howling differential, a hood that was built with quality and doesn’t flutter on the highway and more torque.
  16. Mar 5, 2021 at 8:07 AM
    #216
    Dryfly24
    George
    NM
    A truck that doesn’t appeal to hipsters that think they want a truck but actually want a minivan/luxury car?
  17. Mar 5, 2021 at 8:25 AM
    #217
    Don A
    Don A Active Member
    Don
    Barcelona Red SR5 4x4 Access Cab
    Better seats! Ones that are comfortable please!
  18. Mar 5, 2021 at 8:37 AM
    #218
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Have not read the rest of this thread.
    I'm not sure--the radar mode in the cruise control is probably first on the list. But I would also prefer the old fashioned 4wd levers and manual hubs instead of the unreliable system we have now.
    ToynbyuTicotex likes this.
  19. Mar 5, 2021 at 8:49 AM
    #219
    Itchyfeet
    Itchyfeet Well-Known Member
    What makes it unreliable? I do sometimes wonder why people buy new trucks to complain about such things when there are thousands if not hundreds of thousands of trucks waiting to be had in the used market with manual hubs, levered transfer case, that have a better chance of surviving a solar flare or emp attack.
    Dryfly24 likes this.
  20. Mar 5, 2021 at 8:52 AM
    #220
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    No leaf springs in the rear
