young gun...help me out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eric.gumberry, Apr 15, 2015.
  1. Apr 15, 2015 at 6:39 PM
    eric.gumberry
    eric.gumberry [OP] Well-Known Member
    Eric
    North Carolina
    2006 6 speed 4x4
    17 in methoods and 265/70r17, 884s and billys at 1.75 in front no rear lift
    I have a 06 4x4 ext 4.0 Tacoma 6 speed and it is NOT a prerunner and i was wondering if this lift has been done on a truck like mine I have like a 400 dollar budget just for lift so I wanted to just put the 2 shocks in front...I would also like to like to put a 2.5 inch with aal 1.5 inch...but won't be able to get bigger tires til about July...I am only 16 and my job is on the summer about 300 bucks a weeks and 50% of that will be going towards my truck...any response is good...thanks
  2. Apr 15, 2015 at 6:40 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    How many lug nuts do you have? 5 or 6?
  3. Apr 15, 2015 at 6:51 PM
    eric.gumberry
    Eric
    North Carolina
    2006 6 speed 4x4
    6
  4. Apr 15, 2015 at 6:59 PM
    Pigpen
    Dan
    Northwest Montana
    Actually 24
    He said v6 4.0, so 6 lug...
    OP, do the aal first. Carry around some weight if it's too tall. Then do the front with 5100 s. Your truck will look good and be functional.
  5. Apr 15, 2015 at 7:01 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    With 6 lugs there are many many options.....
  6. Apr 15, 2015 at 7:04 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    5100's in the front @ 1.75 with a 2in AAL in the rear and 5100's or OME shocks and you will be golden and right around 400 bucks.
  7. Apr 15, 2015 at 7:40 PM
    eric.gumberry
    Eric
    North Carolina
    2006 6 speed 4x4
    Okay I will look into that how much lift will those coils give me?
  8. Apr 15, 2015 at 9:02 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Front 5100's are adjustable. He's saying to set them at 1.75" in the front, and the AAL will give you 2" in the rear.
  9. Apr 16, 2015 at 4:17 AM
    eric.gumberry
    Eric
    North Carolina
    2006 6 speed 4x4
    If I am going to put a aal in do I need longer struts?
