Your Experience with Spacers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dangeroso, Sep 6, 2018.
  1. Sep 6, 2018 at 12:33 PM
    ELT2JV
    ELT2JV Well-Known Member
    17 TRD OR ACLB
    8112 front 8100 rear. Method NV with 265/75/16 KO2.
    I used spacers on my jeep for two years of hard wheeling and mudding. Never had a problem. Torque em on and use some blue loctite and your good to go.
  2. Sep 6, 2018 at 12:54 PM
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Well that's the cost of modifying a truck.
  3. Sep 6, 2018 at 12:56 PM
    frenchee
    Oceanside CA Area
    I bought non overpriced wheel spacers and they have been fine.
    I don't wheel on a regular basis but no issues yet.
    Maybe I will take them off to inspect them.
  4. Sep 6, 2018 at 12:56 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    The risks from mounting spacers are mostly limited to the spacer itself, adding additional studs and nuts adds potential failure points if not maintained and properly installed. If the studs are of low grade metal then there is a greater risk of shearing them off during use or install/uninstall. Other "risks" are that they aren't centric in some way and allow the wheel to rotate out of balance, but that should be noticeable.
    Beyond that, in regards to wheel bearings as already stated, there is no appreciable mechanical difference in running spacers than in running a wheel with a matching offset. Ask all the guys running SCS wheels about their "guaranteed" wheel bearing failures, all of the SCS wheels push the wheels out approximately 1" over stock or more. Spacers are no different than having a deeper mounting surface on a wheel. I know the reasoning behind why people guarantee failure with spacers but its been shown time after time to not be the case. There are greater risks to your wheel bearings occurring when you decide to run tires 20+lbs heavier than stock and when you wheel your truck routinely.
    OP, go with Spidertrax or BORA. Spidertrax will get you 1.25", if you want a specific offset, from .75" to 2" go with BORA. There's enough people running them w/o failure to feel safe in those choices.
  5. Sep 6, 2018 at 1:00 PM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
  6. Sep 6, 2018 at 1:03 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I've run wheel spacers on several different vehicles over the years and have not replaced one wheel bearing because of a spacer.
  7. Sep 6, 2018 at 1:03 PM
    MHFitz
    MHFitz Member
    Colorado
    2017 DCSB Diet Colored Tacoma Off-Road
    None that matter.
    You sure you're trolling the right forum?
  8. Sep 6, 2018 at 1:04 PM
    elduder
    Van WA
    Darth_Yota likes this.
  9. Sep 6, 2018 at 1:08 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    "It's basically the cheap way of modifying the suspension system on your car."
    I had to stop the video after that one there. This isn't modifying suspension at all.
    elduder likes this.
  10. Sep 6, 2018 at 1:09 PM
    NC_IslandRunner
    NC_IslandRunner Well-Known Member
    Rory
    2018 Inferno Taco TRD offroad
    I ran wheel spacers on my 04 Chevy Trailblazer for years, still has the factory hubs installed, I've blown the transmission 3 times, broke more CV axles than I care to count and bounced it off rocks and trees and destroyed the front differential. But wheel spacers have never caused me one issue. Now that I'll be wheeling my Taco it will need some too. I doubt I'll be as rough on it as I was the Chevy, it gets expensive.
    elduder likes this.
  11. Sep 6, 2018 at 1:10 PM
    elduder
    Van WA
    Are you sure they wernt the cause of the blown tranny, I mean come on 3 times and you never thought to remove the spacers? ;)
    WZ00R2 and EatSleepTacos like this.
  12. Sep 6, 2018 at 1:15 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  13. Sep 6, 2018 at 1:19 PM
    NC_IslandRunner
    Rory
    Spacers really don't add and real stress to the drive line, so many other parts weaker that would fail first. Hauling heavy loads, running though deep mud and over rocks cooked the transmission. The 4L60E isn't known as a beefy transmission to begin with, great for what it was designed for but I played a little harder than it was meant to handle, should have upgraded it but I had it rebuilt for a decent price so I just went that way.
  14. Sep 6, 2018 at 1:25 PM
    elduder
    Van WA
    Sarcasm, just messing with you, and satirizing the typical responses we get on the forums for these kind of things. :spy:
    EatSleepTacos likes this.
  15. Sep 6, 2018 at 1:47 PM
    #35
    x2akimbo
    x2akimbo Well-Known Member
    Chicago
    '18 MGM Tacoma TRD OR MT
    Had them. BORA 1.25 for about 5 weeks. Really wanted to give the truck a more aggressive stance while I shopped around for a wheel and tire deal. Never had issues. Now that I got my wheels and tires I will be selling my set on here shortly once I take some pics. But honestly, having the spacers always made me feel a little uneasy. I always kept checking to make sure they didnt come loose and when driving long distance I would have this bad feeling in the back of my mind that something bad can happen and Ill lose a wheel going 70mph. I know, stupid, but that feeling never went away.
  16. Sep 6, 2018 at 2:35 PM
    #36
    elduder
    Van WA
    Not really any different than the wheel lugs. They should be checked routinely though, also like wheel lugs.
  17. Sep 7, 2018 at 10:22 AM
    #37
    RevivalOL
    RevivalOL Well-Known Member
    Pete
    Berkley, MI
    2017 TRD Off-Road DCLB
    People are going to tell you that your wheel bearings are going to fail because of changes in angles, etc. But typically, those same people will say that running an aftermarket wheel with a different offset or back spacing than the stock wheel is just fine. These both have the same effect on angles and force on steering/axle components. Many people have run spacers successfully with no issues, both on road and off road - on Tacomas, as well as other vehicles. Can/will it wear out some components faster than stock wheels with no spacers? Sure - maybe. It is going to grenade on you right away? No. I ran spacer for 10k miles before getting aftermarket wheels with an offset that accomplished the same thing. 17k miles now and nothing has fallen apart yet. Might I have some kind of issue sooner now? Quite possibly - but I doubt I'll have an issue (knock on wood) anytime SOON. Am I willing to go that route for the look/function that I want - yes.
    dangeroso[OP] likes this.
  18. Sep 8, 2018 at 5:59 PM
    #38
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    If you keep mashing that pedal on the left you will eventually have to change those pads that make you stop. LOL
    I have used spider traxx spacers on a trail jeep for like 10 years now, and on my Tacoma for about 30,000 miles now. There has been no abnormal wear in either vehicle so far, but I imagine that all wheel bearings will need to be replaced eventually... spacers or not.
  19. Sep 8, 2018 at 6:13 PM
    #39
    Harvo
  20. Sep 9, 2018 at 9:31 AM
    #40
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    That 4L60E is TRASH! I put 3 in my Silverado. Always wanted the 80.
