Your favorite interior upgrades (NOT mods)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blairrad, Apr 8, 2023.
  1. Feb 24, 2025 at 6:47 PM
    #81
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Hay Lobos[QUOTED] likes this.
  2. Feb 25, 2025 at 7:09 AM
    #82
    hinmo24t
    hinmo24t MAhole
    tom
    dartmouth, ma
    2015 TRD OR , blue ribbon metallic
    flip it upside down if its not powered, like i did in above post. gain a good amount of viewing, and night lens you just tilt the whole thing up or down and it goes to night view
  3. Feb 25, 2025 at 7:14 AM
    #83
    Hay Lobos
    Hay Lobos Let's be friends.
    Ben
    The Great State of Maine
    2013 Tacoma SR5 Access cab
    I have the powered version with backup camera and I like it, so I don't know if this will work for me, but it's a damn fine idea.
    hinmo24t[QUOTED] likes this.
  4. Feb 25, 2025 at 10:40 AM
    #84
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
    Unfortunately Bird Dawg no longer exists but there is someone making a new version for sale currently. I can't find the thread so you'll have to search for it but it's so worth it to get the mirror up and out of the way.
  5. Feb 25, 2025 at 2:55 PM
    #85
    Hay Lobos
    Ben
    It's become the only thing that bugs me about the truck. I'm tall enough that I shouldn't fit comfortably, but I do, except the damn mirror right in the middle of my vision. Thanks for the tip, I'll hunt it down.
  6. Feb 25, 2025 at 5:03 PM
    #86
    Waasheem
    Waasheem
    2007 xrunner
    I have an aftermarket head unit, pioneer nexXXXXX. I set it up so the backup camera is always on, except when I fiddle with music or navigation. Daytime it works perfectly. In the morning, if the windows are fogged, the camera will also be fogged, needs a quick wipe off. Nighttime it’s soso, about all I can see is headlights.
    You could get a glue to the windshield thing at an auto parts store. The one I bought came with some cleaner & glue. It stayed on until I got rid of the car I put it in.
  7. Feb 25, 2025 at 5:59 PM
    #87
    Hay Lobos
    Ben
    You mean, so I could detach and reglue the mirror in a better spot? That's probably the best idea.
  8. Feb 26, 2025 at 11:24 AM
    #88
    ABA180
    East Bridgewater MA
    That's another option yep
  9. Feb 26, 2025 at 11:41 AM
    #89
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
  10. Feb 26, 2025 at 12:14 PM
    #90
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Hay Lobos likes this.
  11. Feb 26, 2025 at 3:53 PM
    #91
    Hay Lobos
    Ben
  12. Feb 27, 2025 at 6:36 AM
    #92
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Id still try to find the Bird Dawg one. It also has provisioning for a RAM ball mount
  13. Feb 27, 2025 at 7:01 AM
    #93
    Waasheem
    Waasheem
    2007 xrunner
  14. Feb 27, 2025 at 11:12 AM
    #94
    Pigpen
    Dan
    Northwest Montana
    Hand throttle. Definitely an upgrade. 2 wheel drive low button. Definitely an upgrade. Heated mirrors button. Definitely an upgrade. Custom console between rear seats (second battery, charger, and inverter in there). Definitely an upgrade. But my favorite upgrade has to be the kid's car seat.
    Williston likes this.
  15. Feb 27, 2025 at 11:55 AM
    #95
    JRVfromDVT
    JRVfromDVT Well-Known Member
    Southern Vermont
    2006 Tacoma Access Cab
    The JessicaAlba heat/AC control dials. It’s nice being able to see where the controls are set at in the dark
  16. Feb 27, 2025 at 12:03 PM
    #96
    Hay Lobos
    Ben
    I've looked but all I'm finding is defunct Bird Dawg posts.
  17. Feb 27, 2025 at 12:20 PM
    #97
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    Have you tried carefully adjusting the arm all the way up? I did this with mine and it helped considerably.
  18. Feb 27, 2025 at 1:15 PM
    #98
    Waasheem
    Waasheem
    2007 xrunner
    Be careful. I did manage to flip mine upside down but in the process heard a cracking glass sound. It hasn’t fallen off yet.
  19. Feb 27, 2025 at 1:29 PM
    #99
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    oh exactly! I actually held the mount at the glass very firmly and levered the arm against that pressure.
  20. Feb 27, 2025 at 3:26 PM
    #100
    Hay Lobos
    Ben
    I did move it up casually, but felt like it was up against something, so I didn't exert any real pressure on it. I'll take a closer look, even an inch would be really good for me right now without having to spend any money. It's 12 years old so maybe it just needs a little persuasion to go farther.
    reallifedog[QUOTED] likes this.
