Your Front Lift measurments
Discussion in '4 Cylinder' started by maxpower29, Jan 26, 2013.
  1. Jan 26, 2013 at 5:16 PM
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Just wondering what people are running up front for lift specs and measurements. The 4 cylinder is 150-200 lbs lighter then the V6 so it must sit a tad higher. Anyone? Looking to make a decision on what Toytec spacers to add for a bit more clearance up front.
    Thanks
  2. Jan 27, 2013 at 5:29 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Come on people get off your ass
  3. Jan 30, 2013 at 10:27 AM
    barker14
    barker14 sexual ninja
    Adam
    Nova Scotia, Canada
    05 Tacoma TRD Off Road
    Complete OME suspension with Dakar leaf pack. Clarion touch screen Sport hood Tri fold Tonneau cover
    What are your before and after measurements? If your under 3" of lift you can add half the difference in spacer to get you up to 3". If your at 2 1/2" of lift, get a 1/4" spacer and that will put you up 1/2" so you will sit at 3" of lift.
  4. Jan 30, 2013 at 11:50 AM
    BlackSeven
    BlackSeven Grab your helmet, this shits about to get retarded
    Maryland
    '10 Reg Cab 4x4
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    Toytec ULK coilovers, front measurement on a settled suspension is 23 3/4. Initial measurements at installation was 24 from hub to stock fender flare. I also have my coilovers cranked 1.5 turns (Toytec states this is OK, but no more).
    I also have a demello offroad front plate bumper so that soaks up some weight (No winch).
  5. Jan 30, 2013 at 5:38 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    im pretty sure the 2.7 will sit a bit higher though with less weights so im looking for the difference
  6. Jan 30, 2013 at 7:20 PM
    barker14
    Adam
    Nova Scotia, Canada
    Doesn't matter what engine or weight you have on the front end now that its lifted. That's how the springs will sit. Now you can measure how much lift you got and add a spacer to make up the difference.
  7. Feb 3, 2013 at 2:59 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    4x4 2.7 + OME 885x + no spacers = 3"
  8. Feb 3, 2013 at 10:34 AM
    BlackSeven
    Maryland
    '10 Reg Cab 4x4
    What is your hub to fender measurement?
  9. Feb 3, 2013 at 11:00 AM
    4Wheelin4Banger
    Randy
    I don't recall, but before & after were 3" difference.
    I might lose a little tomorrow Eric is welding on sliders & Wednesday I'll bolt on the skid plates after the paint dries.
