Your input on my lift plan is appreciated. 32x11.5x15 BF Goodrich on 2002 DC taco 4X4
Discussion in '1st Gen. Tacomas (1995-2004)' started by SwampRabbit, Aug 1, 2016.
  1. Aug 1, 2016 at 9:25 AM
    SwampRabbit
    SwampRabbit [OP] Member
    Jesse
    Baton Rouge La
    02 double cab Tacoma 4x4
    Hello friends. I have a stock 2002 double cab 4 wheel drive Tacoma. I recently found a good deal on a slightly used set of tires, BF Goodrich all terrain 32x11.5x15 on a set of aftermarket rims. I purchased them with the thought that they would slightly rub, but man was I wrong, they rub way too much. After reading on this site for a good while, I came up with the bilstein 1500s for the front and the add a leaf for the back. Should I still have concerns of rubbing after installing the lift? I don't want to order and install the wrong lift. Should these tires fit or should I just sell the tires? Thanks for the help.
  2. Aug 1, 2016 at 9:28 AM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    What exactly are you rubbing? You might have to remove the front mud flaps.
  3. Aug 1, 2016 at 10:40 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Jack up the front end 2 inches, turn steering wheel from lock to lock....check for rubbing. If it still rubs, go up another inch. If tires still rub.....you are going to need more than 3 inches of lift to keep from rubbing. From that information, you can decide what to do next. Either buy a lift for your tires or buy tires that will fit your truck without a lift.
  4. Aug 1, 2016 at 10:59 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    thats not how it works... its still gona cycle the suspension and still rub with 3" lift.
    theyl fit stock height. just do the pinch weld mod.
  5. Aug 1, 2016 at 11:13 AM
    eon_blue
    Azusa, CA
    I assume by rubbing you mean it's rubbing on the pinch weld right? The metal part of the body just behind the tire (usually covered by a plastic). My stock size tires were rubbing on mine because of the aftermarket wheels I have (spacing was different).
    I cut back that plastic part and bend the pinch weld back as much as I could with a hammer/pliers. Couldn't really get much of it to bend back though because it get's pretty thick. I installed my 5100/OME 881s and got about and inch and a half of lift in the front, which combined with bending back a bit of the pinch weld, got rid of 99% of my rubbing. I only rub now if I'm at full lock and on a steep decline (when off-roading).
  6. Aug 1, 2016 at 11:21 AM
    CD20H
    Ben
    North Texas
    So raising the front end will not simulate a lift? Whether by floor jack or springs. It does the same thing. You want to cycle the suspension. That's the whole point.
  7. Aug 1, 2016 at 11:39 AM
    devinzz1
    devin
    2023 aclb trd or mt
    coilover/preload lifts only raise the ride height. the suspension still cycles up all the way to the same bottom out point. if you hit a bump or articulate the suspension its gona rub the same. even with the lift youl need to do pinch weld mod because itl cut your tires up and rub.
    MatthewMay1 likes this.
  8. Aug 1, 2016 at 11:51 AM
    eon_blue
    Azusa, CA
    My OME881s got rid of my pinch weld rubbing, I left the 5100s set at 0. I used to rub like crazy even after beating back the pinch weld on full turns, after the coils were put on it doesn't rub on those turns anymore. Not saying it'll work for everyone, depends on where and how bad your rubbing is but it worked for me.
  9. Aug 1, 2016 at 12:34 PM
    SwampRabbit
    Jesse
    Baton Rouge La
    They are rubbing the front mud flaps, which it looks like cover the pinch welds. I will remove the flaps and make the pinch weld mod and see how much it helps. Thanks to all for the suggestions.
  10. Aug 1, 2016 at 9:05 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    A lot of people can get away with just removing the mud flaps. It'll depend on your wheels if you need to trim a little more or not.
  11. Aug 5, 2016 at 2:32 PM
    SwampRabbit
    Jesse
    Baton Rouge La
    Update, I removed the mudflaps and did the pinch weld mod. Got rid of most of the rubbing. Went ahead and ordered 5100s for the front end and will install next week. Thanks for the help everyone.
  12. Aug 5, 2016 at 4:19 PM
    UtahTacoma02
    UtahTacoma02 Well-Known Member
    Dave
    SLC
    02 Tacoma Double cab TRD Limited
    ARB front bumper, Old Man Emu suspension, on board air compressor, on board hot water converter, cb radio, safari snorkel, warn 8K lb. winch, AP rock slidders/rear bumper, gray wire mod
    I'm running the exact tire size and brand on my 02 with OME suspension. 3" lift front and a little more in the back with add a leaf. Never rubbed even at full tuck and turn. With no body lift or wheel spacers.
  13. Aug 7, 2016 at 4:44 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    What are you running for lift in the back of your truck?
  14. Aug 8, 2016 at 10:50 PM
    UtahTacoma02
    Dave
    SLC
    Dakar leaf springs with add a leaf. Nitro Charger shocks and 3" shackles i believe.
  15. Aug 9, 2016 at 10:05 AM
    devinzz1
    devin
    2023 aclb trd or mt
    that would give you like 6" of lift or more?
  16. Aug 9, 2016 at 11:19 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    That's why I didn't respond to that quote. It seemed a little "high" @devinzz1
  17. Aug 9, 2016 at 4:03 PM
    UtahTacoma02
    Dave
    SLC
    No, I'm at about 4" lift in the back with that set up. The leaf shackles are 5" long so about 2" longer than stock i believe. Every inch added to the shackle length from stock length will lift the truck about 1/2" in most cases. With just the dakar leafs + AAL you will be up roughly 3" from stock. Measurements from the top of tire to bottom of fender is at about 9" now. Stock height the measurement from top of tire to bottom of fender was around 5". So my back is up 4" roughly from stock.
