Your new 2010 - 2015 truck -Auto transmission could be low on fluid directly from factory
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gearcruncher, Jan 26, 2014.
Was your transmission low on fluid
  1. Was your transmission fluid low -brand new ?
    36 vote(s)
    78.3%
  2. fluid low after dealer said it was fine ?
    9 vote(s)
    19.6%
  3. fluid low after dealer did transmission work ?
    1 vote(s)
    2.2%
  4. fluid low after lube shop changed fluid ?
    2 vote(s)
    4.3%
Multiple votes are allowed.
  1. Jan 26, 2014 at 6:47 AM
    gearcruncher
    gearcruncher [OP] Well-Known Member
    Canadain bumper technician
    Hey folks .
    I try and assist with most transmission related questions at TW .
    I wasnt sure how to word the post so all of you guys catch wind of the issue so hopefully the way its worded will attract your attention .
    This post covers ALL YEARS of the 4 LITRE ENGINE WITH NO TRANSMISSION DIPSTICK
    EDIT : UPDATE - DEALERS DO NOT CHECK THE FLUID WHEN THEY SELL YOU THE TRUCK
    What I am finding as well as many others here at TW ,is 99 percent of the transmission complaints are caused by a low fluid condition . Shudders , delays , torque converter failure, solenoid codes caused by friction clutch sediment and premature transmission failure .
    Some of you are lucky enough and the problems occur within the factory warranty timeline but others are finding out far too late and end up having to pay for a transmission overhaul . From what some of the members here have gathered , your brand new truck is possibly low on transmission fluid .
    Toyota calls WS fluid a lifetime fluid and doesnt need to be checked .Its not a lifetime fluid . No fluid is lifetime . The only reason they called World Standard transmission fluid a lifetime fluid good for 100K was to get away from enviromental tax fees . Other manufacturers recommend changing their fluid much sooner and have to pay an enviromental fee for every vehicle they sell to the public . Sell a million cars and trucks and the enviromental fees add up quick . Toyota comes up with a lifetime fluid that is good for 100k and saves millions . They did not create a quality transmission fluid , they simply worded it to save enviromental fees . WS is no better than anything you get off the shelf in Walmart in fact even at Walmart you can purchase better quality transmission fluid than WS . Why did Toyota recently decide to change their transmission fluid replacement from 100k down to 60k ? .....far too many warranty issues
    At this point in time we are not positive as to why your transmission is low on fluid or what YEARS are involved but can guarantee after reading this , some of you will find a low fluid condition .This post / poll is to make you aware that there is a problem with the transmission fluid level .
    The transmission is built by Aisn Warner and considered a sealed unit meaning " NO FILL TUBE WITH LEVEL INDICATOR UNDER THE HOOD " its filled with enough transmission fluid and dyno tested to make sure it functions properly before it is shipped to Toyota for installation . Once at the Toyota factory , the transmission is then installed and additional components are added such as transfer cases for the 4 wheel drive version and transmission coolers for the towing package . Some take more fluid , some take less but Toyota has to follow a temperature fill guideline using the vehicle ECM and their Techstream scan tool .Not sure whats being overlooked here but some members are finding after a dealer transmission service , their transmission is "still " low on fluid when they perform a fluid check using the trucks on board diagnostic system at home .
    Fortech created an excellent write up on how to properly check the fluid at home . If you are interested to see if your truck is low , click the link below and Remember that the engine has to be running when you check your fluid .
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/63851-how-drain-refill-automatic-transmission.html
    Here is the PDF from Toyota showing how to fill / check the fluid . Scroll down to page 18 for the details http://www.toyotatundraforum.com/pdf/A750E.pdf
    And then read here http://www.purefjcruiser.com/docs/2...ion/Automatic Transmission Fluid/01600210.pdf
    And for heavens sakes , DONT DO THIS https://www.tacomaworld.com/threads/halp.33318/
    All we are looking for in the poll is to verify the condition and to possibly save the members here a few bucks .
    Its unfortunate that you can only add to the poll for a week before it closes . Many many members are finding their fluid very low when checked using the two guidlines noted above . Some guys are reporting that their fluid level is fine and others are reporting the fluid level low . With this said , its hit or miss as things stand now .
    PzTank likes this.
  2. Jan 26, 2014 at 7:10 PM
    gearcruncher
    Went back in my records and it looks like the dealer did service my transmission . Went outside and followed the fluid check guide . Sure enough I am 3 quarts low on fluid .
    Topped up the trans with Max life fluid and it shifts much better .
    The torque converter shudder at 45 is completely gone .
    Check your fluid level people . Do not trust your dealers
    Thanks for the write up Foretech .
    My vote is in
    EDIT : Sorry if i didnt post a poll with your choice . Maybe your fluid level is fine etc etc
    What fluid did you use ?
    how,s the transmission been working ?
  3. Jan 26, 2014 at 7:11 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  4. Jan 26, 2014 at 7:19 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
  5. Jan 26, 2014 at 7:21 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    I might need to check mine, it doesn't always shift as smoothly as it should.
    ManBeast likes this.
  6. Jan 26, 2014 at 7:21 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I'll look into this
  7. Jan 26, 2014 at 7:51 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I shall look into it on my 3 month old 2013 taco...
  8. Jan 27, 2014 at 6:21 PM
    gearcruncher
    My neighbour also has a 2011 TRD off road with 26K. Just went through the home check fluid process with his truck and he was a quart low .
    He,s not a member so I cant vote for him but was very thankfull .
  9. Jan 28, 2014 at 1:34 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Checked the dipstick on mine and it is spot on.
  10. Jan 28, 2014 at 2:31 AM
    OverPar
    OverPar Well-Known Member
    Dirt Guy
    NW CT
    09 TRD Sport
    Fold-a-Cover G4 Elite, Light bar (X3 Hella), Thule/OEM RR, Avid OR BO Sliders, TRS Projector HL (BHLM), 5100s F/Rear @ 1.75
    Well that's nice. And I'm guessing if its brought to their attention they're not taking responsibility for it. God forbid anyone take responsibility for their actions. Yea. Instead of trusting them, put it this way. I checked my trans fluid level. Its low. It came that way. Top it off please. I will check again when I get home and be back if its not properly done. Thank you.
  11. Jan 28, 2014 at 2:46 AM
    Coast2Coast
    Coast2Coast Well-Known Member
    Northern Alberta
    2009 TRDOR
    Black Sand Pearl factory paint - flattened "au natural" by tree branches.
    My fluid was flushed with the "drain the pan and add more fluid" method 2 or 3 separate times at the dealership before I bought my truck, according to the service history forms I got with it. I was planning to do a full flush soon when I decide which ATF I want to use. I'll check the level with the procedure before I start the flush and get my vote in.
  12. Jan 28, 2014 at 12:32 PM
    gearcruncher
    Lucky guy . You have a dipstick .
    Us unlucky owners have to crawl under the truck and remove a stupid plug , then spend the time to put the ECM into temperature mode .:confused:
  13. Jan 28, 2014 at 12:56 PM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    Could we not simply add transmission fluid cool until dripping out of the overflow, then run the truck for a few miles until the transmission temp was up to normal operating temperature and then remove the overflow (not drain) plug until no more hot fluid came out? To me, that would be the proper level; hot to the top. Then no need to jump circuits to get the ECM into some special temp mode.
  14. Jan 28, 2014 at 3:15 PM
    Easy rider
    Easy rider Well-Known Member
    Cali
    18' T4R 4x4 LT TC 3.5 over
    Just FYI....I blew up my 2013 transmission after losing only a little bit (a couple ounces at most)of fluid after I ruptured a line offroading. I trail fixed it and limped it back to camp and lost all of my gears/boom (zero warning lights). Toyota refused to back their warranty due to my suspension modifications...I will be starting a neutral 3rd party arbitration soon due to the AT temp sensor not flipping on and toyota blaming it on my suspension.
  15. Jan 28, 2014 at 3:17 PM
    OZ-T
    Peter North
    British Columbia
    There's an ATF dipstick ?
  16. Jan 28, 2014 at 3:23 PM
    OZ-T
    Peter North
    British Columbia
    what
  17. Jan 28, 2014 at 3:48 PM
    gearcruncher
    Its a good idea King . Should at least get your fluid level into the ball park range should it be low but according to the proper procedure , the trans has to be between 46°C (115°F) and 56°C (130°F) to accurately check the fluid level. Its possible the temp during factory fill could be the issue as to why sooo many guys are having slipping / shuddering issues and premature trans failure .
    Edit : Your idea of cold and my idea of cold are two different temps . Transmission fluid does expand and so do the alluminum /steel parts within the trans . If we follow what Toyota specifies , we know the level will be adjusted according to manufacturers specs .
    At least we know there is an issue and hopefully find the problem soon
  18. Jan 28, 2014 at 4:08 PM
    OZ-T
    Peter North
    British Columbia
    I'm serious , is there an ATF dipstick on my 2009 ?
  19. Jan 28, 2014 at 4:15 PM
    gearcruncher
    Hey OZ . fairly certain on the 4 bangers there is a filler tube with level indicator .
    If you got some spare cash , order one up and modify to fit the 4 litre
    This means OZ hasnt checked his transmission fluid and he owns a 2009 :D
  20. Jan 28, 2014 at 4:18 PM
    OZ-T
    Peter North
    British Columbia
    Thanks
