your not going to believe what i found
Discussion in '1st Gen. Tacomas (1995-2004)' started by adiablo420, Apr 22, 2010.
  1. Apr 22, 2010 at 11:42 PM
    adiablo420
    adiablo420 [OP] Active Member
    HI DESERT CALIFORNIA
    96 TACOMA 4X4 4 CYL
    SUSPENSION LIFT, RIMS AND BFG MUD TERRAINS
    My last post was that i found that a fitting was stuffed into a rubber hose that comes from my air intake tube to the bottom of the throttle body.. well today i pulled it out and WoW.. it looks like a gas line fitting. somebody put it in there to slow the air down.. now that i took it out.. the idle runs high.. I do have a check engine light for a ctp sensor to be replaced... Does anyone know if thats why..
    heres some pics
    heres the hose with the crack.. gotta replace it now.. comes out the intake tube
    this is what was in the hose.. that hose goes under the throttle body...
    yea... some weird shit..>:eek::eek:
  2. Apr 23, 2010 at 5:45 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    that probably a vent return line of some sort. ...not positive, but that's what it looks like to me.
    in years past, it wasn't an issue. ..now, with all the emissions crap, you have to vent back into the intake.
  3. Apr 23, 2010 at 5:50 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    There is a resonator delete mod (IIRC) for first gen intakes. I think that is what was done. I will see if I can locate it.
  4. Apr 23, 2010 at 6:01 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Ok, it's not the silencer delete mod. It appears to be the EGR Block mod.
  5. Apr 23, 2010 at 10:05 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    It's your blow off valve to your turbo.
  6. Apr 23, 2010 at 8:21 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    High idle ? Throwing codes too ? Your running lean Bro', look for more vaccum leaks......good luck....:cool:
  7. Apr 23, 2010 at 9:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  8. Apr 24, 2010 at 9:57 AM
    adiablo420
    96 TACOMA 4X4 4 CYL
    bro.. i've checked for leaks on the vacuum.. one code i got is a p0510 closed throttle position switch... the other is p0116 coolant cirbuit range performance... gonna change out the sensor.. I'm not a mechanic but do run a bodyshop.. i know a lil.. when i start my truck , it runs fine (idle),as it warms up , the idle goes high on its own.. It seems that the coolant sensor is not sending the signal to something to tell the truck that its warm . cause soon as the truck warms up.. the idle runs high again.. seems to me like the cooling sensor and the throttle sensor are not communicating... whats your take on this...
  9. Apr 24, 2010 at 9:57 AM
    adiablo420
    96 TACOMA 4X4 4 CYL
    yea.. what he said.> !!!!!!
