YOUR OPINION ON LABOR CHARGES
Discussion in '1st Gen. Tacomas (1995-2004)' started by TACO TX, Feb 3, 2014.
  1. Feb 3, 2014 at 9:28 AM
    TACO TX
    TACO TX [OP] Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    So over the last year my trucks ride has gotten really rough and i have been fighting a vibration in the steering wheel. I have replaced rack bushings, installed hub centric adapters on my wheels and it still has a slight vibration and still rides rough. So i take it to my local mechanic which is a Napa service center and they check it out. They say my front Bilstein hd's are toast which are only 4yrs old and that the lower ball joints have play also. I also need lower control arm bushings which started squeaking after the last ice storm. He also said that the caster on my alignment is probaly out and causing some of the high speed vibe. The local Autozone is going to warranty the shocks and replace them. The shop will install them. This all comes with a 2yr 24,000 mile warranty that is good at any Napa service center and the ball joints are lifetime. For a grand total of $1350.00. Do you all think this high or a decent deal. Also the man that owns the shop and his first mate are both Toyota master mechanics which gives me some peace of mind. I just dont have the time or facility to tackle the A-arm bushings and shocks and would run all over to get alignment and the proper tools to do the shocks. Anyhow, whats your thoughts?
  2. Feb 3, 2014 at 9:30 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    So what exactly would they be replacing? Shocks, lower ball joints, lower control arm bushings, and an alignment?
  3. Feb 3, 2014 at 9:30 AM
    trailbikerider
    trailbikerider Well-Known Member
    Kalamazoo, MI
    He's charging you $1350 to replace two front shocks, two lower ball joints and the control arm bushings? Maybe it's because I don't ever take my vehicles to a shop, but I wouldn't pay that much to have that done. Seems like only a few hours work to me.
  4. Feb 3, 2014 at 9:33 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    That's just labor cost, or that includes the ball joints and bushings?
  5. Feb 3, 2014 at 9:48 AM
    TACO TX
    Kelly
    Denison ,Texas
    Thats labor, Bj's, bushings, alignment, shop supplies, switching out shocks, and taxes.
  6. Feb 3, 2014 at 9:51 AM
    TACO TX
    Kelly
    Denison ,Texas
    Wish you were closer, lol. I usually do all i can myself, but with no spring compressor, no ball joit tool, or a press and its cold, icy, rainy ect here now.
  7. Feb 3, 2014 at 10:22 AM
    trailbikerider
    Kalamazoo, MI
    :laughing: Yeah it helps to have a shop with a lift.
  8. Feb 3, 2014 at 10:24 AM
    Fanman47
    Fanman47 Well-Known Member
    Luke
    Texas
    I noticed you are in Denison. I know its a bit of a drive, but I use a toyota mechanic in Fort Worth that will pretty much beat any prices and warranty his work. Hes trustworthy.
    Just PM me if you are interested in his information.
  9. Feb 3, 2014 at 10:36 AM
    TACO TX
    Kelly
    Denison ,Texas
    Yea its also a time frame deal, they said they could do it in day. We cant get along being a car down for very long. Kids basketball practice, school, me and the wifes work.
  10. Feb 3, 2014 at 10:52 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Really they just pull up the manual and charge you by however many hours the book "says" it'll take. Been trying to get my coils replaced on my coil overs and its been pretty pricey. 3-450 just for labor. But if you go to a show that knows that they're doing it should be a lot cheaper because they know the actual time it costs to complete. Still seems a little steep though
  11. Feb 3, 2014 at 11:06 AM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    You don't need a press for the LBJ's. There's a $20 puller tool.
    Most shops can change out the shocks on a strut for ~$50 if you bring them the assembly already off the truck.
    Is there REALLY play in the LCA bushings? If they're stock LCA's and bushings they are a royal pain to change and I simply recommend replacing the whole arm with a new OEM unit.
    I wouldn't pay a shop that much. Just my opinion.
  12. Feb 3, 2014 at 11:12 AM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    That's a fair price, 2.0 to R&R struts, another 1.0 per lower control arms R&R, .5 for R&R bushings per arm, .5 for BJ R&R +alignement+parts+tax. If the shop is charging 100-120/hr that sounds about right. Took me 3 hours to remove my lowers, hammer out the bushings, and press in the new ones.
  13. Feb 3, 2014 at 11:42 AM
    TACO TX
    Kelly
    Denison ,Texas
    Pressing bushings out was what i would use a press for, new LCA's from Camel back are $190 each. Yes they are loose and they squeak like rubber on metal. I could move the arm about 1/8" to 3/16".
    Is a $100 an hour alot, yes. Would i rather go a different route, yes. Do i have time, tools, place, patience to run all over town looking for a shop that is willing to drop what everything and assymble struts and then find an alignment place, no not really. Thanks for everyones info and opinions but i guess ill eat it and be happy that my truck hopefully rides and drives like its suppose again. Its fast approaching 200,000 miles.
  14. Feb 5, 2014 at 2:55 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
    Not trying to be cute but too bad you live so far away.
    I am in Nuevo Laredo, Mexico, just across the border from Laredo.
    I know a good mechanic who will work for $5/hr, but then you would spend 100s just traveling back and forth LOL.
  15. Feb 5, 2014 at 3:07 PM
    TACO TX
    Kelly
    Denison ,Texas
    Bad part is they just called and said they had trouble getting the A-frame bushings out and wouldnt have it done today. But i dropped it off at 8am and it dodnt move till 11am. They should have stayed late to finish for me. I was only off work today and now have no truck.
  16. Feb 5, 2014 at 3:08 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Maybe do what's easiest yourself so you can save some money. My mechanic charges me low rates but he does have a system that he uses for most customers. He inputs the job and the computer gives him the time frame. It's usually higher time frame than what the job would call for. Maybe have your mechanic do the LCA bushings because I've heard its difficult. I've done lower ball joints and it takes maybe 1.5 hrs per side. Then For the coils you can rent a coil compressor from auto zone for $40 bucks then You get your money back once you return it, same goes for the ball joint press and puller for tie rod.
    Just trying to let you know it can be done in a day by you if you want to save some money. I don't have experience with the LCA bushings but I've heard negative things.
