Your opinion on this 2002 frame rust!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ouskambou, Dec 16, 2017.
  1. Dec 16, 2017 at 5:12 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Anywhere you see or suspect there to be rust, or can’t see bare metal because of that goopy stuff.
  2. Dec 16, 2017 at 5:43 PM
    Ouskambou
    Ouskambou [OP] Member
    Gotcha!
  3. Dec 16, 2017 at 6:00 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    well, it seems to be quite rusty underneath the old undercoat/black paint. So you definitely need to bang the frame thoroughly with a hammer, that's the only way to know if the rusty frame is still good
    the area to check first is where the leaf springs attach to the frame, right behind the cab, as this is usually the first spot where these frames start to rust and rot. Then by the catalytic converter and the gas tank, as these are commonly rotten spots.
    Then try to take a look under the bedliner, the seams of the bed seems to be rusty too
    standard likes this.
  4. Dec 16, 2017 at 7:46 PM
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    The truck bed is usually the worst.
  5. Dec 18, 2017 at 8:58 AM
    Ouskambou
  6. Dec 18, 2017 at 9:06 AM
    tacopablo
    tacopablo Well-Known Member
    Québec
    2002 tacoma 2.7l
    4th picture: this is where it can get ugly. Mine was perforated from rust at this location. If you go to Boulevard Toyota, they could tell you if the truck is still covered by the warranty. You could get a brand new frame. Ask for Sylvain Vincent, he knows pretty much all about it.
  7. Dec 18, 2017 at 9:06 AM
    Ouskambou
    Got it man I will be calling right now. Thanks, Ill report back!
  8. Dec 18, 2017 at 10:58 AM
    andrew8404
    ANDREW
    Albuquerque, NM
    Don’t bother you won’t get a new frame unless there’s an actual hole in it. My frame was about as bad as could be but no holes. This frame looks pretty terrible I wouldn’t waste your money on it. Trust me and look for a clean one.
  9. Dec 18, 2017 at 10:59 AM
    andrew8404
    ANDREW
    Albuquerque, NM
    Also a 2002 won’t be under warranty anymore. So your outta luck!
  10. Dec 18, 2017 at 11:04 AM
    Ouskambou
    Alrighty, thanks for your time Andrew!
  11. Dec 18, 2017 at 11:11 AM
    andrew8404
    ANDREW
    Albuquerque, NM
  12. Dec 18, 2017 at 11:26 AM
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
  13. Dec 18, 2017 at 11:52 AM
    onakat
    Canada
    2000 indestructaco!
    Nope, judging by these new pictures I'd pass
    Well, unless you hammer test it and it turns out it is good and you get it for real cheap, but the thing is that you will have to scrape off all of this old undercoat (and mud??), treat the rust and grease the hell out of the truck. But $5600 for this? no
    andrew8404 likes this.
