Your perfect snow build?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AlaskanTaco, Sep 17, 2012.
  1. Sep 18, 2012 at 6:34 PM
    #61
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd consider going with that size also. Right now I've got 265/65R17 highway tires and another set of 265/70R17 A/T's. Drivability-wise, I want something right in the middle so the 255/70R17 fit the bill and Hankook makes their Dynapro in that size. As long as it's a daily driver and with my short lift, the 245/75R17 or 255/70R17 would look nice I think while still giving me decent fuel economy and handle well. I've also heard that some of the taller tires cause the transmission to shift 'weird'.
  2. Sep 18, 2012 at 6:35 PM
    #62
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Hankook makes the ATm in 255/75/17
  3. Sep 18, 2012 at 6:41 PM
    #63
    Pugga
    Massachusetts
    You're not making it easy! Have you heard, or noticed anything as far as a weird shift due to the taller tires? I haven't researched it much since I still have 2 sets of tires and won't need a new set for a while.
  4. Sep 18, 2012 at 6:49 PM
    #64
    OZ-T
    Peter North
    British Columbia
    255/75/17 are basically the same height as 265/70/17
    I have 275/70/17 , haven't noticed anything change since I switched from 265/70/17
  5. Sep 18, 2012 at 6:49 PM
    #65
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    :confused: So you think going from a stock 31" tire to a 32" tire will screw with the transmission's shift logic?
  6. Sep 18, 2012 at 6:50 PM
    #66
    Pugga
    Massachusetts
    Good to know. Thanks!
    I might have to get a little taller when my tires wear out.
  7. Sep 18, 2012 at 6:51 PM
    #67
    Pugga
    Massachusetts
    Not screw up the logic. I read that someone noticed the transmission shifting harder with the taller tires. I they were running the 255/85R16 tires. I haven't looked into it any further since my tires are in good shape.
  8. Sep 18, 2012 at 6:52 PM
    #68
    OZ-T
    Peter North
    British Columbia
    Yeah , that guy was running 255/85/16
  9. Sep 18, 2012 at 6:54 PM
    #69
    KenLyns
    Belly of the Beast
    Haven't noticed a difference with mine (265/75-16). Wonder if the guy with hard shifts had pre-TSB software?
  10. Sep 18, 2012 at 6:56 PM
    #70
    OZ-T
    Peter North
    British Columbia
    He complained that the truck shifted at odd times through the whole range though , not just 1st - 2nd
  11. Sep 18, 2012 at 6:56 PM
    #71
    Pugga
    Massachusetts
    I didn't notice anything different with the 265/70R17's either but I was reluctant to go taller after reading that. I like my smooth shifting truck :)
  12. Sep 18, 2012 at 7:07 PM
    #72
    AlaskanTaco
    AlaskanTaco [OP] Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    I know about the taller skinny tires. No one here in Alaska drives with fat tires during the winter. And if you do, you are screwed. What other things would you do?
  13. Sep 18, 2012 at 7:08 PM
    #73
    OZ-T
    Peter North
    British Columbia
    Damn , sorry for the threadjack
    Apologize I must
  14. Sep 18, 2012 at 7:47 PM
    #74
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You know skinny vs wide can be easly settled. How far you are from new england and how much money you willing to bet? :D
  15. Sep 18, 2012 at 8:09 PM
    #75
    TRD 09
    TRD 09 Well-Known Member
    Alberta
    09 TRD sport
    I had the same tires on my F150, it handled all the hunting trails and job sites with ease, my vote is tall and skinny
  16. Sep 18, 2012 at 8:17 PM
    #76
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
  17. Sep 18, 2012 at 8:19 PM
    #77
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I can't wait for snow wheelin.
    Hopeful to have a few new mods for winter:
    Beadlocks
    Lockers front and rear
    Can't wait to test out my MTRs in snow.
  18. Sep 18, 2012 at 8:48 PM
    #78
    Spoonman
    Jamie
    Alberta
    It can go both ways. Snow vs ice require different tires IMO. Studs vs studless... Yadda Yadda Yadda
  19. Sep 18, 2012 at 9:46 PM
    #79
    Tacomada
    Tacomada Well-Known Member
    TBC - Canadiana
    2010 TRD Off Road
    That's actually not true. Contact patch size increases... Increasing weight increases friction, changing the rubber compound will increase friction. But the size of the tire does not increase friction.
    We must have an engineer in here somewhere.
    Other items if consider for winter driving and wheeling. Fog lights and driving lights if you plan on night driving.
    Weight in the box of the truck. Lots of commuting and potential for rough roads you may want to look at some system of securing whatever weight you put in the back. I use sandbags between the wheel wells secured by 2x10 boards in my old truck. Cut some grooves I hold skis and boards too. Got stuck offroad once and jammed a bag under the wheel. It tore open and the gravel created the traction I needed to get moving...
    Mud flap removal... Backing up in deeper snow with larger tires will make short work of them anyways.
    For wheeling obviously everything you have will work different in the snow. Jacks are a pain in the ass in snow so try an have something to use as a base.
  20. Sep 18, 2012 at 9:48 PM
    #80
    Ripcord
    Ripcord KM6PIM
    Jim
    Northglenn, Colorado
    Spruce Mica 2013 TRD-OR
    Friction is independent of contact area, its just Normal Force (weight of the truck) x Friction factor.
    Its the pressure that is increased with a smaller tire, Force / Area.
