Your perfect snow build?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AlaskanTaco, Sep 17, 2012.
  1. Sep 20, 2012 at 11:07 AM
    #141
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    and unsubbed
    Good luck OP
  2. Sep 20, 2012 at 11:17 AM
    #142
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Yes, much better in the desert as well. The bacon gives your muffler more traction.
  3. Sep 20, 2012 at 11:22 AM
    #143
    Saskquatch11
    Saskquatch11 TRUCK YEAH
  4. Sep 20, 2012 at 11:49 AM
    #144
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Agree, per fixed time 1cm will "dig" into ice deeper. I put dig in double quotes because its not actual dig its rather process of melting. (studs are great example of dig into ice. they do puncture ice, and it is why they are mounted very often on super skinny tires)
    Melting is the part that needs to be avoided. Once contact layer turns into liquid friction disappears.
  5. Sep 20, 2012 at 12:04 PM
    #145
    BlueT
    NorthEast
    :rolleyes:
    I offered to buy skinny tires to mount on your truck and put you on slab of ice to prove me wrong, ....
    You declined...
    If you believe in what you saying you should have no problem proving me wrong.
  6. Sep 20, 2012 at 12:16 PM
    #146
    Blygy
    Blygy Well-Known Member
    East of Edson
    Supercharged 2012 DCLB TRD Sport Trail Teams
    Trail Teams Edition Supercharger
    Yea.. I agree this is getting dumber and dumber.. I'm out as well..
  7. Sep 20, 2012 at 12:33 PM
    #147
    Tacomada
    Tacomada Well-Known Member
    TBC - Canadiana
    2010 TRD Off Road
    Oi. Why does the stud dig into the ice?
  8. Sep 20, 2012 at 12:35 PM
    #148
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    It's harder, and there is a lot if force pushing it into the ice.
  9. Sep 20, 2012 at 12:38 PM
    #149
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    If the tire was as hard as the stud. Say made of the same material. Would it dig into the ice?
  10. Sep 20, 2012 at 12:53 PM
    #150
    XXXX
    sKiP
    05 Prius
  11. Sep 20, 2012 at 2:46 PM
    #151
    Spoonman
    Jamie
    Alberta
    Depends on the tread/weight distribution/size/temperature of this metal tire you're describing.
  12. Sep 20, 2012 at 3:47 PM
    #152
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    Anyways. I'm getting to Carrie away with this. Point I was trying to make was that the smaller stud will "dig" into the ice more than a whole tire for a given weight.
    That the principle us skinny tire guys are trying to convey... Again to be noticeable there are many factors. The best example is slushy snow on a highways. There is a noticeable difference between a 235 series and a 285 series.
    For deep offroad snow of course the larger surface area is better. On road though the opposite is very true.
  13. Sep 20, 2012 at 4:43 PM
    #153
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Obviously you are retarded and do not understand physics.
    But if you are going to stand by your claims via YouTube videos so be it.
    As smart as you think you are there are always smarter people than you. And if you can't learn from other people then that is your problem.
  14. Sep 20, 2012 at 4:55 PM
    #154
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    The problem is this: there are countless variations of snow. Powder, slush, corn, wet, heavy, dry, fluffy, etc etc. While the hilux does really well in deep powder, I only see it going through deep untouched powder so for that application, yeah I agree it's best suited, and definitely most awesome. But for everyday driving, every tire shop up here will tell you one thing: a narrower snow rated tire will perform better than a wide tire. Some mud tires use a softer compound which can perform WELL, but is still outclassed by a devoted snow tire. I have just finished searching tire rack and was unable to come up with a 285 that was rated for winter. Isn't that strange? BTW I've lived in Alaska for 26 years so I'd like to think I'm an authority on our conditions. Bottom line is nothing we all don't know, there is no magic tire that will let you off road, play in the rocks, dig into the mud, boost your fuel economy, and be silent on the highway. Different strokes for different folks.
  15. Sep 20, 2012 at 5:03 PM
    #155
    XXXX
    sKiP
    05 Prius
    I eat yellow snow :)
  16. Sep 20, 2012 at 5:03 PM
    #156
    OZ-T
    Peter North
    British Columbia
    Lol ^^
  17. Sep 20, 2012 at 5:05 PM
    #157
    XXXX
    sKiP
    05 Prius
    all goofing around you guys should end the pissing contest and listen to the pros who actually plow the roads and deal with untouched virgin snow on roads like OP is asking about
    http://www.plowsite.com/showthread.php?t=21287
    Consensus from the expert pro's SKINNY
    end thread and but hurt lol
  18. Sep 20, 2012 at 5:09 PM
    #158
    benbacher
    Anchorage, AK
    I won!!!
    unsubd
  19. Sep 21, 2012 at 12:39 AM
    #159
    AlaskanTaco
    AlaskanTaco [OP] Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    Once you have lived in Alaska, you will understand why ALL OF THE PLOW TRUCKS RUN SKINNY TIRES! I understand that I am going to run skinny tires! Any other suggestions?
  20. Sep 21, 2012 at 12:45 AM
    #160
    AlaskanTaco
    Anchorage Alaska
    Here is something for those people that want to run fat tires during the winter. Next time, cut your pizza with your forearm.....then try cutting it with your pizza cutter. Tell me what the out come is. On wider tires, the weight is distributed in the center of the tire, and the rest is to grab something if needed. If you actually notice on a tire, that actually has some miles on them, notice that the wear pattern is in the center. Not so much on the edges unless your camber is screwed up.
