Your Responses
Discussion in 'Technical Chat' started by nobackhair, Nov 27, 2011.
  1. Nov 27, 2011 at 1:14 PM
    nobackhair
    nobackhair [OP] Well-Known Member
    There is a Hell, Az
    07 PreRunner LB Tacoma (White)
    DR coil-overs Camburg uniball UCA AFE stage 2 SI CAI AFE Catback
    I'm still in my rookie yr. here but I've noticed when I look up a reference to help w/ a, let's say, what kind of oil to use, I see these, "and it worked fine". Or it worked fine for me. Is that a conclusive documented reseached answer? I'm not here to complain but maybe looking for clarification I guess. Is there an almighty Taco Guru out there I don't know about that I can rely on w/ just, " I use Dadada and it works fine."?
  2. Nov 27, 2011 at 1:37 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    This is a forum. Not a research facility.
    People are telling their real world experience.
    Like anything on the net your going to have to take things with a grain of salt.
    If you want to use or do something and you have 2 or 3 different approaches to doing it then the research falls on you to decide which way to go.
    If you notice in a lot of threads there are a lot of questions asked to clarify something.
    There is no all mighty guru. There are a ton of people that have high knowledge in different areas. That's what makes this a high caliber forum.
    the final analysis falls on you :)
  3. Nov 27, 2011 at 2:37 PM
    Brunes
    Brunes abides.
    Rotorhead
    There is not a single answer for many things.
    Example: The best oil- There are so many oils that will work....Some people will observe the effects on mpgs, engine noise, oil pressure and temps, etc. Some people will get oil analysis done. Some people just call it good enuf if the engine doesn't blow up.
    You gotta make the decision for yourself most of the time....
  4. Nov 27, 2011 at 2:44 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I'm a little confused on what sort of answer you were hoping to get from such a general and subjective question.
  5. Nov 27, 2011 at 7:05 PM
    nobackhair
    There is a Hell, Az
    Very well put and realized this lately but I had to shake things up a bit. This forum is as good as it gets and that does have some gravity.
  6. Nov 27, 2011 at 7:08 PM
    nobackhair
    There is a Hell, Az
    Understood. Absolutely recognized.
    Do you partake in the yoga?
  7. Nov 27, 2011 at 7:09 PM
    Brunes
    Brunes abides.
    Rotorhead
    I did almost daily for a long time...I have kinda fallen off due to...well....life. But it made me happy and kept me sane thru most of college and for a few years after that...
  8. Nov 27, 2011 at 7:15 PM
    nobackhair
    There is a Hell, Az
    It was meant to be more of an opinion and I realize their isn't an answer and I wouldn't want one to think that because something works for them that they can't add their $.02. I, as much as anyone am not the least bit shy about an inquiry at the cost of appearing like a complete idiot. nufsaid. I knew when I made this thread I was going to open a can of worms.
  9. Nov 27, 2011 at 7:20 PM
    nobackhair
    There is a Hell, Az
    I guess I could say the same. Did it religiously for 3 yrs. but I started having some serious problems w/ my daughter wher I had to be w/ her every min. and I never wnt back. I have to say though that it does change you more than anything I've experienced. I'm back to bouncing off the walls, but w/ control.
  10. Nov 27, 2011 at 7:21 PM
    Brunes
    Brunes abides.
    Rotorhead
    I hear you man...I've got some of the DVD type sessions that I'm going to be trying to get back into...Lets me practice at the house instead of having to make a trip anywhere.
  11. Nov 27, 2011 at 7:32 PM
    nobackhair
    There is a Hell, Az
    Have those too.(Jim Martin) Can't push myself as hard but it's better than not doing it all. I do miss the scenery. I was in a class of 35 to 50 students a night that had a ratio of 1 in 15 men to women. That was a perk. I was right next to a univ. Need I say more. Bad. Bad boy. What would Bhudda say? Take care.
  12. Nov 28, 2011 at 6:43 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Meh this is a forum you should take any advices with grain of salt...
    On the topic of lubricants ... whats wrong with water ? :cool:
  13. Nov 28, 2011 at 6:49 AM
    leveltwo
    leveltwo Well-Known Member
    eh, it worked fine
    :anonymous:
  14. Nov 28, 2011 at 8:27 AM
    nobackhair
    There is a Hell, Az
    Ok guys. I get it. I'm gonna go have a glass of salt water.
  15. Nov 28, 2011 at 8:31 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Don't trust anyone :spy:
  16. Nov 28, 2011 at 8:46 AM
    Toyoghi
    Toyoghi Well-Known Member
    Shoghi
    Calgary, AB
    2011 Tacoma Double Cab
    Solid tri-fold Tonneau, Deezee Bed mat, Pop n Lock.
    GTFO please. :der:
  17. Nov 28, 2011 at 8:49 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    I agree.
  18. Nov 28, 2011 at 9:18 AM
    Toyoghi
    Shoghi
    Calgary, AB
    :puke:
  19. Nov 28, 2011 at 9:33 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    lol really! i have guys pming me about retrofitting constantly and i answer every single one i respond to post 99% of the time in a positive manner and so do many others.
    sure there are some guy's on here that flame a bit for not searching but, if your asking a question that there is a hundred threads on already it's your fault for not using the search function right?
    i have never really done stuff to any of my cars or trucks myself before but with the help of some of the local guy's on tw and the general research and other members i have built a pretty bad ass truck man i love it here.
    do i get tired of the "whats the largest size tire i can run on a factory truck" threads hell yes!
    i never really had any trouble asking a legit question that i needed help with. if you don't like it here try custom tacos :) you may find there members are more your speed.
  20. Nov 28, 2011 at 11:11 AM
    KPT
    09 Prerunner
